Rating:
#981 |
Mod
Shouldn't you put back in the bleeder screw before using the turkey baster?
#982 |
the bleed hole is just another hole like where the expansion tank cap goes, so not necessary.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#983 |
Mod
Alright, danke
#984 |
On the underside of the block on the passenger side.
Nasty to get a socket on and takes some wrist strength with one hand on a 3/8" drive. See the tie rod cover and ground strap in these pics for orientation: |
#985 |
I searched and didn't find an answer.....on my Jag, the temp guage was a "feel good" stay in the middle idiot light until all hell broke loose gauge. Does the E46 work the same way? We had a forum member who came up with a fix (new circuit board), and now I know the actual temp. The same mod would be very useful to us if this is the case. It would prevent the all of a sudden the needle goes to the "engine toast" position.
#986 |
Ours works the same way.
Would be very popular if someone could come up with a mod kit. |
#987 |
Yup ours works the same way, I recall someone making a buzzer of some sort?
#988 |
yeah it's called coolant snitch
http://www.zhpregistry.net/Tech/CoolantSnitch.aspx
#989 |
That serves one purpose, but it does not modulate the temp gauge to give an accurate temperature reading.
#990 |
bad water pump sound
Im replacing my entire cooling system today minus radiator. Here is a quick video why. this had been going on for over a year when the car was still my sisters.
#991 |
at least you're smart enough to have a manual.
#992 |
#993 | |
My Ride: 2005 325xi
Seeing your car is a 2001 I would throw a new radiator in there if it's original, even if it's a low mileage vehicle. 13 years of heating and cooling cycles take their toll on the plastics of the unit. It's short money for a MT $132.95 from my local source. It would really suck to get everything back together only to find a leak from reassembly.
Rubs the roundel on its skin or else it gets the hose again.
#994 | |
#995 |
The operation was a success! took only a few hours and was very easy. The radiator was dated 2010 so I was good to go there.
I just got back from doing burnouts ![]() thanks guys |
#996 | |
#997 | |
Modded ///Member
yep, next will be your fuel pump going out, and fuel filter. Just sayin' Last edited by caleb6; 02-14-2013 at 04:21 PM. |
#998 |
#999 |
My Ride: 2005 325xi
Not to digress from the point of this thread but I'm dying to know the correlation between burnouts and fuel pump & filter failure.....
#1000 |
Modded ///Member
| Tags |
| bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump |
| Rate This Thread | |
