Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 02-14-2013, 06:40 PM   #15981
My Ride: Lexus
If i had to guess, it's the bracket closest to the transmission mount hitting on the heat shield or the heatshield itself loose
Old 02-14-2013, 07:01 PM   #15982
My Ride: Lexus
I think i'll look for these:
http://www.harborfreight.com/3-piece...lls-91616.html
Old 02-14-2013, 07:40 PM   #15983
Cpconst
My Ride: 2004 e46 m3
Just finished installing water pump, pulleys, both belts, expansion tank, tank bracket, transmission thermostat, new brass bleeder screw and flushed coolant. Po replaced radiator and hoses last year so now I should be good for another 70,000 miles
Cpconst is offline   Reply With Quote
Old 02-14-2013, 07:59 PM   #15984
My Ride: Lexus
found it. uploads sideways. ugh
Sent from my SGH-T999 using Bimmer App
Old 02-14-2013, 08:03 PM   #15985
caleb6
My Ride: 2005 330XI
Walked down to the garage and just looked at it. Does anyone else just enjoy looking at their cars? I think there is something I want to do, but end up just popping the hood, wiping down the engine, and looking the car over.
I have to address a headlight washer leak issue (caused by me when I took the headlights out to switch ignitor and ballast to fix a a xenon issue). Looks like I'm going to have to order a new nozzle for the left side.
caleb6 is offline   Reply With Quote
Old 02-14-2013, 08:03 PM   #15986
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Having fun tonight?
Old 02-14-2013, 08:05 PM   #15987
college46
My Ride: Alpine White
Tried to clean the ICV again but couldn't get the damn screw clamp on the lower intake boot. I really dont want to buy another one since my upper intake boot was in great condition, but I can't imagine they would be that expensive. I think I may have to cut the lower intake boot to remove the screw clamps to access the ICV.
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 02-14-2013, 08:11 PM   #15988
My Ride: Lexus
Originally Posted by Solidjake View Post
Having fun tonight?
Drill baby drill! I just hope my drill has enough juice in it cause i can't find the charger i'm just going to do step 1 tonight--seam sealer. then tomorrow i'll jack up the car, tape the bottom and inject both cartridges in one hole. should be easy enough i hope..
You mean you can't access the clamp on the lower boot that wraps around the TB? Swiveling attachment will work wonders here w/ 1/4" ratchet
Old 02-14-2013, 08:33 PM   #15989
wildirish317
My Ride: 2004 325Ci vert
Where did you get that? That's a pretty low price.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-14-2013, 08:39 PM   #15990
trj
My Ride: 325Ci
# 4,5,6?
The only part I found on the top of the exhaust was number 4. The 5 and 6 must have dropped somewhere. Number 4 was the one resting on the top of the pipes and rattling.
And yah traffic lights at neutral and windows up. Don't want that embarrassment.
Old 02-14-2013, 08:44 PM   #15991
college46
Yes. Just tried swiveling attachment on my 1/4 inch ratchet. no dice. I can get any angle at the clamp. The screw head is facing the rear of the hood.
Old 02-14-2013, 09:11 PM   #15992
serdar255
My Ride: '01 325ci / '90 325i
Harbor freight, i have the same one. They are good quality!
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 02-14-2013, 09:12 PM   #15993
serdar255
Originally Posted by 330i ZHP View Post
Not for the E46, but:
Eisenmann installed - not much louder - I did drive around with no muffler and it sounded great - except a little drone
Old 02-14-2013, 10:38 PM   #15994
ryannel2003
My Ride: '04 Cadillac Deville
Ordered 8 quarts of BMW 5W-30 synthetic oil (at $6.78 per quart), new oil filter, and air filter for $70 shipped. Also ordred new Vanos line, ofhg, and 6 crush washers for $50. Going to tackle all of this on a warm weekend very soon.
ryannel2003 is offline   Reply With Quote
Old 02-15-2013, 01:09 AM   #15995
RKiepper
My Ride: 1999 E46 328I x2
Ordered all 6 coolant lines, both brake pad sensors, and a lower intake boot from FCP EURO.
That hurt my wallet a bit. Good thing I don't have to do this very often.
RKiepper is offline   Reply With Quote
Old 02-15-2013, 01:17 AM   #15996
tock172
My Ride: '12 135i DCT
$6.78 a quart? From where?
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 02-15-2013, 01:20 AM   #15997
My Ride: Lexus
just finished subframe. messy :/
Old 02-15-2013, 01:28 AM   #15998
The Thomas J
My Ride: 2002 325Cic
I've got that same noise. It's become quite annoying. I will deal with it shortly.
The Thomas J is offline   Reply With Quote
Old 02-15-2013, 08:00 AM   #15999
JZambrano7
My Ride: 2003 325xi
Mine rattles once I accelerate, what should I be looking out for?
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 02-15-2013, 09:18 AM   #16000
ryannel2003
eEuroparts.com. Cheapest I've seen around. They had the Mann oil filters for $4.78 too.
Rate This Thread
