///M3 Forum
Old 03-17-2013, 01:39 AM   #1
Westrace
My Ride: 06 G35, 04 M3 Coupe
Help! Is it window regulator or motor or switch
So my driver side window stuck down position and won't roll up. I managed to removed the panel but now how do I know which is broken?
Is it the motor? the regulator?
When I turn the switch, I hear a click at around the motor area ... that is all I can tell.
Also did I damage the black lock stick when I removed the door panel? Now it stays up and won't go down? (See picture below).
The black lock stick here won't go back down. It was in the up (unlock position) when I removed the panel so I don't know if it got damaged.
Westrace is offline   Reply With Quote
Old 03-17-2013, 02:39 AM   #2
Westrace
Never mind. I think it's the switch. I used my key to roll up the window and it worked. So thankfully it's the switch because the regulator would have been a PITA to replace.
Old 07-29-2013, 05:17 PM   #3
project330ci
My Ride: steel grey 02 325ci
Is there a way to fix the switch? I notice theres no clicking when i go to roll up my window from the switch. Is it just popped off? Fixable? Or i have to replace it?
project330ci is offline   Reply With Quote
Old 07-29-2013, 05:21 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I'm sure someone has sprayed their switch out and cleaned it from the Dr. Pepper that spilled in it...not that bad to do...or to just replace the switch.
That said, you could swap with another switch first and test your theory...could be a wire issue too.
Facebook.com/DMAXstandup
Mangofy your E46!
