Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 03-13-2013, 12:25 AM   #1081
NCLee
My Ride: 2004 330xi
Send a message via AIM to NCLee
Mango, I just went through refreshing my entire cooling system. I bought the "E46 COOL AUTO" kit form Bavarian Autosport, but it was missing a couple key elements - notably the Expansion Tank Mounting Plate, and the Automatic Transmission Thermostat, which exploded when I took the old expansion tank out.
Thank you SO MUCH for your guide, the part numbers, and help on this. I am thrilled to know that my car is going to be healthy and fresh for years to come. You have saved me THOUSANDS of dollars. Keep it up, and keep on rockin'.
NCLee is offline   Reply With Quote
Old 03-13-2013, 02:34 AM   #1082
My Ride: 2016 Lexus
You are welcome sir! I am glad you and your car will be confident as you go down the road now.
Old 03-13-2013, 03:46 PM   #1083
entrax
My Ride: 2002 325xi
successfully replaced my water pump/radiator/fan/shroud/thermostat using the parts/advice on this thread. thanks for the help (and saved me $750 by being able to do it myself!) THANKS!
just from my experience: don't bother trying to use random tools to take out the fan. either use the proper fan removal tool or at least a thin 32mm wrench. i was able to get one for $12 from a bike shop (they sold me one of their old ones) and use a screwdriver to keep the pulley steady; it took me 5 min vs. the 1 hour i tried with all the other tools in my garage. i also took the time to wire brush off some rust on the nut and put anti-seize compound on the threads.
entrax is offline   Reply With Quote
Old 03-13-2013, 03:48 PM   #1084
My Ride: 2016 Lexus
Congrats and welcome.
With an adjustable wrench and a screwdriver, I've released fans in 5-10 seconds. I've done it for a few members here. nice to have the "right" tool but isn't necessary if you're in a bind.
Old 03-13-2013, 04:10 PM   #1085
entrax
My Ride: 2002 325xi
I tried that to start but I had a feeling I would have a tough time as the nut itself had surface rust on it. Maybe its the snow and excessive rain we get here and the fact that the cooling system hasnt been serviced since new that made it difficult for me. When I had it out, the threads did have rust on them too...i hope my case is isolated then! Either way the tool i got (park tools is the brand) has a 36mm on the other side so oil changes will be easier!
Old 03-16-2013, 06:44 PM   #1086
eclipsor
My Ride: stahlblau
Send a message via AIM to eclipsor
Thanks again for replacing my whole cooling system for me this morning Mango! For anyone in the L.A. area, I recommend Mango as a mechanic ahaha
Jet Black 1994 325is -> Steelblue 2003 325i
eclipsor is offline   Reply With Quote
Old 03-16-2013, 09:26 PM   #1087
My Ride: 2016 Lexus
haha no problem. make sure to top it off w/ water the next 2-3 days. after that you should be good to go
Old 03-21-2013, 08:17 AM   #1088
Shaggys
My Ride: 2001 BMW 330XI
Change it out! wasn't that bad once all the parts came in to do it. and I've never worked on a bmw before. a little messy but doable. lucky for me it was -5 out when my tank exploded down the side so when i noticed the temp going up was able to park and get a tow. seems perfect now it's been about 1500 miles and no loss of fluid or leaks so pretty happy for that (thanks Breiwa1 for the help!!) at the same time we installed cross drilled and vented rotors on all 4's ceramic pads new sensors , and new tires .. thing rides sweet! car had 113k on it when it failed and got new rad,hoses,sensors,tstat all for about 300 the pump had been replaced before so didn't feel the need.
and in total about 4 hours to do it 1-1/2 dis-assembly and 2-1/2 to put it back together ..
2001 330xi
Shaggys is offline   Reply With Quote
Old 03-24-2013, 10:48 AM   #1089
My Ride: 2016 Lexus
More recent evidence: http://forum.e46fanatics.com/showthr...1#post15279180
Old 03-28-2013, 03:08 AM   #1090
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
orly?
what's mango's rate for the cooling system overhaul?
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/BMW M Performance Exhaust/Injen CAI
XKxRome0ox is offline   Reply With Quote
Old 03-28-2013, 10:30 AM   #1091
My Ride: 2016 Lexus
orly?
I don't have a "rate." why do you ask?
Old 03-28-2013, 10:53 AM   #1092
325iGirl03
My Ride: 2003 325i
He asked because someone was recommending you.
325iGirl03 is offline   Reply With Quote
Old 03-28-2013, 10:58 AM   #1093
My Ride: 2016 Lexus
Old 03-28-2013, 03:08 PM   #1094
XKxRome0ox
Black and Proud
Isn't it obvious?
If your "rate" is agreeable, I would ask for your help in rehauling my cooling system before it blows up
I have a leak
[bimmerapp]
Old 03-28-2013, 03:14 PM   #1095
My Ride: 2016 Lexus
Isn't it obvious?
I have a leak
[bimmerapp]
Just curious. I've been getting lots of strange questions lately (both directly and indirectly) Where is it leaking from?
Old 03-28-2013, 04:15 PM   #1096
XKxRome0ox
Black and Proud
Around the top of the radiator by the hose
Lot of coolant residue trailing down
My car has 172k miles
And I don't think I have ever replaced any of the cooling system stuff (except for some of the a/c stuff like the pulley and belts)
[bimmerapp]
Old 03-28-2013, 04:53 PM   #1097
Stinger9
My Ride: '04 330Ci
[bimmerapp]
Are you the original owner?
Old 03-28-2013, 05:07 PM   #1098
My Ride: 2016 Lexus
Only if he was 10-14 at the time of purchase
Old 03-28-2013, 05:32 PM   #1099
XKxRome0ox
Black and Proud
yes
lol
i got this car new in july 2001 after i graduated college
i am either doogie howser (if you don't get this reference, then you are too young)
or i'm old
Old 03-28-2013, 05:33 PM   #1100
My Ride: 2016 Lexus
yes
lol
i'm old
Wow. I figured you to be in your early 20s. SoCal climate and environmental factors probably helps a great deal with cooling parts. 172k not bad. Did you order all your parts?
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
