Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 50 votes, 5.00 average. Display Modes
Old 02-08-2013, 04:38 AM   #81
CTRob
My Ride: Alpine white e39
Originally Posted by Marty19 View Post
Just to let you know that Torque works fine via USB
This is great news delighted ;-)
CTRob is offline   Reply With Quote
Old 02-08-2013, 05:03 AM   #82
Marty19
My Ride: 2004 330 ci Vert
Originally Posted by ctrob View Post
this is great news delighted ;-)
Marty19 is offline   Reply With Quote
Old 02-08-2013, 07:51 AM   #83
tnhl1989
My Ride: 02 330xi(RIP),03 ZHP
Charles will be away for Chinese New Years until the 18th.
tnhl1989 is offline   Reply With Quote
Old 02-08-2013, 11:23 AM   #84
Kripas
My Ride: 04 325ci convertible
just installed
Kripas is offline   Reply With Quote
Old 02-08-2013, 11:25 AM   #85
HighxTech
My Ride: 2002 330i
Yesssssss, how does it work? What do I need?
HighxTech is offline   Reply With Quote
Old 02-08-2013, 11:36 AM   #86
jchuillier
My Ride: 330CD
You need to buy the USB plug in the ebay link and torque pro on the playstore...
Total cost should be around 25 euros...
jchuillier is offline   Reply With Quote
Old 02-08-2013, 11:37 AM   #87
HighxTech
My Ride: 2002 330i
Should I get a USB hub because I have my WiFi dongle in the top port?
Old 02-08-2013, 11:42 AM   #88
jchuillier
My Ride: 330CD
Yes, then you need more stuff...
On ebay you can find some 7 port USB hub with AC power for a whooping 4.78$ http://www.ebay.com/itm/130614851519...84.m1439.l2649
You also need a power converter 12V to 5V 5 amps for 3.13$ http://www.ebay.com/itm/251098936087...84.m1439.l2649
The idea to have a powered hub is that you can plug a HDD on it, leave a USB cable going our to charge your phone or whatever you want.
And for an extra cost of about 5$....it's not worth buying a non powered hub
Old 02-11-2013, 05:26 PM   #89
chouch
My Ride: X5
Installed B039 4.0.4 Android unit on my X5 2001, I am hoping I get some detailed answers on how to fix those:
- Radio Reception: plugging the cable just doesnt enhance the reception, is there a better way of fixing the reception without buying an antenna amplifier for $200
- There's a blue cable with ANT written on it? what's that for?
- Sound is just too Loud: I found a way to reduce the sound level by putting the EQ to Rock mode, is there a better way of doing so? can someone explain how to install the speaker level converter?
- Wheel buttons: this is just crappy, laggy, buggy, whatever you want to name it ... it just works 30% of the times ... is this it forever?
- also on the radio side the next button is supposed to change to the next registered channel, mine hops on to the next frequency level
- Phonebook in Bluetooth: isnt it supposed to download the phonebook from my phone? how the hell do you add a number to the phonebook
I dont want to start with the android part, this is a whole other issue.
chouch is offline   Reply With Quote
Old 02-12-2013, 03:31 AM   #90
jchuillier
My Ride: 330CD
Radio reception is good for me when I plugged into the existing antenna cable, I just need to extend this cable all the way forward.
Blue antenna cable is to tell the bmw amplifier to switch into the proper mode if you have the system where the amp and radio are in the back....if you have the system in the front maybe you don't need the blue wire if your amp and so on is in the front
Souns is loud, yes...you need to install a volume switch on the line between the enco and the amplifier
Wheel buttons are ok for me, I get about a 95% working response, make sure the red box is connected properly and that vibrations cannot move it too much
Phonebook, I'm not there yet....
Old 02-12-2013, 08:27 AM   #91
Marty19
Has anyone got bluetooth working on the Android side?
I have tried using a USB dongle with no joy, bluetooth just will not switch on.
I assume there is no way of tapping in to the bluetooth on the radio side?
Old 02-12-2013, 12:00 PM   #92
kaciker
My Ride: E90 320d
Hello
I have proved 5 different, and none works. One of them of brand belkin, that is the one that they were recommending in Dynavi's forum.
But, Your you had managed to make work OBD2 for USB, it is not like that?
kaciker is offline   Reply With Quote
Old 02-13-2013, 02:00 AM   #93
Marty19
Originally Posted by kaciker View Post
Hello
The OBD2 for USB was a wired connection, not bluetooth. I would prefer to get Torque working over bluetooth but it seems this is not possible.
Old 02-13-2013, 08:26 AM   #94
kaciker
My Ride: E90 320d
Yep I know
Bluetooth now is not possible.
USB yes !! For you information THANKS, we are 9 persons that after you test we buy a USB Obd2
The USB connection is very fast and Bluetooth not.
The lag for de Bluetooth (tested whit one Samnsung) is not good
Old 02-13-2013, 09:00 AM   #95
Marty19
Does anyone know if its ok to leave the OBD2 plugged in all the time? I notice there is a red light on even after the ignition is off.
I guess my questions are:
1) Will it damage the ECU by leaving the OBD2 plugged in all the time?
2) Will the battery drain be significant with the engine off?
Old 02-13-2013, 11:10 AM   #96
kaciker
My Ride: E90 320d
1) -> a good question...
2 -> My intention is to weld in the part of behind of the connector a cable pin to pin, to take this cable up to behind the radio, to use the cable of (12v WITHOUT key) in order that the OBD2 ignites simultaneously that the car.
Old 02-15-2013, 08:35 AM   #97
Marty19
Whats the best 3g dongle to use with this unit without having to use PPP widget?
I currently have a ZTE MF190 but doesn't seem to work out of the box, though I can get it working using PPP.
Old 02-15-2013, 10:57 AM   #98
bjornh
My Ride: 320iAT
Huawei E220 seems to be the industry standard. Worked on all my tablets so far, and it is reportedly the one ENCO ships with their devices.
bjornh is offline   Reply With Quote
Old 02-18-2013, 01:57 AM   #99
Kripas
Just tested on my iphone 5 using bluetooth on enco device I can play my music playlist from my music apps and also can play pandora apps from my iphone.
Old 02-18-2013, 03:48 AM   #100
Marty19
Hi Kripas, thanks for the reply. There is no problem with the bluetooth on the "stereo" side of the unit but the "Android" side seems to need its own bluetooth device.
