Thread Tools Search this Thread Rating: Thread Rating: 37 votes, 4.89 average. Display Modes
Old 02-09-2013, 07:51 PM   #21
M3 FOR LIFE
My Ride: BMW M3 E46
Thumbs up guys
Car looking good ..
M3 FOR LIFE is offline   Reply With Quote
Old 02-11-2013, 10:44 AM   #22
SexiPYm3
My Ride: 03 M3
Good work Mert.... Regardless of how this turns out, much respect for doing what most would have never touched. You keep setting the bar higher and higher. Good luck.
SexiPYm3 is offline   Reply With Quote
Old 02-12-2013, 12:46 AM   #23
Bandit4077
My Ride: 330i SuperVeloce
this is the mod I've been waiting for. I've been planning S85 swap sedans, S62 swap sedans, and autocad designing a CF monocoque e46, but this is impressive best of luck to you in your part time AWD M3 conversion. should be one of the sickest pioneering innovations. don't give up!
I put your project on par with impressive's S54 xi sedan- if it works...
Some say, that inside his helmet, there is another helmet. All we know is...
Check out my interior: http://forum.e46fanatics.com/showthread.php?t=1055263
Bandit4077 is offline   Reply With Quote
Old 02-14-2013, 02:04 PM   #24
Twin_Turbo_S54
My Ride: M3
deleted
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 02-14-2013, 02:14 PM   #25
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Dude is going all out on this one
Timeless Motor Group
Old 02-14-2013, 04:32 PM   #26
Twin_Turbo_S54
My Ride: M3
deleted
Old 02-14-2013, 04:53 PM   #27
mcr_driver
My Ride: my favorite two feet
Congrats on the little one
Just saw this thread car looks ridiculous, kudos on taking this route and I hope it exceeds your expectations.
mcr_driver is offline   Reply With Quote
Old 02-17-2013, 05:40 PM   #28
bmxpert86
My Ride: e46 TiAg ///M3
I would just like to first say sorry for giving you crap sometimes in the past on the forums. I appreciate what your doing and if everything comes together the way you hope, you will have one mean M. Good luck Mert I truly hope that everything turns out good for you. We had a n/a M turned into an xi from one of our local New York sponsors and from what I understand the customer was not happy with the end result. But by the looks of things, you are doing everything possible to make this car reliable. You seemed to have changed your attitude lately and it takes a big man to change his ways. Best of luck to you and this really awesome project.
*EDIT* Congrats on the new baby! It's an eye opener when you now have something that you have to put before yourself/makes you grow up faster and appreciate the little things in life.
bmxpert86 is offline   Reply With Quote
Old 02-21-2013, 12:00 PM   #29
Twin_Turbo_S54
My Ride: M3
deleted
Old 02-21-2013, 01:49 PM   #30
BDUB328I
My Ride: bmw 328i S54 sedan (
Originally Posted by Twin_Turbo_S54 View Post
new rubber for the front axle arrived today.
rears are on the air.
is that the max width and max side wall you can fit up front? or do you have to do some testing with that yet?
BDUB328I is offline   Reply With Quote
Old 02-21-2013, 01:58 PM   #31
Twin_Turbo_S54
My Ride: M3
deleted
Old 02-26-2013, 09:48 AM   #32
Twin_Turbo_S54
My Ride: M3
deleted
Old 02-26-2013, 09:51 AM   #33
JohnBlaze
My Ride: Black Sunshine
62->125 mph in 2.2 seconds is, just, crazy!
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 02-26-2013, 12:30 PM   #34
Twin_Turbo_S54
My Ride: M3
deleted
Old 02-26-2013, 01:18 PM   #35
briangl92
My Ride: VQ37VHR
Amazing project! Good luck
briangl92 is offline   Reply With Quote
Old 02-26-2013, 01:40 PM   #36
Twin_Turbo_S54
My Ride: M3
deleted
Old 02-26-2013, 04:11 PM   #37
Cipri
My Ride: E46 M3 2002
Where exactly? And when?
Maybe we come with some cars from Romania.
Cipri is offline   Reply With Quote
Old 02-26-2013, 04:48 PM   #38
Twin_Turbo_S54
My Ride: M3
deleted
Old 02-27-2013, 04:17 PM   #39
BDUB328I
275 can be fitted on the front axles.
front and rear tire circumference must be almost identical, a maximum difference of % 2 is allowed, as this is awd car.
245s up front have similar circumference as that of 315s which I ll run at the rear axles.
I also did not want to have lots of traction for the front differential, more rubber more load on the front differential.
I have Limited Slip Diff on the front axle as well. Has been tough but did a LSD on the front as well.
If 245/315 combination wont yield enough traction, enough means 62-125 mph in 2.2 seconds, wider rubber for the fronts will be tested.
sweet sounds like we will see some 275's on the front soon!
Old 02-28-2013, 02:48 AM   #40
Twin_Turbo_S54
My Ride: M3
del
