Old 02-17-2013, 03:10 PM   #61
Dippinwandy
My Ride: 325i
Originally Posted by UDM-E46 Enthusiast View Post
A bad crankshaft sensor "can" cause bad idling and acceleration behavior. You can give that a shot.
But wouldn't that give out a code?
Dippinwandy is offline   Reply With Quote
Old 02-17-2013, 03:25 PM   #62
always-there
My Ride: 2002 BMW 330I
One thing that can really affect your vehicle can be the EGR valve. Please look into that part!
Old 02-17-2013, 03:44 PM   #63
always-there
Just a thought.
Old 02-17-2013, 03:54 PM   #64
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Sorry to hear about your problems. I hope you can figure it out.
Old 02-17-2013, 04:17 PM   #65
trentcdrums
My Ride: BMW 323i Sedan
Already replaced last month ,,
Old 02-17-2013, 04:32 PM   #66
always-there
And the EGR ?
Old 02-17-2013, 05:53 PM   #67
Dippinwandy
My Ride: 325i
And the EGR ?
What is the EGR valve?
Old 02-17-2013, 05:56 PM   #68
driftingSOCALE46
My Ride: 2002 325i
The title states it. I have cleaned my throttle body, ICV, replaced intake boots and cleaned, changed spark plugs. The dealership said the reason this was last time was because I had a bad valve cover. So I spent $500 on that replacement and it was great for months. Now it's doing it again.
I am drumming a huge youth retreat 2 hours away and had to pull over "12" times because the car wouldn't let me go over 45 mph! So I turn the car off and on again. The cel stays on but the eml and traction lights are off. Every stop sign I approach, the lights comes back!
I know there are multiple threads on this. But I am wondering if maybe y throttle body is done for or my icv.
Here are the codes.
P1510 -ICV STUVK
is ur car, stalling and the engine shuts off? and then the battery light and oil light pop on
driftingSOCALE46 is offline   Reply With Quote
Old 02-17-2013, 07:42 PM   #69
trentcdrums
No batterry and oil light
Old 02-17-2013, 08:26 PM   #70
trentcdrums
And the EGR ?
I'll look into that!! Looks like it'll take a little time to remove.
Old 02-18-2013, 06:15 PM   #71
trentcdrums
Another question, some people may say that the throttle body would be in bad shape, but if I have not received any codes on my tool then I should be fine, correct? That is what I was thinking. The only code that I have got really is for the idle control valve.
Old 02-19-2013, 11:44 AM   #72
trentcdrums
Anyone?
Old 02-19-2013, 04:57 PM   #73
wildirish317
My Ride: 2004 325Ci vert
Try this link: http://www.bmwtech.ru/pdf/e46/ST034/...Internet-1.pdf
I think everyone lost interest when you made the statement about the EGR valve. (If you find it, post a pic. To my knowledge (and per the link) EGR is accomplished internally via the VANOS.)
Good luck!
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-19-2013, 05:44 PM   #74
03E40sick
My Ride: 2003 bmw 325ci
Send a message via Yahoo to 03E40sick
I'm still having the same problem
bimmers is the way to go........
03E40sick is offline   Reply With Quote
Old 02-19-2013, 08:05 PM   #75
trentcdrums
Gah, i hope this ICV swap will FIX IT ALL.
Old 02-19-2013, 08:46 PM   #76
college46
My Ride: Alpine White
before buying a new icv, you should remove and clean your old one. It may help your problem.
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 02-19-2013, 08:52 PM   #77
trentcdrums
As stated in the very first post, I have done that four times are ready.
Old 02-19-2013, 09:13 PM   #78
college46
I think that if your ICV is getting stuck open, it would be from something clogging it. I also read the first post but interpreted it as being cleaned "months ago." You never know. After reading page 2, dumb comment.
Your o2 sensors also can get deposits from a stuck icv which may be contributing to your problems. I would bet on ICV or the throttle position sensor.
Best of luck
Old 02-19-2013, 10:32 PM   #79
trentcdrums
Best of luck
But shouldn't I follow what my codes are reading? Especially if every code I am getting after my check engine light comes on, is my idle control valve sticking.
Old 02-20-2013, 02:44 PM   #80
DylanFulton7
My Ride: Audi S4
Maybe I get lucky... I had the EXACT same problem, I replaced my mass airflow sensor and my fuel filter. I only replaced them because I had the parts sitting around and figured I'd give it a shot. After I replaced them the problems immediately stopped. Again, maybe I just got lucky but for what it's worth it seemed to solve my problem...
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you."
- Jeremy Clarkson
Supercharged 328Ci - SOLD
C32 AMG - SOLD
E53 X5 - SOLD
545i/6 - SOLD
DylanFulton7 is offline   Reply With Quote
