Sponsored by BimmerWorld
Old 11-11-2010, 01:26 PM   #1
My Ride: Lexus
Installing Bilstein Sport Struts this weekend: One question...
I've got a question first, is the lower part of the front strut supposed to stick out past the bottom of the hub? Or does it stop and line up flush with the bottom of where it slides into? I've seen debate in the past but wanted to do this correctly. If anyone knows for sure, let me know.
Oh and can someone explain the L and R marks on the strut? I know it means to line up the L or R depending on which side you're installing... but if the struts are different for L and R anyway, why would each strut have a need for L and R markings? Right strut can only go on the right and therefore should have only ONE mark saying line up pinch bolt HERE. Am I understanding this wrong?
Old 11-11-2010, 02:28 PM   #2
323iINt.o
My Ride: 328i
The strut has a notch in the bottom of it. Slide it up as far as possible.
NEED SMOKED CORNERS AND MARKERS, PM ME IF YOU GOT SOME!
323iINt.o is offline   Reply With Quote
Old 11-11-2010, 09:56 PM   #3
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
WARNING IF YOU HAVE HID's
Unbolt the level sensor connector on the front lower control arm on the passenger side when you drop that strut. If you don't there is a high probability that your strut replacement will cost an additional $100. Don't ask me how I know.
/// MODS
Old 11-11-2010, 10:04 PM   #4
Another BM
My Ride: 330ci
Originally Posted by titaniumcranium View Post
warning if you have hid's
unbolt the level sensor connector on the front lower control arm on the passenger side when you drop that strut. If you don't there is a high probability that your strut replacement will cost an additional $100. Don't ask me how i know.
+1
lol
Another BM is offline   Reply With Quote
Old 11-11-2010, 10:56 PM   #5
lejeunebimmer
My Ride: 02' M3 SMG, 02' 330i
They sit pretty much flush, because of the way they're designed. +1 as to leveling sensor.
Don't think too much into the L&R on the stuts once you start putting them on, it'll be qutie obvious as to how they go!
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF Splitters
M3 - Not enough room to list
lejeunebimmer is offline   Reply With Quote
Old 11-12-2010, 07:48 AM   #6
franz
My Ride: 03 330i
They may have changed designs but mine definitely sat about 2" below the hub mounting. If there is a smaller diameter near the bottom that's how it works, if not and it's all one diameter then they just go in almost to the bottom.
franz is offline   Reply With Quote
Old 02-18-2013, 02:19 PM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
So, I need new struts...ordered Bilstein touring...and just finished reading some posts about them lifting the front up too high...so wondering if I have a choice of some slightly shorter struts. Is the HD lower...think there's a Bilstein Sport too.
Finally, Mango, how you liking your struts? I had Sachs...blew after 3 years. tsk!
Anyway, getting to this soon (love the Meyle HD CABs btw...go nicely with Lem CAs!).
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-18-2013, 03:43 PM   #8
college46
My Ride: Alpine White
Bilstein HD's and Sports have the exact same valve length. And Touring has longer valve length than Hd's. Hd's are optimized for stock ride height and sports are for aftermarket springs. I had "Comforts" on a previous car and they are closest to non sport oem sachs.
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 02-19-2013, 04:52 PM   #9
dmax
dmax's Avatar
Thanks, College!
Are these 'comforts' you speak of a fourth Bilstein model, or is that another term for 'touring'?
I'll get them tomorrow I think...guess I'll find out what I got then!
Mangofy your E46!
Old 02-19-2013, 04:58 PM   #10
My Ride: Lexus
I love my sports. ride is extremely planted and secure under any condition. Gotta love monotube high pressure Bilsteins
From tire rack:
For the enthusiast driver who demands superior handling, the Bilstein Sport shocks and struts deliver the highest levels of control. An excellent match for vehicles with lowering springs or upgraded anti-roll bars, the Sport Series shocks and struts perform under demanding conditions.
The Bilstein Principle
All Bilstein gas pressure struts/inserts and gas pressure shock absorbers operate on the same principle. They are manufactured with the rod pointing down into the strut tube, thereby utilizing the thicker, stouter body portion of the shock absorber to dissipate side loads. Consequently, due to the increased diameter and surface of the pressure tube, the Bilstein gas pressure strut/insert or shock is better suited to take increased side loads when compared with the conventional version.
Additional advantages, based on development strongly influenced by the motorsport industry, include greater stability, better road handling, and accurate steering. This combined with extremely high quality manufacturing and materials, means Bilsteins will last approximately four times as long as Original Equipment.
Battling Heat Build Up
Conventional shocks trap the heat within the shock body and prevent adequate dissipation, making them prone to heat build up, fade and eventual failure.
Bilstein's patented design allows the excessive heat from the oil to transfer to the outer surface of the shock body and dissipate more efficiently. The dividing piston also permits the oil to expand as heat builds, preventing aeration (foaming) and viscosity loss. This allows the shock to maintain full damping characteristics as temperatures rise.
The tube of a Bilstein gas pressure shock or strut is fabricated using a special extrusion method. This process achieves an extremely tight peak-to-valley tolerance and maintains consistent wall thickness. Bilstein's seamless monotube design provides superior tube strength while maximizing heat dissipation and shock life.
Ride Comfort and Performance Without Compromise
The piston head design allows independent tuning of the compression and rebound damping forces to provide optimum ride comfort and performance without compromise. It features fewer parts than most conventional designs. The product's simple, yet exceptionally functional digressive design contributes to the extreme durability and long life of Bilstein Shock Absorbers.
Better Built
Bilstein's shock bodies are precision formed through a unique seamless extrusion process. This provides superior strength along with high finish tolerances. The shock body is then treated with a special paint finish durable enough to withstand grueling 240-hour salt spray tests. The finished body is mated with a solid, induction-hardened steel chrome plated and polished shaft, machined valving components and highest quality seals.
Bilstein products are backed by an aftermarket lifetime warranty.
Old 02-19-2013, 05:16 PM   #11
///MPR77
My Ride: 02 ///M3 Tri-Ped
My bilstein touring struts do protrude below the bottom of the knuckle.
I had to use a jack under the control arm, and sprayed a bit of lube. (Loctite silicone spray) on the bottom of the strut...jacked it up and it sunk right in.
Sent from my SCH-R530M using Bimmer App
Old 02-19-2013, 10:43 PM   #12
ryannel2003
My Ride: '04 Cadillac Deville
^This. I didn't do this and one side of the car sat up higher than the other side .
It's fine now and the height isn't that much different than the OEM suspension, though it doesn't bother me anyway.
ryannel2003 is offline   Reply With Quote
