Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 22 votes, 4.05 average. Display Modes
Old 02-11-2013, 04:36 AM   #21
ZHP6
My Ride: M6
Gotcha. Thanks so much for the clarification.
ZHP6 is offline   Reply With Quote
Old 02-11-2013, 12:52 PM   #22
cyberkaa
My Ride: E46 332i,M3;E30 325i
Originally Posted by ZHP6 View Post
Is there a way to swap those in as well, or do you need the E46 M3 subframe? I'm trying to figure out if it's possible to get at least 7 degrees of caster with camber plates and a few mods.
I've done exactly that. Front subframe was left stock (it's already the same part number as the M3).
http://forum.e46fanatics.com/showpos...&postcount=487
-Kalim
(klx photo studio)
Old 02-11-2013, 05:38 PM   #23
Alex323Ci
My Ride: M3 & 323Ci (sold)
not that it matters for the info of swaps. but although the front subframe may be the same mounting points. the M3 uses the stronger front subframe from the convertible and not the coupe/sedan. it's different.
Old 02-11-2013, 05:50 PM   #24
cyberkaa
The x-ref list here shows the same part:
http://realoem.com/bmw/partxref.do?part=31111096902
Do you have a side-by-side comparison?
That was one thing I was unable to verify except by memory since the M3 subframe was off at a different time.
-Kalim
(klx photo studio)
Old 02-11-2013, 07:03 PM   #25
mkodama
mkodama's Avatar
Are you sure you aren't talking about the underbody reinforcement brace 51717893609? That is a different part, only used on the M3 and the Z4 Ms
Old 02-12-2013, 03:09 PM   #26
Alex323Ci
I don't have comparison. This is specifically listed by BMW in the M3 specs pages.
As for the part number, I suspect they just stock the one now for replacement just like the rear subframe panel. The stronger convertible version.
No I'm not talking about the aluminum plate.
Old 02-12-2013, 03:29 PM   #27
cyberkaa
You've got me curious. Do you have a link to the specs pages?
-Kalim
(klx photo studio)
Old 02-12-2013, 03:56 PM   #28
Alex323Ci
i figured you wouldn't believe me.
last line of the E46 M3 FRONT SUSPENSION SPECS
Old 02-12-2013, 04:20 PM   #29
cyberkaa
[IMGhttp://img.photobucket.com/albums/v188/showitsam/IMG_0389_zps12e583be.jpg[/IMG]
Well, don't be so hard on yourself. It's not that I didn't believe you, but I wanted to see the source. There are a lot of details there that we can independently verify.
Specifically, I'm thinking that since I have 2000 323ci, 2003 325i, and a 2002 M3 at my house right now, I can check all of the subframe part numbers if they're still visible and verify that claim.
-Kalim
(klx photo studio)
Old 02-13-2013, 10:19 AM   #30
Orchazum
My Ride: Steel Grey 330i
So all in all, is it possible to swap out springs only from an m3 to a 330i?. By the looks of it, im gonna have to hunt for an m3 being sold for parts ..its time for a little suspension "love" anyway
Multi Color Angel Eyes, MD, K&N, Sharked, Y-Rated Shoes
Orchazum is offline   Reply With Quote
Old 02-13-2013, 01:09 PM   #31
mkodama
mkodama's Avatar
The the springs looked interchangeable. Same diameter and ends, etc. They are a good deal higher of a spring rate though, so with used non-M dampers, you're probably going to get a very bouncy ride.
Old 02-13-2013, 01:19 PM   #32
Orchazum
Yaaa im not going for the ***** look hahahahah. Thank you for the input however... Much appreciated
Sent from my SPH-L710 using Bimmer App
Old 02-17-2013, 12:56 PM   #33
Cpconst
My Ride: 2004 e46 m3
I'm doing this swap this week and was wondering what the best position for the three top mounting bolts to be positioned for the closest to factory specs for non-M?
Cpconst is offline   Reply With Quote
Old 02-17-2013, 01:24 PM   #34
mkodama
mkodama's Avatar
Probably the position that moves the strut bearing pivot point forward. Camber adjustment stays pretty much the same as a non-M, but there is a small loss in caster/self centering of the steering.
Old 03-18-2013, 09:02 PM   #35
hamadyr
My Ride: '05 330i ZHP
In that last picture of the strut bearing:
Rotated 240 degrees clockwise from original, it seems to give the highest camber and caster when used on non M.
Has anyone set it like this and performed a wheel alignment ?
What is the measurement for camber and caster ?
Visually I would guess around -3 degrees camber.
Anyone have data or a more educated guess ?
hamadyr is offline   Reply With Quote
Old 03-24-2013, 07:18 PM   #36
Mccomasg09
My Ride: 2001 Hellrot 330Ci
Just to be clear ride height stays about the same in the rear and raises a little in the front? I was just curious what the reason for this was? Thanks guys
Mccomasg09 is offline   Reply With Quote
Old 03-25-2013, 12:12 AM   #37
mkodama
mkodama's Avatar
The ride height looks about the same as non-M sport suspension.
The rumor was that M3 front springs would raise the front of a non-M because they were designed to support the heavier M3 engine, but there was nothing noticeable to me.
Old 03-25-2013, 02:46 AM   #38
Mccomasg09
Thanks for the reply, and what did you notice were the biggest benefits? And any negatives? I got a good deal on some and I need new struts, I prefer to stay oem everything but if there is no negative I wouldn't mind swapping them out?
Old 03-25-2013, 03:24 AM   #39
mkodama
mkodama's Avatar
The installation wasn't on my car, so I can't give any helpful info there. Try messaging Devious21 or hizhinezz.
Old 03-30-2013, 12:39 AM   #40
silyb0y
My Ride: E46 330
Non-M struts are partially compressed at rest position, fluid can be heard if shaken, and easier to compress, strongly suggesting a low-pressure twin-tube design. M3 struts are fully extended at rest, no fluid can be heard if shaken, and are harder to compress, strongly suggesting a high-pressure mono-tube design."
I know for a fact that non-M-shock-absorbers are twin-tube-design. However - the OEM-Sachs-shocks on my 330 (M-package) did fully extend in resting position (even after 5 years / 90.000km). Even the rear ones that were leaking oil did fully extend - indicating that there was still pressure inside.
Same goes for my brand new Bilstein B4 replacement shock absorbers which are listed as twin-tube-design - they fully extend - all by themselves. If your E46 Sachs/Bilstein shocks dont fully extend its likely they are worn out/shot/dead. I know - there are cases were brand new twin-tube-shocks dont fully extend but the twin-tube Sachs/Bilstein E46 shocks do!
Note: twin design shocks break down slowly. They even work (kind of) when they are in the process of failing. This is why a lot of people dont notice that their shocks are gone. It usually happens so slowly that they get used to feel. Mono-tubes usually last longer than twin-tubes but when they fail -> you know immediately
BTW - if you look up the E46 M3 shocks in the Bilstein catalog you will see that the B4 replacement shocks are listed as twin-tube-design as well. That of course does not prove that the OEM M3 shocks (I guess Sachs) are twin-tube-design but its an indication.
silyb0y is offline   Reply With Quote
