Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum by BimmerWorld
From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast
Sponsored by BimmerWorld
Old 05-10-2011, 04:30 PM   #81
RoadRace330
My Ride: 2010 Jetta Tdi
You must reinforce the strut attachement point in the trunk if you do so. No real benefit other than the extra adjustments and ease to replace coils. You will also run a much lower spring rate if you run true coil over.
I think it's a little overkill for street/track car.
RoadRace330
RoadRace330 is offline   Reply With Quote
Old 05-10-2011, 04:32 PM   #82
FTWeisse
My Ride: has no hip-hop rimz
Originally Posted by ///Mspired View Post
what are the benefits of a true coilover system in the rear?
^ one of the benefits is that you can run a softer spring and still get the same "wheel spring rate" since you are eliminating the "lever-arm" effect. Another is that you can change the spring really quickly. We were doing a coilover setup on my AST 5200s but we ditched the idea at the last minute for other reasons. People simply have different ways of doing suspension...
Originally Posted by Andy2108 View Post
Would you personally recommend true coils on a street car that only got on the track a few times a year?
No way. Why? You also need to reinforce the mounting points.
Edit - nevermind - all these points were already addressed haha.
Old 05-10-2011, 04:37 PM   #83
RoadRace330
First Ha!
RoadRace330
Old 05-10-2011, 04:45 PM   #84
FTWeisse
Originally Posted by RoadRace330 View Post
First Ha!
haha. Sweet build up
Old 05-10-2011, 05:42 PM   #85
zcchen
My Ride: Clown Shoe/M3vert
whoa!
zcchen is offline   Reply With Quote
Old 05-26-2011, 05:04 AM   #86
RoadRace330
CRAPPY CELL PICS ALERT! I've forgot my camera sorry.
Couple of pics last time I went to the shop.
The bodyshop guy made these really nice brake duct plate out of fiberglass.
Brake duct pipe being installed, thanks to the steering rack stopper, these will live longer than 1 weekend
The Volvo tractor is finally done and passed the DOT inspection flawlessly. Turned out really nice. Not too bad for a 9800$ truck.
All the vinyls were removed. I doubt we will have time to paint it before the first race(this weekend, Gulp!)
The power steering reservoir had to be installed on the right side along with the oil engine oil filter in order to make space for the carbon intake.
The car is still being tuned as we speak (at Chagautosport) it will be ready today, and we leave tomorrow morning for LCMT.
Next update on Monday.
Latest pics of the rig:
RoadRace330
Old 05-27-2011, 10:38 PM   #87
vaio76109
My Ride: Race Cars
How does the steering rack stopper work?
vaio76109 is offline   Reply With Quote
Old 05-30-2011, 07:02 AM   #88
RoadRace330
It's basically a spacer that goes between the inner tie rod and the steering rack main shaft. It locks the travel of the steering shaft. Only downside is a longer turning radius. It's quite a pain in the paddocks, but it saves the brake ducts and it's necessary when using the BMW MS front swaybar kit.
Just like this:
http://www.turnermotorsport.com/imag...ack%20stop.pdf
RoadRace330
Old 01-10-2013, 09:29 AM   #89
Minnetonka
My Ride: 03 330CI
Just found this. Awesome! no more updates?
Minnetonka is offline   Reply With Quote
Old 01-10-2013, 09:51 AM   #90
RoadRace330
Nahh, pretty much gave up on this team, the driver was too novice for my patience and was way to slow to have fun at all.
At the end, it looked like that. We got 316WHP out of the M54 with a M52 Intake.
RoadRace330
Old 02-22-2013, 01:38 PM   #91
murph1379
My Ride: 2003 330i ZHP
Wow, so what other work was done to the M54 to get that kind of whp?
murph1379 is offline   Reply With Quote
Old 02-22-2013, 02:20 PM   #92
RoadRace330
pretty much 18k$ of VAC Parts, A Vipec EFI, and 5K$ of Dyno time and tuning. Voila!
RoadRace330
Old 03-28-2013, 10:29 PM   #93
craz azn
My Ride: E30 325iS
Hi Marc-Andre, any chance you have pics of how the intake ports look? I am curious how the M50 intake manifold was matched to the M54 cyl head. TIA!
Rippin' Proper | E30 | E36 | E36 M3 |
craz azn is offline   Reply With Quote
Old 04-03-2013, 08:04 AM   #94
RoadRace330
Hmmmm, sorry no pics, but I remember that the engine builder had to match the M54 ports to the M52 intake, using epoxy and some grinding. The two ports are totally different.
RoadRace330
m54, racing, vac
