Rating:
Display Modes |
#261 |
Mod
I haven't but I didn't notice any bogging down or lag in the transmission in the summertime.
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#262 |
Has anyone else experienced fan failure? I'm on behr fan #2 after the first one failed around the 6mo mark. My new one seems to be getting louder upon shut down, I'm about 3mos in, and scared!
Sent from my SCH-I535 using Bimmer App |
#263 |
Mod
For the electric fan? I haven't and I did the swap a while ago. I know E46mango just replaced his and it's at 130k or so
http://forum.e46fanatics.com/showthread.php?t=987217 ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide Last edited by Solidjake; 02-18-2013 at 06:16 PM. Reason: Auto-save 1361232994 |
#264 |
Eat grenade stupid!
I'm thinking about doing this mod on my X5 with the 3.0. My only concern is that the E53 weighs about 1,000 lbs more than the E46 and I don't know if that would have any added stress to the cooling system. Although the cooling system for both vehicles is identical. Any thoughts?
#265 |
Newparts has the BEHR fan right now for $183.66 with FREE SHIPPING!!
![]() http://www.new-part.com/product/bmw-...7-11-7-561-757 Enjoy |
#266 | ||
Mod
#267 |
#268 | |
ima touching member
Location: tree fort in big oak on corner somewhere in ny
My Ride: 04 330i jet black
what model to search for on the bay for this behr? |
#269 |
Mod
Part numbers are in the first post
#270 |
ima touching member
for oem, not the behr no?
found one for e46 on bay for $214 not much cheaper than pelican anyhow |
#271 |
Mod
Behr IS oem. Should cost $180-210 or so
#272 |
ima touching member
ahh, found a bosch for $213 thought that was oem
#273 |
Mod
I was searching a bit just now. Bosch is OEM too. Go for it. It's honestly the best mod you can do for your car mechanically.
#274 |
ima touching member
yeah, not much to do to these cars, i missed this for some reason, would have done it when i did water pump and evosport pulleys
#275 |
Mod
You will love it when you get it done.
#276 |
ima touching member
cool, ty for info
think i'll put 16533 on at same time
#277 |
Wasp, I was just coming on here to check into wether Bosch is OEM or not. BMAParts.com has bosch for $185.
#278 | |
ima touching member
ty yeah, that part number comes up as another part number but showing fan in pic spece30 code gets it down to $175
#279 | |
I'm gonna pull the trigger on this Mod, Thanks everyone!
![]() - E46 DIY Maintenance Thread - Mechanical Fan Delete - OBD2 UltraGauge - 2005 BMW 330CI ZHP - SPARKLING GRAPHITE METALLIC. ECS WP PULLEY - BEISAN VANOS & GAS DISA - SPRINT BOOSTER. CUSCO STRUT BRACE - BIMMIAN CELL MOUNT - USASPEC PA12. SMOKED LED MARKERS & REFLECTORS - LAMINX - INTERIOR LED'S. Last edited by WOLFN8TR; 03-13-2013 at 05:57 PM. |
#280 | |
Other than that initial problem, I've not had any issues. |
| Tags |
| aux, auxiliary, behr, bosch, bumper, clutch, damage, electric, engine, explode, fan, hood, mechanical, mount, mounts, removal, swap |
