Go Back   E46Fanatics > Everything Else > Other BMW Models
Other BMW Models
All other BMW model questions! For additional model specific forums check out bimmerfest.com!
Please post all E90/E91/E92/E93 and new M3 news at E90Fanatics.com
Old 02-17-2013, 11:13 PM   #1
louis10
My Ride: 330xi 2002 370000 Km
Towing boat with X5
Hi everyone, I looking for comments
I am thinking of buying a used X5 2006 to draw my boat (5500 pounds B & T).
The X5 is rated to pull 6000 pounds but the commercial hitches that I saw (class III) are rated 5000 pounds.
Would you know if the BMW Hitch part 71600009711 will allow me to draw up to the specified capability of the SUV.
What about the life of the transmission?
Any comment welcome. THANKS
louis10 is offline   Reply With Quote
Old 02-17-2013, 11:37 PM   #2
MCM97
My Ride: 01 325Ci
I had mine replaced under cpo warranty at 96k. You'll find the tranies are made by GM and not very stout
MCM97 is offline   Reply With Quote
Old 02-18-2013, 01:31 AM   #3
Andy2108
My Ride: E46M3E92M3'67Cobra
I wouldn't worry about the extra 500 pounds that isn't technically considered class III. The next class, Class IV, is rated for 10,000 pounds. BMW probably didn't want to deal with that on the X5.
The hitch for the car should work for whatever the car is rated to tow.
I wouldn't worry too much about the life of the transmission. A 2500 chevy might be a more reliable vehicle to tow with in the long term, but I somehow kind of doubt that you're cross shopping an x5 with a pick up truck. Change the automatic transmission fluid when you get the car and be happy. If you have to replace the transmission it really won't be the end of the world if you get a cheap used one and have an indy install it. The main failure on the GM transmissions have been a loss of reverse, but if I'm not mistaken the actual failure is just a solenoid and its replacement has been covered many times.
What is the tongue weight of your trailer? That's just as, if not more, important than the total weight.
Old 02-18-2013, 06:09 AM   #4
WDE46
Weagle Weagle
WDE46's Avatar
My Ride: 2004 330Ci OBM
I'm sure the X5 V8 version does not use the same transmission our cars use. GM makes great transmissions for trucks and whatnot, so I wouldn't be too concerned. Who knows if the X5 V8 is even a GM transmission though? Towing 5000 lbs with an X5 isn't going to be any fun at all though. I towed about the same with a 5.3L Chevy Tahoe. You'll get about 4 mpg haha.
Old 02-18-2013, 08:00 AM   #5
louis10
I estimate tongue weight to be 250 -500 lbs.
I use to tow the boat with a ford 150 5.4l triton and it would use as much gas as the boat!
Thanks you all for the comments. Louis
