Old 03-04-2013, 01:46 PM   #1
hitmanre
My Ride: 2000 BMW 328i
E46 starting problem
So today when I tried to start my car after class my car wouldn't start. So I pushed the clutch in harder and than it started. Seems like a quick fix but I want it to work right. Weather got hotter if that has anything to do with it
hitmanre is offline   Reply With Quote
Old 03-04-2013, 03:10 PM   #2
325ci_c150
My Ride: 2003 325ci
I had a problem like that and it ended up being my key, try a spare and see if it makes a difference
2003 325ci
325ci_c150 is offline   Reply With Quote
Old 03-04-2013, 07:35 PM   #3
hitmanre
it still does it but i found out why, i needed to push it in where i here a click in the clutch than it would turn on
Old 03-04-2013, 07:40 PM   #4
tailspnr
My Ride: 03 325i Manual
Your year e46 has 2 clutch switches, one at the top to detect starting to push the clutch, so as to deactivate CC, and one at the bottom of the range to make sure the clutch if fully disengaged before starting. Sounds the later one may need adjusting/replacing.
The 2002+ started using a single 4 wire interrupter style that detects both.
tailspnr is offline   Reply With Quote
Old 03-04-2013, 08:43 PM   #5
hitmanre
how do i adjust it?
Old 03-04-2013, 08:55 PM   #6
tailspnr
I don't recall if the 2000 model gives you the ability to adjust the position of the switch or not like on some older cars. You may just have to adjust the position of your seat to make sure your extending the pedal fully in order to engage the switch. If you notice that the problem becomes intermittent, I'd suggest a volt/ohm meter to test the switch.
Old 03-04-2013, 10:10 PM   #7
hitmanre
Yeah il just move my seat up I guess
Old 03-04-2013, 10:43 PM   #8
always-there
My Ride: 2002 BMW 330I
You need a new safety clutch switch.
Old 03-04-2013, 10:44 PM   #9
always-there
And you need to clean/bleed your clutch delay valve to improve the shifting!
Old 03-04-2013, 11:03 PM   #10
scarede46er
My Ride: 2001 BMW 325i ZSP
Actually even my 2001 has the new kind.
