E46 Xi Forum
Old 06-17-2012, 02:21 AM   #1
bmwstephen
My Ride: e46 325XI, e36 M3
Drop Hats/Lower Spring Pads
Did XI owners get lower spring pads for the front too? I know we have a 5mm rear spring pad that'll take off some distance between the arch and the wheel.
bmwstephen is offline   Reply With Quote
Old 06-17-2012, 08:20 AM   #2
Kubica
My Ride: 2003 325xi
Nope.
Old 06-19-2012, 12:43 PM   #3
bmwstephen
http://www.bimmian.com/Mechunik-Fron...W-E46-3-Series
in case anyone wants to lower their car on a stock suspension. I've ran these on my e30 for over a year now and they are great. Looks like it can work for XI's to since their spring plates are idential to the AWD one.
combine this with a smaller rear spring pad (OEM)
and your car should return to the level of a I setup.
Old 06-19-2012, 04:56 PM   #4
shadow 2
My Ride: 07 328i
Sounds like a good idea.
shadow 2 is offline   Reply With Quote
Old 06-19-2012, 08:42 PM   #5
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
these look like e90 drop hats to me available at your local dealer for like $20
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 06-19-2012, 08:52 PM   #6
bmwstephen
no the e90 drop hats have a protruding center that eats into your shock's piston when you bottom out. It's been discussed in the e30 community. It actually sits 5mm less than the one bimmian sells. For us XI owners who want to get the most drop while retainin OEM setups, it might be worth while to pay a little extra.
in any event. I don't encourage anyone to get them yet. I'll be the guinea pig in the coming month when I do an inspection 2 on my car before handing it to my brother.
Old 08-26-2012, 11:55 PM   #7
Carter22
My Ride: 01' 325xiT, 72' 2002
Any word on these?
Carter22 is offline   Reply With Quote
Old 08-28-2012, 02:49 PM   #8
JRiggs
My Ride: E36 M3 S50, E46 M3
Those look really close to the E90 ones. I don't see the nasty centers you're talking bout... or maybe I'm not looking at the exact right spot. Either way in for info, the winter beater needs a ever so slight drop.
E90 Inside
Mechunik Inside
E90 Outside
Mechunik Outside
JRiggs is offline   Reply With Quote
Old 08-28-2012, 03:04 PM   #9
bmwstephen
sorry i meant to clarify that the protrusion is only noticeable when i compared it to e30 stock spring hats.
regardless. if you look at the munick ones, the designs are clearly different if you see how tall the it is and how deep the spring will sit into the pocket as opposed to the e90 drop hat. It's a bit hard to see because of the color and angle of the photos. The drop is there because if you google e90fanatics, a lot of members actually installed these on their cars to to deliver the drop their stock plate's couldnt do
Old 08-28-2012, 11:17 PM   #10
E46er75
My Ride: 323i Vert, 330xi
So these looked interesting, has anyone added these to in addition to and already lowered XI with Eibach/HR springs???
E46er75 is offline   Reply With Quote
Old 08-29-2012, 12:25 AM   #11
Carter22
I have a set of the OEM E90 hats, we had them in stock so I said what the hell. I'll try them out before the weekend. Just put new Bilsteins on the wagon and it raised back up to stock XI height...I really liked the sagging look haha...oh well
Old 08-31-2012, 11:52 PM   #12
E RaK
My Ride: 2001 325xit
I have these ready to go in but I went off to school so they will have to wait
E RaK is offline   Reply With Quote
Old 01-08-2013, 11:58 PM   #13
SSB Z4
My Ride: 325xiT, Z4 race car
Any updates? Please post pics
SSB Z4 is offline   Reply With Quote
Old 01-09-2013, 09:30 AM   #14
xi_ter
My Ride: 2003 325xi
Koni Yellows/ Eibach ProKit were low enough in the front. I managed to break off my under body jack pad under the engine area with normal driving.
Old 01-10-2013, 11:27 AM   #15
SSB Z4
Anyone tried lowering spring perches on an XI? Let me know which one fits.
Old 02-11-2013, 02:59 PM   #16
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
How has no one tried this yet? I'm so curious but don't want to find out that it won't work
drumbum624 is online now   Reply With Quote
Old 02-11-2013, 03:11 PM   #17
E RaK
I have had a set sitting around for months still waiting to go in. I'm sure they work fine to give a slight drop on the front axle. There was a post on the E90 forums from months ago that showed a side by side comparison, try searching there for pictures.
Old 02-11-2013, 04:17 PM   #18
e46alfonso
My Ride: 330xi MT, mustang gt
kabooom did it. He said it will lower an xi to RWD height.
Old 02-12-2013, 11:49 PM   #19
SSB Z4
This is the response I got from Tam Nyguen from Supreme Power when I placed my order. "Thank you for your online order. We are unable to confirm that the spring perches will work on your 2003 325xiT. We can process the order but the item will be nonrefundable."
I am holding off until someone can confirm that they work.
Old 02-24-2013, 07:58 PM   #20
bmwstephen
http://forum.e46fanatics.com/showthread.php?t=929526
