Thread Tools Search this Thread Rating: Thread Rating: 71 votes, 5.00 average. Display Modes
Old 04-04-2012, 06:00 PM   #201
Bimmer_Addict
My Ride: E46 323i
So I previously had the SES in due to a miss fire on cylinder 5 I reset using the paper clip 9 seconds and it worked. I had my valve cover gasket changed yesterday an every thing was fine till this morning car is fine running great, I stopped at the store and when I came back to start the car I found my A/C on "frost button light" which wasn't on before I made that stop. Tried this method again and I have no luck. Would changing the valve cover gasket has any thing to do with this?
00 E46 323I current
08 Jeep Grand Cherokee Laredo current
08 E60 535I LEASE OVER
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
Bimmer_Addict is offline   Reply With Quote
Old 07-07-2012, 07:43 PM   #202
warrenn
My Ride: 323
I have a '99 328i and it finally worked after several tries. As other people have said, you must short it for exactly 3 seconds. It wasn't working for me because I was just counting to 3 or doing 1-mississippi, etc. I guess my counting wasn't accurate enough. Finally I took a stopwatch and held the clip in for exactly 3 seconds and it worked!! Thanks.
warrenn is offline   Reply With Quote
Old 07-19-2012, 06:21 AM   #203
GaryGG
My Ride: BMW 330Xi & 740i
This is a process I pulled from a video I found on another website. I haven't tried it yet but I'm changing oil later today and I'll give it a try after that...
"After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, EMD SIA should show up for a few seconds. All Done "
It sounds pretty simple and certainly beats a couple of hundred bucks for some fancy test module!
Gary Goodlund, "GaryGG"
Sebastopol, CA
330Xi & 740i
gggbiz@hotmail. com
GaryGG is offline   Reply With Quote
Old 07-23-2012, 03:30 PM   #204
Usmc1028
My Ride: 1999 BMW 328i
After trying it different ways it finally worked 1999 328i build date 09/1998
Heres how i did it:
1: Take the cap off The DLC.
2: Turn key to position 2.
3: Shut the driver side door.
4: Ground pin 7 to the ground stud for 3-5 sec ( its a short window so make sure you use a stopwatch)
5: Replace the DLC cap.
6: Turn the ignition to off then back to position 2, and bamm it should work.
Of course many other people have tried it the regular way and it worked for them, but it just didn't work for me. So i had to figure out a different way to do it.
Good luck!
Usmc1028 is offline   Reply With Quote
Old 08-27-2012, 04:00 PM   #205
jwebb
My Ride: 325i
Any difference for newer models
Will this work for a 04? Or does anyone know if there is a topic on resetting the oil service?
Pete
04-BMW 325i lady's car
69-Chevy C/10 my project
97-Ford Ranger ridin on 35's
jwebb is offline   Reply With Quote
Old 08-27-2012, 04:11 PM   #206
jwebb
My Ride: 325i
OK, I read back a few pages and I'm gonna try when I change my oil.... Always seem to get the answer
Pete
Old 11-09-2012, 04:56 PM   #207
jakksfor20
My Ride: ZHP,Slow 323ci
One thing that I don't think was mentioned in this. I had a hard time doing it today. I tried every which of grounding the pins, grounding the pins together to ground with a piece of wire. I then tried the paper clip every which way again. I finally got it to work by pushing the paper clip in ALL the way in on pin 7 and 19. No need to ground them to ground for me.
jakksfor20 is offline   Reply With Quote
Old 02-21-2013, 11:52 AM   #208
tamb
My Ride: 323i se
A can't get my 323 1999 to do it help lol
tamb is offline   Reply With Quote
Old 02-21-2013, 03:21 PM   #209
markusmarkus
My Ride: 2001 330Ci
BTW, the connector is an OBDII connector! The connector changed for the 2001 MY.
Old 02-22-2013, 03:40 AM   #210
tamb
My Ride: 323i se
yes its obd11
Old 06-08-2013, 09:40 AM   #211
Dan46
My Ride: E46 323ci msport
DOSENT work on my 04/99 323ci uk car tried both methods neither work what are you suppose to do
once you have counted to 3 put cap back on or turn key back then put cap back on?????
Dan46 is offline   Reply With Quote
Old 06-08-2013, 10:44 AM   #212
Dan46
It worked pin 7 to strut as ground bolt no 19 pin ignition on cap off ground 7 cap on ignition off then back on bingo!!!!
Old 09-27-2013, 06:30 PM   #213
nclubine
I have a '99 328i. I tried the paperclip ground between pin 7 and pin 19 with the key in position 2 but it didn't work. After waiting for 3 seconds and pulling the paperclip out I went to look at the dash and it was flashing the oil inspection milage a few times but then goes away without resetting. Ideas?
I also tried grounding pin 7 to the bolt next to the DLC connector but also with no result.
nclubine is offline   Reply With Quote
Old 12-20-2013, 06:40 AM   #214
ChuckyVee
My Ride: 2000 323i, '99 328is
I know this is an old thread but I just wanted to post up my experience with resetting the oil service light....my first post too by the way!
I'm the proud owner of a new to me 2000 323i...bought it a couple weeks ago and it has a build date of 04/2000.
Anyway, before I tried the paper clip reset trick I went and tried the left button gauge cluster reset procudure. Low and behold it worked like a charm!
Like others though, the display went from showing miles to the next oil service to now showing miles to the next Inspection (15xxx). I think I figured this out. Since BMW recommends 15K miles between oil changes and I believe 30K miles between Inspection I and II (which include an oil change), the Oil Service and Inspection light will alternate between every other reset. If you reset it when it showed "oil service" it will show miles to the next inspection. If you reset it when it showed miles to "inspection", it will then show miles to the next "oil service".
Personally, I'm going to change my oil every 7500 miles so I will end up doing 2 oil changes between inspections.
ChuckyVee is offline   Reply With Quote
Old 01-22-2014, 08:48 AM   #215
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
Reset oil service light BMW E46. From years: 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006.
How do you reset oil for BMW service light BMW E46.
Turn key switch ON or when start engine. The instrument panel will display OIL Service or INSPECTION and left distance for several seconds
[COLOR=black]If Service or INSPECTION are lit all the time and the left distance is next to 0? it indicates that it needs oil service reset.
Reset by manual.
  1. Press RESET button in the left of instrument panel.
  2. Turn key ON and to ACC position.
  3. Waiting for the instrument displays OIL Service or INSPECTION is flashed.
  4. Release RESET button, then press five seconds, the screen will display RESR or RE is flashed.
Release RESET button again and press again till the screen displays 25000km.
Now reset of a oil service light on a BMW E46 is completed.
When you find there is bar symbol in front of the left distance number in the screen, and you can.
That it is the full procedure how to reset oil service light BMW E46. If you like to reset any maintenance oil light after an oil change. Or reset check engine light, airbag light, inspection key or insp errors when maint reqd, for BMW cars. Or any error which appears on the display. Write in the search box the car name for which you want to find information, and find how to reset other service reminders when by yourself.
This is an information site where you can solve your car problems.
Eurobahn BMW MMINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro NC dealership.
Eurobahn BMW is offline   Reply With Quote
Old 02-14-2014, 09:31 PM   #216
Boondockz
My Ride: 1999 323i
Excellent, worked perfectly the first time. Thanks a million!
Boondockz is offline   Reply With Quote
Old 03-04-2014, 09:23 AM   #217
ndi7
My Ride: 1999 BMW 318i (E64)
Originally Posted by darkmanlfe View Post
This applies to earlier e46 models. eg. 99-00 with OBCI.
1. Locate the 20-PIN DLC Connector. It is located under the hood, passenger side empty compartment.
It looks like this.
2. Turn the key to position 2. key position before the engine start.
3. For OIL RESET, just ground PIN 7 and PIN 19 for 3 seconds.
4. For ENGINE SERVICE light, ground PIN 7 and PIN 19 for 9 seconds.
Yeah ! I have just reset mine; many thanks my dear friend. Make sure it is exactly 3 seconds (I used a stop watch; pls note: it failed when i tried 5, 6 and 7 secs). I turned the key to position 2 (just before starting the car), i got out and connected Pin 7 to negative terminal of my battery and press my stop watch at the same time, i pulled off exactly at 3 second; i got into the car turned it off and then to position 2 again and it said 25,000 inspection ... [by the way i used a piece of cat5 network cable( one of the twisted pairs) ]
Last edited by ndi7; 03-04-2014 at 09:31 AM. Reason: adding a word of advice to help others
ndi7 is offline   Reply With Quote
Old 03-04-2014, 10:25 AM   #218
Boondockz
My Ride: 1999 323i
delete
If you feel comfortable while your driving, your going too slow.
Old 03-06-2014, 07:01 PM   #219
Boondockz
My Ride: 1999 323i
Hey, I got the oil reset just fine. Currently I am trying to clear the codes I recently acquired, I have tryed many many times and am wondering if the SES is different from a check engine light?
I just don't want to keep trying if the CEL needs a scan tool to reset. I know what it was and its fixed...
Old 08-29-2014, 05:08 PM   #220
asiangear
My Ride: 323 2000 Ci
Can the service/oil indicator be reset before the remaining miles hit 0? I did an oil change when there is still 1500 mi left. I tried the paper clip method (which previously worked on my car) and it doesn't reset.
USC Internet: We are the 1%, in lightning-fast porn download (Brazzers at the speed of light)
asiangear is offline   Reply With Quote
