E46 Tie Rod Replacement DIY - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 4.97 average. Display Modes
Old 06-30-2012, 08:31 PM   #61
mps
My Ride: 2002 325ci
Originally Posted by andymilonkis453 View Post
did you have to put grease inside the boot? like cv joint grease?
I would think greasing is required only on the ball behind the screw the connects to steering rack
http://forum.e46fanatics.com/signaturepics/sigpic134793_3.gif
mps is offline   Reply With Quote
Old 07-01-2012, 10:26 AM   #62
Saintluk2
My Ride: 2000 323i sedan
I did my outer tie rods. The difficult one needed about 9 treatments of soaking in PB blaster with generous heating from a propane torch. The ninth time it finally budged.
Saintluk2 is offline   Reply With Quote
Old 12-15-2012, 05:35 PM   #63
TiAg323ci
My Ride: 2000 323ci
Excellent write-up, I just did mine today, this is an easy DIY especially with this DIY. For those of you that have earlier E46's the outer tie rod nut is not 19mm. I tried 19, then 18mm (which was still loose) and 17mm (too small) and figured it must be SAE and ended up using an adjustable wrench
Koni FSD's | Eibach Pro Springs |Staggered 19" VMR 710's | Hotchkiss Sway Bars | BMW Performance CF Strut Bar | Meyle HD Control Arms, RSM, Diff. bushing | Powerflex FCAB, RTAB| Brembo Sport Slotted Rotors + Akebono Euro Ceramic | Simota CF CAI | Conforti Shark Injector | Stewart Water Pump | M3 front and rear spoilers | Depo smoked front/side signals, Eagle Eye smoked LED tails | ACS interior trim/pedals | UUC Rob Knob 5 & floor mats |
TiAg323ci is offline   Reply With Quote
Old 12-15-2012, 07:03 PM   #64
missamo80
My Ride: 2001 325i
Glad you had success changing them out!
Neil
missamo80 is offline   Reply With Quote
Old 12-19-2012, 01:41 PM   #65
spennI
My Ride: 2004 330i
Originally Posted by lmr2wil View Post
I just did this DIY today. It went without a hitch. Thanks for the write-up!
Just a few thoughts to add to the pile:
1. sdpaguy is absolutely right. The tierod puller is the way to go. I bought this for $15 - http://www.amazon.com/Powerbuilt-648...3184051&sr=8-1 - which is the same price as a pickle fork and hammer (although the fork is certainly useful for the control arms too). It fit fine (using the smaller of the two bolts) and worked in just a few turns (See the attached pictures).
2. Both the jam nut on my old tierods, as well as that on the new ones, were 24mm rather than 22mm (YMMV).
3. I wanted to be able to torque the inner tierods to spec, so I also decided to go with a 1-5/16" crowfoot for $7 - http://erisautomotivetools.com/SUN97741.aspx - the actual size is 34mm but this seemed harder to find close to me. All I had to do was slightly file it down to get it to work.
Thanks again for an excellent write-up!
Luke
Would you do the job again without a tie rod puller?
spennI is offline   Reply With Quote
Old 12-19-2012, 07:19 PM   #66
lmr2wil
My Ride: '00 328Ci
It is so easy with the puller that I would really want it (this is especially true since you can get the power built one for so cheap). Having done the control arms earlier that summer, it was such a night and day difference of removing the tie rods with a puller compared to man handling the control arms ball joints off with a fork! No question, the puller is worth the $15.
It's also nice because you can remove the tie rod without damaging it, so if you need to remove the tie rod without replacing it, you can do that too.
Good luck!
Luke
lmr2wil is offline   Reply With Quote
Old 01-10-2013, 04:47 PM   #67
Ivan77cb
My Ride: Bmw 323i 00 sedan
what are the symtoms of a bad tie rod? i been geting some vibration on my steering wheel when im driving at 70 to 80 mph!!! i checked the tie rod last night and i notice the boot has a crack or a hole!!! and when i do a left u turn i get***65279; a scraping noise like a grinder noise!!
Ivan77cb is online now   Reply With Quote
Old 02-22-2013, 04:00 PM   #68
Ivan77cb
bmw e46 tie rods
do I have to replace just the tie rod end? or the whole tie rod cus I checked the tie rods this morning and the are really worn out and have some play because I been getting a vibration in my steering wheel I just replace the control arms and control arm bushings, can any one help me out plz
[ATTACH]Click image for larger version
Old 03-19-2013, 06:32 PM   #69
serano99
My Ride: 2000 BMW 323ci
To check your tie rod jack your car up and see if you can wiggle your tire side to side easily. Get a pry bar and and see if there's a lot of play in the bushing that attaches to your wheel. These are usually indications of a bad tie rod, it's normal for them to look warned out after so many miles.
serano99 is offline   Reply With Quote
Old 03-19-2013, 06:42 PM   #70
KrasivataSabine
My Ride: 323Ci
sub'd for the info, good job OP
#BattleBimmer #323RS
KrasivataSabine is offline   Reply With Quote
Old 04-02-2013, 03:25 PM   #71
trizzuth
My Ride: 234k, 16yr old B3AST
Sub'd cause I am all about this soon. Again. YAY for Chinese made tie rods from E-bay! Came from a "Hamburg Technic" kit I ordered a long time ago, I am actually surprised that they lasted as long as they did now that I think of it. But my driver's side is BAD, can move the wheel like 1/2" in each direction! Need to do this ASAP. NEVER BUY ANYTHING HAMBURG TECHNIC, I've had a control arm ball joint pop where it was so bad I thought it was going to separate and now this... and sway bar end links that were shot after less than a year! garbage parts.
2001 BMW 330i - Current at 235K
1996 Mitsubishi Galant S - gone at 121K
1993 Volvo 850 GLT - gone at 89K
1987 BMW 325 - gone at 238K
trizzuth is online now   Reply With Quote
Old 04-03-2013, 07:29 PM   #72
trizzuth
Hamburg technic tie rod outer end was destroyed. Thankfully it came off fairly easy, had both the tie rod separator and pickle fork, pickle fork won. Had to perform a driveway alignment to get her lined up good on that side on my zhp's. Rides good and straight now, so much better in the steering wheel, hitting highway tomorrow so we'll see how accurate my estimates are..
Old 04-03-2013, 07:40 PM   #73
Rahsblk330i
My Ride: 328i
Need parts for my zhp want to refresh suspension don't wanna go cheap but don't have crazy money to buy bmw parts I need to know the next best thing to it and where I can get parts good stuff for cheap
E90BAI!
Rahsblk330i is offline   Reply With Quote
Old 10-14-2013, 08:11 PM   #74
Silver325
My Ride: 2002 325i
For those who are searching for tie rod DIY and tie rod tools;
http://www.toolsource.com/inch-drive...-p-112593.html
Meyle control arms, M3 RTAB's, Bridgstone Potenza RE760
Silver325 is offline   Reply With Quote
Old 01-09-2014, 05:29 AM   #75
BOURBON
My Ride: 2003 330ci
I've just done this exact process to the "tee" per your write up. Everything's tight, I checked several times over, and made sure the tie rods were threaded the same length as the ones that came off. When I dropped the car back down and turned the wheel all the way to the left or right side, it pretty much involves a ton of work to pull it back center. Not to mention the ride home from the hobby shop where I did the work was scary as the car wanted to wobble and pull itself left and right at the same time. Is this a normal thing until I take to get an alignment?
BOURBON is online now   Reply With Quote
Old 01-09-2014, 03:22 PM   #76
sdpaguy
My Ride: 2002 330cic
Mine was a little squirrelly until it got aligned, so I wouldn't worry about it. But get that alignment sooner rather than later!
sdpaguy is offline   Reply With Quote
Old 06-20-2014, 06:15 PM   #77
Alex323Ci
My Ride: M3 & 323Ci (sold)
sub'd to add photos later
Old 08-14-2014, 10:48 AM   #78
BOURBON
My Ride: 2003 330ci
Just saw these replies, ive been gone on deployment since jan. So im faced with the issue again after pulling the car from storage. The wheel locks to the left or right whenever i turn it all the way. I have to fight to pull it back. I have new tires on the way to replace the fronts but youre saying an alignment should fix this? Im taking it tomorrow for that but dont want to be disappointed
Old 09-09-2014, 01:36 PM   #79
Davidle0612
My Ride: E46 330XI
" Step 19: Put your wheel back on and see how dumb it looks. In my case I accidentally had the length of my tie rod on the passenger side at 18 1/4" It looked obviously bad. If this happens to you get under the car and loosen the lock nut with the 22mm wrench. Then use the 13mm wrench to adjust how far the outer tie rod is screwed in/out. Then tighten the lock nut again with the 22m wrench "
In step 19, in order to adjust the length of the tie rod end, besides loosing the lock nut, the outer tie rod ball joint must be removed from the wheel hub in order for it to be turned left/right, is it correct? Thanks
Davidle0612 is offline   Reply With Quote
Old 11-24-2014, 09:33 AM   #80
mekaneck
My Ride: 2003 325xi
Davidle - you've probably figured this out by now, but for anyone else: no, you don't have to remove the outer ball joint from the knuckle to adjust your alignment. The shaft between the tapered lock nut and the steering rack will spin (because the ball on the inner ball joint can be spun in its socket), so that is all you need to turn to adjust wheel alignment.
Just make sure the steering rack boot isn't bound up on the shaft, or you will twist it up and possibly tear it.
2003 325xi Black
mekaneck is offline   Reply With Quote
good for tie rods
