Old 02-10-2013, 03:36 PM   #1
straight_beamin
My Ride: 2000 bmw 323i
Speedometer maxes out when i turn car on
Hi, today i noticed when i turned on my car the speedometer shot up to 250km/hr and just stayed maxed out. The rpms and the temperature and gas gauge work properly but the speed and the mpg needles do not. Ive tried the cluster reset and the battery disconnect with no luck.also checked fuses 10,34,and 43 Another problem on the never ending list
straight_beamin is offline   Reply With Quote
Old 02-10-2013, 03:38 PM   #2
straight_beamin
This is what happens when i turn car on or into position 2 (accessory). When i turn it off it goes back down to zero
Old 02-10-2013, 03:42 PM   #3
stevenluczynski
My Ride: Is Steel Blue
Looking at the non oem background, it's most likely a messed up motor or mid aligned needle.
stevenluczynski is offline   Reply With Quote
Old 02-10-2013, 03:55 PM   #4
Charmervin
My Ride: 2001 325ci
Check to make sure battery is good...
Charmervin is offline   Reply With Quote
Old 02-10-2013, 04:06 PM   #5
straight_beamin
Actually ive noticed that the battery light also stays on... Think it is the battery
Old 02-10-2013, 04:07 PM   #6
straight_beamin
Ive had the m3 style cluster in there for 3 years with no problems. Could it just one day do this lol?
Old 02-10-2013, 05:04 PM   #7
straight_beamin
just checked again while driving, battery light is on! thoughts?
Old 02-10-2013, 05:08 PM   #8
tks
My Ride: slower than yours
Battery light on.
Go to test 9 in OBC give us results with car on / off
12.5-14.0 car running
12.0-12.6 car off
at least iirc those are normal numbers.
if while running, numbers dont match up, alternator is poo-ed out.
WTB:: Natural Brown Sedan Full Interior
tks is online now   Reply With Quote
Old 02-10-2013, 05:15 PM   #9
straight_beamin
ok will post back shortly, would the alternator cause weird issues with speedo and/or cluster? also noticed the digital part with the mileage and clock is flickering faintly
Old 02-10-2013, 06:39 PM   #10
straight_beamin
12.1-12.3 volts off
11.3 steady while running
Old 02-10-2013, 06:56 PM   #11
tks
that 11.3 is probably going to diminish... does it ever go higher?
I wouldn't rule out alternator ad a problem but being that the car is already NOT being charged, that is another problem that could affect your current one.
Same as before, see if you can pull up OBC 9.0 =
Get current reading with car running.
Then go to hood, find alternator, unplug sensor part, then go back to OBC see if it changes.
If your is already at 11.3 v while running, your alternator already isn't charging though so yeah.. that's your first problem!
Old 02-10-2013, 07:24 PM   #12
straight_beamin
I dont see where the wire is to unplug, safe to keep driving to work?
Old 02-10-2013, 07:26 PM   #13
2000beamer
My Ride: 2000 323i
You have a faulty rear right brake light as well.
[/SIGPIC]
2000beamer is offline   Reply With Quote
Old 02-10-2013, 07:37 PM   #14
straight_beamin
Nah its just from the led tails lol
Old 02-11-2013, 01:02 AM   #15
fth001
My Ride: 325i, e36m3, s13
Voltage should be in the 13's when the car is running. A quick and easy alternator check is to start the car and then pull the ground off the battery. If the car stays running, the alt is working, if it dies the alt is bad. These cars start acting really weird when there is a voltage problem so the battery should be checked out also.
fth001 is offline   Reply With Quote
Old 02-11-2013, 04:40 AM   #16
straight_beamin
Ya checked this morning im at 10.7 volts when running.
Old 02-11-2013, 06:17 AM   #17
straight_beamin
Should i replace the alternator?
Old 02-11-2013, 10:26 AM   #18
tks
Yes.
Don't try driving the car because your battery will be next to die too!
Make sure you get it fully charged before you hook up the new alternator so you don't fry it!
Old 02-11-2013, 11:46 AM   #19
Ballstowalls
My Ride: 05 e46 m3 vert
Slow down haha
Ballstowalls is offline   Reply With Quote
Old 02-11-2013, 12:19 PM   #20
straight_beamin
Originally Posted by ruskisky View Post
Yes.
installing the new alternator now, will report back. thanks a million
