Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 02-05-2013, 04:14 PM   #981
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Shouldn't you put back in the bleeder screw before using the turkey baster?
Old 02-05-2013, 04:17 PM   #982
My Ride: 2016 Lexus
the bleed hole is just another hole like where the expansion tank cap goes, so not necessary.
Old 02-05-2013, 04:29 PM   #983
Solidjake
Zero. Leaks.
Solidjake's Avatar
Alright, danke
Old 02-05-2013, 04:55 PM   #984
Stinger9
My Ride: '04 330Ci
Originally Posted by NickBMW View Post
mango where is the drain bolt to drain out old coolant?
On the underside of the block on the passenger side.
Nasty to get a socket on and takes some wrist strength with one hand on a 3/8" drive.
See the tie rod cover and ground strap in these pics for orientation:
Old 02-08-2013, 07:18 PM   #985
mike66
My Ride: Jaguar XK8 BMW 325i
I searched and didn't find an answer.....on my Jag, the temp guage was a "feel good" stay in the middle idiot light until all hell broke loose gauge. Does the E46 work the same way? We had a forum member who came up with a fix (new circuit board), and now I know the actual temp. The same mod would be very useful to us if this is the case. It would prevent the all of a sudden the needle goes to the "engine toast" position.
mike66 is offline   Reply With Quote
Old 02-08-2013, 11:49 PM   #986
Stinger9
My Ride: '04 330Ci
Ours works the same way.
Would be very popular if someone could come up with a mod kit.
Old 02-09-2013, 01:41 PM   #987
eneka
My Ride: 2003 325i
Yup ours works the same way, I recall someone making a buzzer of some sort?
eneka is offline   Reply With Quote
Old 02-09-2013, 04:10 PM   #988
My Ride: 2016 Lexus
yeah it's called coolant snitch
http://www.zhpregistry.net/Tech/CoolantSnitch.aspx
Old 02-09-2013, 07:59 PM   #989
Stinger9
My Ride: '04 330Ci
That serves one purpose, but it does not modulate the temp gauge to give an accurate temperature reading.
Old 02-14-2013, 11:53 AM   #990
norcalmike
My Ride: 2001 330Ci
bad water pump sound
Im replacing my entire cooling system today minus radiator. Here is a quick video why. this had been going on for over a year when the car was still my sisters.
norcalmike is offline   Reply With Quote
Old 02-14-2013, 12:18 PM   #991
Stinger9
My Ride: '04 330Ci
at least you're smart enough to have a manual.
Old 02-14-2013, 12:23 PM   #992
norcalmike
My Ride: 2001 330Ci
Automatics are for girls and grandparents
Old 02-14-2013, 12:54 PM   #993
7xWDC-MSC
My Ride: 2005 325xi
Seeing your car is a 2001 I would throw a new radiator in there if it's original, even if it's a low mileage vehicle. 13 years of heating and cooling cycles take their toll on the plastics of the unit. It's short money for a MT $132.95 from my local source. It would really suck to get everything back together only to find a leak from reassembly.
Rubs the roundel on its skin or else it gets the hose again.
7xWDC-MSC is offline   Reply With Quote
Old 02-14-2013, 12:55 PM   #994
My Ride: 2016 Lexus
+1. the seals that hold the endtanks to the main body are just about done. also theres a chance you WILL damage your lower radiator plastic outlet as you remove that lower hose. very brittle.
Old 02-14-2013, 05:08 PM   #995
norcalmike
My Ride: 2001 330Ci
The operation was a success! took only a few hours and was very easy. The radiator was dated 2010 so I was good to go there.
I just got back from doing burnouts
thanks guys
Old 02-14-2013, 05:11 PM   #996
My Ride: 2016 Lexus
thanks guys
Old 02-14-2013, 05:20 PM   #997
caleb6
My Ride: 2005 330XI
thanks guys
Burnouts yep, next will be your fuel pump going out, and fuel filter. Just sayin'
caleb6 is offline   Reply With Quote
Old 02-14-2013, 05:42 PM   #998
norcalmike
My Ride: 2001 330Ci
that was done a couple years ago already, but thanks for the positive vibes man
Old 02-14-2013, 06:00 PM   #999
7xWDC-MSC
My Ride: 2005 325xi
Not to digress from the point of this thread but I'm dying to know the correlation between burnouts and fuel pump & filter failure.....
Old 02-14-2013, 06:03 PM   #1000
caleb6
My Ride: 2005 330XI
its a long story. catch up on all the new maintenance threads and you'll see.
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
