Old 03-11-2013, 04:16 PM   #1
Jerry Murk
My Ride: 03 325i
HELP PLEASE!!!! e46 starting problem.
My 03 325i has had some serious starting problems lately. (Hasn't started in almost 2 months) I let my sister drive my car one day and she brought it back to me with a flat tire. Since I couldn't afford a new tire at the time and I didn't have a spare I let my car sit in my driveway for a while. About 2-3 weeks later when I finally got a new tire I tried starting my car and it cranked but the engine just wouldn't turn over. The last time I had that problem it was cause of my bad fuel pump and low fuel so this time I went and filled my car to a half tank. After putting some had in my car still wouldn't start so I figured it was because I was 2000 miles past due an oil change so I changed the oil and filter myself. After I changed the oil my car wouldn't start due to a dead battery so I used my mom's 745li to charge my battery. After charging my battery for about 10 mins I tried starting my car 3 times and the first two times it cranked but didn't start and ppb the third time it didn't even crank at all and that how it's been for the past 5 days. I was thinking that now maybe my starter isn't working well from trying to start it unsuccessfully too many times. What do you guys think it could be??? Please help!!
03 325i
Jerry Murk is offline   Reply With Quote
Old 03-11-2013, 04:26 PM   #2
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Need to fully charge your battery. Take your battery to Auto parts store to get fully properly charged. 10 minutes is not enough.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 03-11-2013, 04:39 PM   #3
Jerry Murk
My Ride: 03 325i
Thanks, I'll try that
03 325i
Old 03-11-2013, 06:19 PM   #4
Jerry Murk
My Ride: 03 325i
Im starting to think that it may be the starter
03 325i
Old 03-11-2013, 09:05 PM   #5
TitanSilverE46
My Ride: 2001 318i & 325i
I think you should first have the battery fully charged.
Next, if the starter cranks but the engine doesn't fire properly, it could be low oil pressure in the hydraulic tappets, due to excessive cranking and no start.
Check Post #5 in the second link under my sig
TitanSilverE46 is offline   Reply With Quote
Old 03-11-2013, 09:27 PM   #6
lszlszx
My Ride: 1.8T, XC70
Purchase a battery charger, or you could jump start the car.
Battery might be getting old, too.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-11-2013, 09:45 PM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I vote battery...check date on it...if it's 4-5 years old, it may have done its time. If you have a charger, try it.
It doesn't sound like starter at all...it was cranking...then your nearly dead battery just didn't have any power. Cranking takes more power than anything.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-11-2013, 11:06 PM   #8
Jerry Murk
My Ride: 03 325i
Thanks guys, I'm gonna try getting it fully charged tmrw or I might just end up getting a new battery. Hopefully, it really just is the battery and nothing more.
03 325i
Old 03-18-2013, 09:30 AM   #9
BMWCaptain
Did you get your car started?
BMWCaptainE46.com
Old 03-18-2013, 09:50 AM   #10
WDE46
My Ride: 2004 330Ci OBM
You should have just jumped it off the 745. Then let it run for 30-45 minutes to self charge the battery. You probably have a weak or dead cell by now though. Buy a new battery.
Old 08-03-2013, 01:11 PM   #11
Jerry Murk
My Ride: 03 325i
Im doomed.
4 months later and i still rely on my girlfriend to take me everywhere cause my car still wont start. Just went and wasted $140 on a new battery and it turned out that wasnt even the issue. Now im thinking the starter went bad after too many unsuccessful attempts to start it. What do you guys think?
03 325i
Old 08-03-2013, 01:22 PM   #12
2003silver330i
My Ride: 03 BMW 330i
Does the engine turnover when you turn the key or is there complete silence?
This should help you with starter symptoms:
http://www.ehow.com/how_4845780_spot...d-starter.html
2003silver330i is offline   Reply With Quote
Old 08-09-2013, 08:05 PM   #13
Jerry Murk
My Ride: 03 325i
It turns over.
03 325i
Old 08-09-2013, 08:30 PM   #14
jayb328i
My Ride: E46 2000 328i
My cell phone battery takes 4 hours to charge, my camera battery takes 6 hours, my electric shaver takes 11 hours.................what were you thinking when you concluded that 10 minutes is enough for an auto battery. Not sure why you would not just jump start it on the other car's battery and if successful, drive for an hour (or more) to charge your own battery
jayb328i is offline   Reply With Quote
Old 08-10-2013, 06:28 AM   #15
NumbaOneNewb
My Ride: 2003 330CI Silver
Re: HELP PLEASE!!!! e46 starting problem.
Check fuses, especially the ones under the hood in upper right compartment
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
battery, fuel, oil, starter, tire
