Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#21 |
What is a guibo and CSB
I'm confused with the acronyms. Sorry Waiting for reply. Thanks |
#22 |
Weagle Weagle
The a guibo is a a rubber coupler that joins two shafts. There ins one on the drive shaft also called the drive shaft flex disk. The CSB is the driveshaft center support bearing. It holds the weight of the driveshaft near the middle of the car. It is a bearing fitted into a bracket with rubber. That rubber wears out and allows some play. A worn guibo can wear out the CSB and a worn CSB can wear a guibo.
#23 |
Damn, WDE46! You beat me to it
#24 |
Thank you
#25 |
Same exact symtoms. Transmission went 3 months later. It went on for a while. The vibration just gets heavier. Careful
Edit: I searched this problem for months! and everyone all said guibo or U-Joint Last edited by Nightmare5336; 02-04-2013 at 09:51 AM. |
#26 |
Hahaha how comforting. I think it is something with the wheel and tire assembly and the suspension components because the rumble followed the tires when I rotated them from the rear to the front. I'll find out in a week or so once I get the suspension replaced or when I have the balance on the tires checked again.
#27 |
UPDATE: Yesterday I had an appointment with my Indy shop to have my tranny fluid and filter changed. My Bimmer guy told me the fluid was nasty and had likely never been done. Happily, though, there were no signs of any kind of wear that was beyond normal use. He drove my car and told me that he felt the vibration I was talking about and told me that because of how it felt to him and the condition of the fluid when he took it out, he would suggest keeping an eye on it over the next couple days to watch if it changed at all with the new fluid in there. So, in the past two days I put about 50 more miles on the car to cycle the fluid around in the transmission and besides how much more awesome my transmission feels now, it does seem to have remedied the shudder/vibration. It is now mostly completely gone under normal driving and even under moderate and heavy acceleration it does not seem to be happening anymore. It's nice to be able to open her up again! So, I'll continue to keep an eye on it and keep you guys posted on whether this fix lasts and really solves the issue. I'm certainly hoping it does and it seems to have done it.
#28 |
Ugh... It's back. So it still seems to have this low frequency rumble around 25mph which gets worse when warm. Pretty annoyed
