Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 02-11-2013, 11:24 PM   #1
bmwm330cie46
My Ride: e46
e46 headlight swap
im getting xenon projector headlight from a 2002 e46 to replace my stock 2001 headlights , just wondering is it a direct fit with the wire and plugs and how do i make them auto leveling
bmwm330cie46 is offline   Reply With Quote
Old 02-12-2013, 12:01 AM   #2
afstud
My Ride: 2003 ZHP 6-speed
If your car has halogen headlights, you will have to have them programmed, via coding to accept the Xenon headlights or buy some kind of Relay resisters to make your car think your running the halogens, The auto leveling will not work because you dont have the auto level sensors on all 4 of the suspension arms, but autoleveling isnt really a big deal, doesnt really make a difference and mine doesnt work anymore because my car was lowered and i dont care, just make sure there aimed properly, next as far as them swapping, we need to know some information are you swapping from a coupe to a coupe or what ?
2003 330i ZHP 6 speed
afstud is offline   Reply With Quote
Old 02-12-2013, 12:02 AM   #3
TallSkinnyMatt
My Ride: E92 M3 ZCP
Just get a BMW scanner 1.4 and reprogram the xenons.
TallSkinnyMatt is offline   Reply With Quote
Old 02-12-2013, 12:09 AM   #4
bmwm330cie46
My Ride: e46
i also have all aftermarket suspension so cant do auto leveling ,thx for that info ,yes coupe to coupe, i found out so far that i need screw on blinkers instead of clip on ones
Old 02-12-2013, 03:06 AM   #5
afstud
your exactly right.....
Old 02-12-2013, 03:10 AM   #6
eneka
My Ride: 2003 325i
I recall there only being 2 leveling sensors?
eneka is offline   Reply With Quote
Old 02-12-2013, 03:58 AM   #7
Bluzzer
My Ride: E46 328Ci
I bought last year xenon lights for mine. Dont need a reprogramming.
Plug and play
Bluzzer is offline   Reply With Quote
Old 02-12-2013, 04:53 AM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Coupe to coupe yes they will work. Coding should be done to avoid any issues such as flickering.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 02-12-2013, 12:06 PM   #9
afstud
yea you probably will have to code them, i swapped some in a few ive had and they all flicker and shut off after a minute, i used resisters on one that i got from the retrofit source but then the computer figured it out somehow and started doing it again so easier to get em coded and be OEM
Old 02-12-2013, 07:44 PM   #10
bmwm330cie46
My Ride: e46
i just got the headlights in mail today i will install them tomorrow and give u guys a update at night time about all . i bought them separet on ebay one is part number ending in 72 the other one is 71 is it becouse the year diffrance 02 and 03 thay look the same
Old 02-12-2013, 08:04 PM   #11
bmwm330cie46
My Ride: e46
are the leveling sensors for the auto leveling on the front control arms because i am planing to get the melye hd arm soon from http://www.oembimmerparts.com/BMW_E4...rts_s/1836.htm and what extra wireing do i have to do just wondering . if i choose to go with the auto levoling will it still work if i choose to run a fueltech standalone system if i choose to run it with my turbo kit
Old 02-13-2013, 08:14 PM   #12
bmwm330cie46
My Ride: e46
Got them installed all wiring fits fine . The xenons dont flicker but on my dash reads headlight bolbs out . Will reprogram it asap thanx for ALL UR help
