Rating:
#16141 |
/// Power
I got bored of the blacked out and redded it out instead.. Thanks tho broski..
#16142 |
Creative... Matches the lisence plate.. Thought it looked very gangsta lol
#16143 |
Painted my nasty chipped cup holders.
#16144 |
Replaced thermostat. Used aftermarket cast metal one. Shall see if any differance. From my observations of the old one still on engine, looking from under car, leak appeared to come from bottom bolt area. Thought maybe a crack. Upon removing and inspecting the old one it was actually leaking from the center portion where the electrical stuff is. Not the outer seal as speculated. O ring inside electrical connector bad. Not something to repair.
#16145 |
Just finished VCG... obligatory pic included...
#16146 |
My Ride: E46 325Xi & E92 335i
Photo of it installed?
Is the rest of the interior tan? |
#16147 |
Hopefully not a Victor Reinz Gasket.
#16148 |
nope, did lots of reading here first... went with Goetz... 60k miles btw, oil changes every 5k (and, yes, i know now that a longer interval is preferred and have switched to 7500)
gaskets were stiff, plasticized in some spots... lot of condensate on inside of vc as well, too many short trips in car... needs a good long drive |
#16149 |
Headers just came!!
I filled her up too.
![]() Want a handmade shift knob or custom vinyl stickers? PM me I'm sixteen and like cars with three pedals. My ever small company... www.facebook.com/StgFabricationAndMolds |
#16150 |
Headers just came!!
#16151 |
Sunroof repair in progress
#16152 |
Modded ///Member
Had a guy buff the car this past weekend. Looks good, except he didn't use swirl remover for all the marks. Fail. So I had to buy Meguiars Swirl X and do it myself and the results are much better.
#16153 |
Struts, sway bar bushings, end links=like new ride again....
#16154 |
That's what I like to hear!!
#16155 |
Mod
My VR gasket is leaking after a few months. Getting swapped to an Erling gasket tomorrow.
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 Pics from post 505 on! ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#16156 | |
Replacing mine within a few weeks...its been long enough. |
#16157 |
Jake I did the same. Now the elring is leaking in two months. I am going goetze or whatever is OE soon.
#16158 |
How, or rather in what pattern did you torque the studs?
#16159 |
Modded ///Member
Pretty sure my VR gasket is leaking again too. Staring to smell some oil from the car when I park it.
#16160 |
Grand Superpatriot
I highly recommend GENUINE BMW ONLY on VCG. It's not that much from the dealer. I had 3 VRs go out in a row. Now using BMW and dry as a bone on the desert floor in the middle of summer!!!!
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
| Rate This Thread | |
