E46 Xi Forum
Old 02-26-2013, 03:42 PM   #1
beemteam
My Ride: 325xi
WARNING!! Aluminum thermostats!!BEWARE!
I thought I was doing a good thing by replacing my failing thermostat with one with an aluminum housing. After replacing it everything was fine for a day then my car just died in the middle of traffic on day 2! I thought the fuel pump went out but after some research (and a new $220 fuel pump) I found out it was the fuel pump fuse!
But why was the fuse blowing? Someone on the forum said replace the thermostat so I unplugged the electrical connection on the thermostat replaced the fuse and voalaa! The car cranked right up! Why the thermostat is blowing the fuel pump fuse is still a mystery to me but I'm just going to leave well enough alone and leave the aluminum thermostat in and keep it unplugged, the car is running fine, all the guages are still functioning fine and I haven't experienced anything abnormal so far.
I guess that the electrical connection on the thermostat is for the OBDII, but I keep an eye on my water temp guage just out of habit anyway.
If anyone knows what the connection does feel free to share. Information is M-POWER!!!! Thanks and safe motoring to you all.
beemteam is offline   Reply With Quote
Old 02-26-2013, 03:47 PM   #2
beemteam
My Ride: 325xi
In this same vein, my mechanic said it may not be the thermostat itself but I may have a bad wire on the connector end. Just a thought. Still... beware of the aluminum.
Old 02-26-2013, 04:20 PM   #3
bmwbob89
My Ride: M-5 325 X3 528 740
They are junk. Remove it and send it back for a refund. They short out as you have found out. Where did you buy it. Other vendors removed them from their sites a long time ago.
bmwbob89 is offline   Reply With Quote
Old 02-27-2013, 10:35 AM   #4
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
+1 they are crap. We had a discussion on this in the general e46 section. Bad item to buy.
Old 02-27-2013, 04:55 PM   #5
latitude39
My Ride: 2002 325xi
My aluminum, aftermarket, TStat seemed to work fine since I installed it over 1 year ago. However, when I read my codes, recently, I get a code indicating my thermostat is "stuck open." The CEL has *not* illuminated. I read codes only because of another unrelated issue.
The coolant temperature floats around 85-89C when fully warmed up, which seemed a little cool to me ( the OEM unit is labelled as a 97C unit, FWIW).
I now have an OEM, plastic one in-hand.
Other than the too-cool temperature, the unit seems fine. Still, I'm going back to OEM.
latitude39 is offline   Reply With Quote
Old 02-28-2013, 05:00 AM   #6
beemteam
My Ride: 325xi
Question
Going back to the OEM ASAP! Thanks Guys! Next stop Cold air intake, any suggestions or warnings on a system?
Old 02-28-2013, 03:40 PM   #7
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Not worth it either. I had an AFE one and it sounded INCREDIBLE. But it had a lot of heat soak and rattled a lot. Went back to OEM and couldn't be happier.
Old 03-02-2013, 04:26 PM   #8
mrlatexxx
My Ride: 325xi
saved me $300 haha
$300 going for cosmetic, She needs that kinda love now lolz
sent from phone to bimmer app
mrlatexxx is offline   Reply With Quote
Old 03-02-2013, 07:21 PM   #9
Kubica
My Ride: 2003 325xi
I love my BMW Performance intake.
Old 03-03-2013, 06:19 AM   #10
beemteam
My Ride: 325xi
Thanks for ALL the input guy's I'm just going to upgrade My air filter to a quality one like K&N or something, and be done with it.
