Old 03-12-2013, 10:27 AM   #1
Waggonpuller
My Ride: e46 wagon e30 325is
Question Dome light problems... How does it work?
Hello, I am having problems getting my dome light working and don't really understand how the switches work. I have two map lights that work with the two outside switches, but only if the middle switch is pushed. Once the middle switch is pushed, the map lights work with their respective switch. The middle dome light won't work at all. Can someone explain how the switches are suppose to work? Seems to me the three switches would control the three different lights independently with the dome light coming on as you unlock the door.
Waggonpuller is offline   Reply With Quote
Old 03-22-2013, 11:12 AM   #2
Waggonpuller
Still can't get this figured out. I ordered a new dome light, but still can't get the middle light to come on at all. The new light I got came with the pigtail still plugged in and I noticed that it has one extra wire than mine does. Can that be the reason mine is not coming on? Also, does anyone know how I can get some info on retrofitting foot well lamps? Any help would be great!
Old 03-23-2013, 04:25 PM   #3
sillieidiot
My Ride: '06 AW 330ci
so did your car not have the dome light in the first place or something? try pushing the middle one and holding it for like 15 seconds or so. when you hold it, that's how you force it on/off.
Old 03-23-2013, 11:51 PM   #4
Waggonpuller
Hey, thanks for the responce. I tried holding down the middle button and it turned on everything but the dome light. I just want the damn dome light working. I am not real sure if it has ever worked. Anyone know where I could get a wire schematic?
Old 03-24-2013, 03:18 AM   #5
cityjohn
My Ride: 2001 M3
I know you said the light was new but be sure and check the bulb. They're supposed to be little 6 watt xenons but a 2825 or even a 168 or 194 will fit.
cityjohn is offline   Reply With Quote
Old 03-24-2013, 06:43 PM   #6
Waggonpuller
I have tried multiple bulbs and still nothing. I am wondering if the center light might be some sort of lighting package that didn't come with my car?
