Sponsored by BimmerWorld
Old 02-20-2013, 07:43 PM   #61
123Shift
My Ride: 2001 325i
Mjlavelle- thanks for the info. I didn't think to read the reviews. I'll check them out. I'm lucky enough to have a harbor freight store about 15 min away. Hope it works!
123Shift is offline   Reply With Quote
Old 02-21-2013, 06:41 PM   #62
tech4tech
My Ride: 2004 325i
Originally Posted by 123Shift View Post
For ball joint separation don't use the pickle fork. This is what you want, and it makes the job stress-free:
http://www.harborfreight.com/3-4-qua...tor-99849.html
Tech4Tech- The link to the ball joint separator says its for front wheel drive vehicles. It works on the e46 too?
Yes
tech4tech is offline   Reply With Quote
Old 02-21-2013, 10:10 PM   #63
123Shift
My Ride: 2001 325i
Alright- I got the ball joint separator and it worked great for the outer ball joints. Don't see how it would work on the inner joints though. Luckily after I got the outers to pop, a quick couple of whacks with a hammer popped the inners and the arms dropped out. Now I have a question. Since you can't get a socket on the inner ball joints how do I torque it to spec? I got the outers and the lollipops but the inners are another story. Any help?
Old 02-21-2013, 11:18 PM   #64
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If you apply 1 pound of force, 1 ft. away from the nut/bolt (using a foot long wrench)...that's 1 ft-lb.
If your wrench is 6" long, that same force equals 1/2 ft-lb.
I don't know the torque setting, but if it's 50 ft-lb and your pushing on a foot long wrench, you'd make it very tight. Imagine the force of a bag of concrete.
I think of torque as tight, really tight, and crazy tight.
Make it tight...I don't think you can make it too tight...it'll be just a few degrees you'll be turning with each pass.
Know what torque means and get as close as you can. But you want it really tight. I think it's a 21mm nut...it takes a lot of force...you won't break it.
HTH (now I'm going to get yelled at. Just watch!)
See me in NYC in May!
Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m.
dmax on Facebook
Mangofy your E46!
Old 02-22-2013, 02:44 AM   #65
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Or you could get a 50' handle and just apply 1lb of force!
/// MODS
