Old 02-21-2013, 09:36 AM   #21
Surrept
My Ride: 2002 330ci
Yeah the screw heads on them are usually facing to the bottom of the vehicle. I recommend switching them around once you get them off and have them facing up so if you have to remove them again it's much easier.
Surrept is offline   Reply With Quote
Old 02-21-2013, 10:22 AM   #22
petemo94
My Ride: 2004 325CiC
Originally Posted by BlackenWkN View Post
... and I'm guessing the whistling noise I have going on right now( which is at random times mostly idling or accelerating a little bit) I'm assuming its the boot so that will get looked at as well
So I too have this "whistling noise". To me it sounds like a pulley going bad, but its [1] NOT coming from the pulley area but near the DISA area (which I checked out and things look great) [2] I've replaced all of the pulleys, belts, hoses, WP, ET, OFHG, recently the CCV and hoses, oil-dipstick o-ring, ICV gasket & cleaning, TB gasket & cleaning, replaced both intake bellows.
I still have the noise. So all thats left is a random vacuum line that snakes under the intake manifold (which all looked fine during my CCV replacement) or the alternator bearings are starting to wear down.
My noise too appears at idle and disappears when under throttle. Seems to be louder in colder temperatures.
Let us know if you find it. Will do the same.
Regards,
PeteMo94
2004 325Cic, ZSP, ZPP, ZCW, Owned since 12/1/12
///M3 Floor Mats - Power under my feet!
petemo94 is offline   Reply With Quote
Old 02-21-2013, 10:47 AM   #23
My Ride: Lexus
Thanks guys for recommending those links cause I did write them for people like the OP. It's frustrating when people dismiss it as a waste of money but they don't realize that when people follow the basics I laid out, they have no problems.
Do what you want with the advice but trust me, it all needs to be done at some point. You can't just buy these cars for the badge and not take the responsibility that comes with it. It's a precision machine that needs plenty of servicing to run properly
Old 02-21-2013, 12:23 PM   #24
Surrept
My Ride: 2002 330ci
No one dismissed anything. I agree I've done pretty much all of those things. But some don't need to be done immediately after purchase. Thats just common sense. Every vehicle is different with different maintenance history.
Old 02-21-2013, 12:24 PM   #25
Surrept
My Ride: 2002 330ci
And I wouldn't call throwing money at things that don't need replacing "responsible".
Old 02-21-2013, 12:33 PM   #26
My Ride: Lexus
Unless you have receipts or date stamps on the parts, assume it hasn't be done. It's a BMW, not a hot dog stand. Take some responsibility
Old 02-21-2013, 01:10 PM   #27
Patton323I
My Ride: R1100GS E46 E53
But what if my car does shoot hot dogs out the tail pipe????
Patton323I is offline   Reply With Quote
Old 02-21-2013, 01:12 PM   #28
Surrept
My Ride: 2002 330ci
You don't need a service record to know if your oil housing gasket is leaking, you dont need a service record to tell you if your final stage resistor is working, you dont need service records to tell you if your alternator is working or not, and you don't ****in need a service record to tell you that your disa is working properly or not. It's not a matter of responsibility to the vehicle its a matter of common sense and using your eyes/ears.
Old 02-21-2013, 01:15 PM   #29
My Ride: Lexus
Oil filter housing gasket is $5. You do it while you're in there cleaning the TB/ICV/etc.
I've never replaced my DISA, but I've cleaned, inspected, and re-sealed it.
See quote in my sig re: owning a cat.
Old 02-21-2013, 01:17 PM   #30
Patton323I
Its called preventative maintenance tiger. The part isn't going to shout at you right before it fails. And parts on these cars have a tendency to break without expectation. So in replacing them before they fail, you eliminate the chance of the part failing.
Old 02-21-2013, 01:20 PM   #31
My Ride: Lexus
that's exactly right. everything is "still good" until it breaks. just ask the guy whose old/dry rotted tires that failed on the freeway. His tires were "still good."
Old 02-21-2013, 01:26 PM   #32
tks
My Ride: slower than yours
stop replacing parts and replace entire vehicle before something else breaks
^ mango mentality
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 02-21-2013, 01:28 PM   #33
My Ride: Lexus
^ mango mentality
like i said, my guides are just the basics. that's nowhere near "the entire car"
and no, it's the mentality of the majority of the forum.
people like hoebama, goingnuts, mercforhire would tend to agree with you.
Old 02-21-2013, 01:32 PM   #34
ryannel2003
My Ride: '04 Cadillac Deville
First thing: go to club, find bitches, tell those bitches you own a BMW and smash. /theend
No, but really just follow Mango's guides and your car will be good as new.
ryannel2003 is offline   Reply With Quote
Old 02-21-2013, 01:40 PM   #35
Patton323I
^ mango mentality
Wow dude... Its not hard work to perform, nor is it expensive. So... whats the issue?
Old 02-21-2013, 01:42 PM   #36
My Ride: Lexus
I think you just said what the issue is.
It's fine--not everyone is rich (including myself) but when people pretend that is NOT the issue, that's when I.. take issue.
Old 02-21-2013, 02:10 PM   #37
Surrept
My Ride: 2002 330ci
Leaking oil housing gasket wont strand you, nor will a failing disa, and nor will a faulty fsr...Preventative is important if it prevents you from driving, otherwise its a waste. Tires obviously are different considering they put your life in danger. The only thing id be willing to agree on possibly is the voltage regulator but considering I went through 3 on my last e46 in a matter of 4 years, I wouldn't trust new/rebuilt over what I was currently using.
Old 02-21-2013, 02:15 PM   #38
My Ride: Lexus
FSR has been known to drain batteries. it will leave you stranded. not everything on my list can leave you stranded--that's not why you do them. you do them so your car will run at peak performance. it's nice to drive a nice car. very nice
Old 02-21-2013, 04:15 PM   #39
Surrept
My Ride: 2002 330ci
My RAM in my motherboard could fail too, and it's fairly cheap to replace. Why don't I replace that? Cause it doesn't f'n need replacing. A lot of things in life COULD fail, but if it ain't broke, don't fix it. It's a god damn BMW and the idea that somehow it's the holy grail of cars and all parts should be replaced every so often to maintain it is ridiculous. I'm a fanatic, but not to the point of stupidity. Your working FSR might give you 3 more years before starting to show signs of failure, why on earth would you replace it. Same goes for all the other stuff.
Old 02-21-2013, 04:19 PM   #40
My Ride: Lexus
RAM doesn't have a track record for failing. You can produce all the obscure ridiculous scenarios you want, but truth is you are the clear minority here and absolutely do not know what you are talking about.
I will say nothing more on this
