Rating:
Display Modes |
#1 |
E46 is strong with this one
Let's Talk: Heating Blankets for E46
Hey guys; after having the cold come back after a week or two of decent weather, I have become inspired and driven to get a heating blanket for the E46. Let me start off by saying a couple things:
1) BMW did make a block heater; but after hours of searching, I'm pretty sure they are discontinued, or are basically non-existent. 2) I don't want a pad that "sticks" inside the oil pan, or on the outside...that seems dangerous for the car at first, and I don't want this thing to be on my car year round. 3)I have become interested in the actual heating blankets that you just drape on top of the engine when you need to, and then plug it in. Close the hood while heating. This seems great. Just take it out, heat it up, remove, and then go on my way. So what are my options? A quick search netted me a couple blankets from $250 up to $1,000, which is ridiculous. My price range is less than $200...ideally, around $100. Can anyone help out? I'd love to be the test subject and let everyone know how it goes. Thanks.
#2 |
Hmm seems like a lot of work for little gain. The car is designed to be started in cold weather, just let it warm up or be gentle until it is warm. I think a remote start system would be a better investment. 5-10 minutes before you want to leave, hit the button and she will be warm when you are ready to go.
#3 | |
There is no work at all. I buy it, it shows up to my door, and when it gets cold, I put on my car and warms engine and all the fluids to normal temp. Starting engine at 5 degrees is not "normal". It's bad for the bearings, and pretty much all the engine components. In a perfect world, engines run in temperatures of 72 degrees outside at all times. And remote start? This isn't a E90 M3. In our cars, they will stall out, if not run rough for at least 5 minutes. It's in the owner's manual to start driving right away after engine ignition. Sorry man, but that post has zero credibility. This is not a '72 Chevy. A lot of people can back me on this.
#4 |
Non existent? Maybe not:
http://www.ebay.com/itm/GENUINE-BMW-...3b87b9bb8#shId Although it is slightly more than your stated budget (after shipping), it's the correct part for the job. Luke |
#5 | |
#6 |
Op- you live in Pittsburgh, not the Yukon. You don't need this. Use a thinner oil and stop worrying.
#7 | |
And I'm very aware of the car stalling out. I have to keep my foot on the gas to stop my E46 from stalling out at a stop in the morning (but I thought doing the vanos seals would fix it). |
#8 | |
Luke |
#9 | |
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” |
#10 | |
#11 |
You have more problems than you're aware of. I'd get that sorted out asap.
#12 |
Idle that drops and bounces back every 10 seconds or so when motor is cold? I was under the impression that was vanos. But disa, IAC, CCV will be done soon too.
#13 |
You live in Pittsburgh. Just let it be. It doesn't get that cold there.
#14 | |
OP starts post asking for opinions, then argues with the ones he gets. <3 this forum.
#15 |
I mean you COULD just get a cheapo warming blanket that you would normally sleep under. I would imagine that it will keep the engine a tad bit warmer than without it. Certainly wouldn't cost you 200 bucks.
#16 |
In the cold what i usually do is, turn the key, the vehicle starts and idle for a few moments and then i fly away.
Its colder here in Toronto than where you are. You dont need a block heater or a blanket. |
#17 |
Agreed. It gets subzero here where I'm at in Ohio in the winter sometimes. Tdot is about 5 hours NORTH of where I am and if he doesn't need one, neither do you.
#18 | |
Have you thought about how much power would be required to overcome the thermal inefficiency of warming a blanket, then the layer of air between it and the motor (along with plastic engine cover, etc etc), and finally the block itself? How about the potential fire hazard? An electrical short if you close the hood on it the wrong way and shear the wire? |
#19 | |
no but seriously OP, i take my engine out, tuck it into bed at night, then when im ready to set off on a cold Chicago morning, i pop it back in and im on my way! no, but seriously, not hard feelings, but you dont need some silly blanket, as some have said, use thinner oil and dont drive hard until its warm.. i start my car in below 0 temps often and im fine |
#20 | |
| Tags |
| snuggie for bmws |
