Sponsored by BimmerWorld
Old 03-09-2013, 11:22 PM   #1
zooswanko
My Ride: 328i
Send a message via AIM to zooswanko
H&R springs installed on stock shocks. What to expect?
Did a lot of research before deciding to try h&r sport springs on my stock e46 suspension. Found so many different oppinions that I just decided to do it and installed today.
How long til the springs settle 100%? The rears appear to be lower right now maybe because I had the front of the car up all day and leaning on the rear suspension.
Second question? What's your oppinion on installing the h&r sport springs (.75" lower in rear and 1.4" front) on stock suspension?
Turner motorsport says they are for stock suspension but I know others have different oppinions.
Any feedback is appreciated.
Sent from my SAMSUNG-SGH-I747 using Bimmer App
zooswanko is offline   Reply With Quote
Old 03-09-2013, 11:30 PM   #2
Adamo99
My Ride: 2016 Wrangler 75thAE
You're the one that has them installed. Why don't you report back in a week and let us know whether it works out well or not?
Adamo99 is offline   Reply With Quote
Old 03-09-2013, 11:52 PM   #3
bmwstephen
My Ride: e46 325XI, e36 M3
bouncie bounciy kaboo0m! bigger bouncy bouncy bouncy
bmwstephen is offline   Reply With Quote
Old 03-10-2013, 10:33 AM   #4
zooswanko
My Ride: 328i
Ill keep you guys posted. I know other people have done it but I would like some better insight on what to expect. And being bouncy makes no sense. If anything its more stiff
Old 03-10-2013, 10:40 AM   #5
trippmann
My Ride: E30
Send a message via AIM to trippmann
You should expect blown shocks in a few thousand miles
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 03-10-2013, 11:33 AM   #6
zooswanko
My Ride: 328i
Why would they say they are for stock suspension then?
Old 03-10-2013, 04:07 PM   #7
trippmann
My Ride: E30
because they fit on your stock suspension.
Old 03-10-2013, 04:08 PM   #8
Japanrot_325i
My Ride: 03 325i
+1
Japanrot_325i is offline   Reply With Quote
Old 03-10-2013, 04:22 PM   #9
erich330ci
My Ride: 2004 330ci
Not sure if you have Sport Package OEM suspension, so I'm not sure if this is applicable to your situation, but if so, note that I spoke with H&R directly and was advised that I can, in fact, use my stock Sport Package dampers with 29484s. I suggest you call them if you want to get the right answer, from the horse's mouth.
Eric H.
erich330ci is offline   Reply With Quote
Old 03-10-2013, 05:07 PM   #10
jdny516
My Ride: Oxford Green M5
what to expect: blown shocks/struts after awhile.
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Frank Smith Tune
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
DINAN Front Strut Brace
Storm Motorwerks Products
2003 BMW X5 4.6iS | Black Sapphire Metallic | Black Sport | Titan Trim
2000 323Ci | TiAg | Gray | 5MT | SOLD My Progress Thread
jdny516 is offline   Reply With Quote
Old 03-11-2013, 11:29 PM   #11
drumsauce
My Ride: 2000 323it
They are not mutually exclusive terms.
They WILL be stiff as far as impact on bumps and reaction to changes in steering.
HOWEVER, the stiffness isn't being controlled by a damper that has enough force to control it. The spring will rebound after the initial bump and then compress again, and then rebound, compress, rebound, etc. This is where the bounce comes from.
IF you are in for the look, good luck to you.
But, as some have said already, the worn OE shocks will be overworked and will give you a more uncontrolled bounciness the more miles you put on. You will grow tired of it...I know I did. (poor 87 prelude)
drumsauce is offline   Reply With Quote
Old 03-12-2013, 01:36 AM   #12
zooswanko
My Ride: 328i
Thanks for the more detailed response. I see. I got the H&Rs for only 99$ brand new and installed them myself so if/when I find my car becoming bouncy, ill convert to coilovers. And now I know how to remove/install an e46 suspension :-D
Old 03-12-2013, 02:03 AM   #13
J LAU
My Ride: E46 / E82 / E89
You will have blown shocks or/and struts for sure. H&R race will blow them even sooner.
Based on what i have researched back in 2008, lowering springs normally shorten the lifespan of the struts and shocks by around 50%-70%.
So lets say a set new stock shocks last 80k miles under normal usage (no tracking, autoX, off road). Then with lowering springs you are looking for about 30-40k miles if you are lucky.
So...If you have the shock/strut for 50k miles, expect them to be blown within 10k miles or even less after installation.
If you just want the looks and want to just have everything right with one shot, I recommend the Koni "orange" struts and shocks. They are fairly cheap, and claimed to be able to support lowering springs without issues.
They should settle within 2-4 weeks if they were new.
J LAU is offline   Reply With Quote
Old 03-12-2013, 09:37 AM   #14
My Ride: Lexus
the shocks/struts are already blown if they are original. he's just riding around on springs.
Old 03-12-2013, 01:05 PM   #15
TT330i
My Ride: 2003 330i
not necessarily
TT330i is offline   Reply With Quote
Old 03-12-2013, 01:24 PM   #16
My Ride: Lexus
Originally Posted by TT330i View Post
not necessarily
Failure, in my definition, is anything beyond 50% loss in performance. Even Sachs-Boge (ZF) admits the early performance loss and total failure of the units.
FWIW, EVERY single original BMW strut/shock I've pulled has been completely dead or extremely worn. And I've pulled BOAT LOADS.
Excellent HIGH-performing lightweight unit, but not designed to go the long haul (as it shouldn't)
Old 03-12-2013, 01:38 PM   #17
bmwstephen
^ he speaks the truth. at 60k its probably dead. if you don't notice, it's probably because you're not driving your car too aggressive.
Old 03-12-2013, 11:17 PM   #18
zooswanko
My Ride: 328i
I love all the feedback and knowledge. Yeah I was shooting for a cheap way to lower the car a bit and possibly stiffin the suspension a little. From just driving a couple days I'm pleased with the feel and look. We'll see how long the feel lasts. When necessary ill do coilovers. Also just put 18's on and my e46 looks hotter than ever. Ill post pics soon
