Old 02-20-2013, 02:38 PM   #1
clwolf
My Ride: 2003 325xi
I'm stupid. Where exactly is the tensioner?
I'm trying to remove my alternator but can't figure out which bolt releases the tensioner.
Attached is a pic.
Is it the 16mm attached to the alternator, or the one below the belt on bottom of pic which is 13mm? Or something completely different?
Sorry, it's 10degrees outside and I am probably just being dumb. Thanks
clwolf is offline   Reply With Quote
Old 02-20-2013, 02:39 PM   #2
clwolf
My Ride: 2003 325xi
ack, somehow [oc flipped upside down.
so bolt in middle of alternator area, or bolt on the very top. Tried putting arrows on them as well.
Old 02-20-2013, 03:52 PM   #3
e46crooser
My Ride: 99 328 5spd
Depends on whether you have the mechanical tensioner or hydraulic (shock) style tensioner.
-The higher 16mm bolt head located above the alternator (deflection pulley bolt) holds the top part of alternator in. Further down you'll see either a 16mm bolt on the mechanical tensioner to release tension on drive belt. If you have a shock style tensioner then you'll remove the cover off the pulley and use the 8mm allen on the pulley to release the tension.
HTH
e46crooser is offline   Reply With Quote
Old 02-20-2013, 04:06 PM   #4
clwolf
My Ride: 2003 325xi
so no where on the pic?
Old 02-20-2013, 04:14 PM   #5
tks
My Ride: slower than yours
it's starting to come into the picture at the right, but no. more on the bottom, the belt wraps around it just search a little harder
it could either be a torx 25 iirc if you have sedan (i am guessing but have seen it done & unsure of the size) , or an 8mm hex bolt (what i have in my coupe)
make sure you go slowly or you will mess up the threads when untensioning it!!
so anyways, two possibilities
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 02-20-2013, 04:17 PM   #6
clwolf
My Ride: 2003 325xi
Ok. Yes, I have a sedan. 325xi. 2003.
I"m gonna try and take another pic.
Old 02-20-2013, 05:23 PM   #7
clwolf
My Ride: 2003 325xi
do these help?
I'm so confused and it is probably staring right at me.
Name:	2013-02-20 16.07.36.jpg
ID:	491640   Click image for larger version
Name:	2013-02-20 16.07.47.jpg
ID:	491641   Click image for larger version
Name:	2013-02-20 16.07.53.jpg
ID:	491642   Click image for larger version
Name:	2013-02-20 16.08.09.jpg
Old 02-20-2013, 05:35 PM   #8
tks
pop the cover off of the pulley in the second picture
Old 02-20-2013, 05:36 PM   #9
clwolf
My Ride: 2003 325xi
so I popped the wrong cover off! Got it. Thanks so much!
Old 02-20-2013, 05:36 PM   #10
tks
here's mine 02 330ci finger pointing at it
i know it's dark looking but go take a look at yours again!
Old 02-20-2013, 05:43 PM   #11
clwolf
My Ride: 2003 325xi
Perfect. Thanks. You leave your covers off all the time?
Old 02-20-2013, 06:18 PM   #12
clwolf
My Ride: 2003 325xi
I think I found it. Now what size? I have torx sockets, but I don't have allen sockets. If it's allen I will need to go to a store and buy it.
Thanks again!
Name:	2013-02-20 17.06.09.jpg
Old 02-21-2013, 04:08 PM   #13
clwolf
My Ride: 2003 325xi
8mm allen?
Old 02-21-2013, 04:36 PM   #14
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You can get a set of allen bits at harbor freight for maybe $10-20 tops...get all the ones you might need. I'm glad you took photo...many assume it's what they're told here and end up using a hex in a torx screw or vice versa and strip it.
8 looks about right...but don't forget there's always a chance someone used an aftermarket screw that takes a different size. Always check...stick it in by hand...if it wobbles, go the next size up...it'll either fit nicely or not. Be careful...if say, you used a 7, you might get it to turn, but you might also strip is. Trust your feel and check every bolt/nut for size yourself. You'll probably run into exceptions in a few spots along your DIY career.
Oh, and my 14" 1/2" breaker bar is perfect for the tensioner...if you get a 3/8" bit set, you can get an adaptor to go from 1/2" to 3/8" and use that larger breaker bar on a lot of tough to loosen bolts/nuts.
HTH
Facebook.com/DMAXstandup
Mangofy your E46!
dmax is online now   Reply With Quote
Old 02-21-2013, 04:40 PM   #15
clwolf
My Ride: 2003 325xi
Good idea on the adaptor. I have a 1/2 breaker bar that would be perfect as well.
Yeah, I have replaced at least a dozen alternators in my life, and have never had such a hard time. Must be my old age!
Old 02-21-2013, 07:36 PM   #16
tks
I had a problem with mine the first time too, exactly as you put it and I actually was tightening (thinking the pulley was stuck) the bolt above... then I realised it was the 8mm allen underneath it haha.
Hope it went well for you and now you can do it easier for next time :p
Old 03-02-2013, 12:42 PM   #17
clwolf
My Ride: 2003 325xi
Finally life got out of the way and I was able to work on my car.
Took belt off alternator in less than 10 seconds. Amazing when you have the right tools and actually using them in the right place how things work! Thanks ruskisky and dmax!
