Old 02-13-2013, 04:50 PM   #1
kraimer
My Ride: 04 330Ci, 00 323it
Send a message via AIM to kraimer
Rebuilding ZF 6speed Transmission
Has anyone attempted and successfully taken one apart and reassembled it?
[IMG][/IMG]
kraimer is offline   Reply With Quote
Old 02-16-2013, 01:48 AM   #2
wertyu78
My Ride: '04 ZHP
Looks.like.hell. I've never rebuilt a transmission, but I'd love to give it a go.
wertyu78 is offline   Reply With Quote
Old 02-16-2013, 03:43 AM   #3
bernie21614
My Ride: 01 330i
I've done a couple in lab setting and throwing it in on the trans dyno for testing once it was put back and everything came out good. To rebuild one you need the specs on the clearances once your clutch packs are installed it's not hard you just need the right tools.
bernie21614 is offline   Reply With Quote
Old 02-16-2013, 03:12 PM   #4
kraimer
My problem is after assembling the housings, I feel like 5th and 6th gears aren't engaging properly...5th gear feels like its engaged, but I am still able to rotate the output shaft and when engaging the 6th gear, it feels like there's no resistance at all at the output shaft...I've aligned the forks many different ways, and it still seems to give me the same results.
Could it be that I just don't have enough leverage to properly engage the 5th and 6th gears?
Also, I didn't take the gears apart, I replaced the input shaft bearing and now just trying to reassemble it back.
Old 02-19-2013, 05:23 PM   #5
bernie21614
My Ride: 01 330i
are you sure everything is seating right and the gear meshing correctly?
