Go Back   E46Fanatics > Everything Else > The Off-Topic > Photography
Photography
Old 03-11-2013, 08:56 PM   #1
Kwando
My Ride: rolls Volks TE-37SL
What kind of camera strap do you use?
As much as I like my OEM Nikon strap, I'd like to find a comfortable sling that can easily detach the camera. So far I've been looking into these two
OP/TECH Utility Sling - $25
http://optechusa.com/utility-strap-sling.html
From the pictures, what I don't like is that it looks like someone could detach it when you're not paying attention.
BlackRapid Metro - $70
http://www.blackrapid.com/products/metro
Other than it being way more expensive for a strap, my main concern is my camera loosening from the screw even if they say it won't.
Can anyone one provide insight into either strap or have any recommendations? Perhaps I'm just over thinking these issues but I'm the cautious type, especially when's there's 2k hanging from my side.
Would also like to hear from people who don't run straps at all. I'm not using anything right now and love how there's no strap flopping around but I'll need one when I start doing more traveling.
Kwando is offline   Reply With Quote
Old 03-11-2013, 10:11 PM   #2
woobiee
My Ride: JetBlack E46 323Ci
Send a message via AIM to woobiee Send a message via Yahoo to woobiee
What I found with heavy duty straps is that the straps are heavy in weight. It may not seem like a big deal, but when you have a heavy strap flopping around when you work, it gets really annoying. But then you have those heavy duty straps with quick releases. I found out with those is that most of them come with these huge plastic clips which are massive and get in the way as well.
In my opinion, the sling-type straps are more cumbersome for its own good. After using many straps, I finally settled for a simple Heavy Leather NYC strap http://www.bhphotovideo.com/c/produc...era_Strap.html Simple, lightweight, small QR clasps, and it looks good.
woobiee is offline   Reply With Quote
Old 03-12-2013, 12:55 AM   #3
saxual328ci
My Ride: 2004 325ci
I wanted something close to my saxophone strap. Something well padded and wouldn't sweat my neck out. lol So I got the Crumpler Industry Disgrace strap. This is well made and padded well. When I shoot outdoor concerts in the summer my neck is not sweating. They make one that detaches. Black Rapid from what I hear is a good one. In the UK they have the Crumpler Singapore Sling which has a quick release. They don't sell the Sling in the states so I can't comment on the that version but the difference in these straps is that the Sling can detach from your camera.
I remember when I got my D90, in the Nikon Manual they had changed the way you put the strap on the camera. It was different than previous Nikons DSLR. If you look at the threading, it makes sense to thread it this way.
http://support.nikonusa.com/app/answ...ikon-camera%3F
saxual328ci is offline   Reply With Quote
Old 03-12-2013, 11:30 AM   #4
Blueandwhite85
My Ride: E46
I just stick with the strap that Canon provides.
Blueandwhite85 is offline   Reply With Quote
Old 03-12-2013, 11:38 AM   #5
Breezy
My Ride: LSB M3, saab 900s
I had a black rapid and then a grip strap, but got rid of both of them. These days the stock canon one works best.
Breezy is offline   Reply With Quote
Old 03-12-2013, 01:34 PM   #6
Kwando
Thanks for the comments. I'm perfectly happy with my Nikon strap but would like something with a quick release. Will be checking them out at the store at some point.
Old 03-12-2013, 03:20 PM   #7
328iGuy
SensFan
My Ride: 2012 Audi Q7 S-Line
I use a Luma Cinch, and it is fantastic. The MKII will be out very soon, love mine though and I have carried my 5DII + 70-200IIL without issue on the sling.
They are made by Luma Labs.
Canon 5DIII | 35L | 16-35L II | 24-70L II| 85L II 1.2 | 70-200 2.8L IS II | 600EX |
328iGuy is offline   Reply With Quote
Old 03-16-2013, 03:36 PM   #8
boatshoe
My Ride: 330xi
I bought a Blackrapid connector and attached my Canon kit strap to it. Hangs at my side, just doesn't slide up and down like a Blackrapid.
boatshoe is offline   Reply With Quote
Old 03-16-2013, 05:30 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Stock strap
Old 03-17-2013, 03:52 AM   #10
Godsgiftowomen
My Ride: Peasant Express
Crumpler one
Godsgiftowomen is offline   Reply With Quote
Old 03-27-2013, 12:00 PM   #11
TayloMade[07]
My Ride: '12 Frontier Pro-4x
Sun-Sniper... really awesome strap, lets the camera sit in the low of your back so its easy to walk around with especially out doors or in busy crowds, has a built in wire in the strap (Sniper-Strap Steel) to eliminate being cut off you in those sketchy places. its also very comfy. would highly recommend it.
http://www.sun-sniper.com/en/the-steel.html
Old 03-27-2013, 04:42 PM   #12
SamDoe1
My Ride: 4cyl of fury
I use a Tamrac strap, I don't remember the model but it has memory card storage, quick disconnect strap, and is comfy.
Old 03-31-2013, 01:38 AM   #13
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
I just received my Canon CPS strap. Feels comfortable compared to the stock one.
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
Old 03-31-2013, 01:58 AM   #14
poke08
My Ride: AW E46 M3
Black rapid is the way to go. I have the rs-sport and its really comfortable.
**edit** I forgot to mention I use it with my gripped d7000 and 24-70 2.8 all the time with no issue. I even used if with my 70-200 when I had it as well.
poke08 is offline   Reply With Quote
Old 07-05-2013, 04:42 AM   #15
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Am I the only one that uses NO strap?
Either my stuff is on a stand, in a Pelican case, or in my hand. Why clutter things up?
Old 07-05-2013, 11:58 PM   #16
saxual328ci
My Ride: 2004 325ci
I like using a strap. Some days I will keep my bag in the car, and just go out with the camera on a shoot. When I use a 70-200 or if I'm shooting all day the strap will save my hands from cramping up. My Crumpler Industry Disgrace strap is so comfy. I'm thinking about buying one to carry my sax with. #comfy
Old 07-08-2013, 08:28 AM   #17
jinwu57
My Ride: bmw325 ci
I currently use an imitation Black Rapid, but looking at getting this to carry around a second body for shooting events: http://www.amazon.com/SpiderHolster-...ords=spiderpro
Anyone have experience with it?
jinwu57 is offline   Reply With Quote
Old 07-08-2013, 10:41 AM   #18
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
stock Canon 60D one
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 07-08-2013, 11:04 AM   #19
328iGuy
SensFan
Luma Cinch hands down my favourite of all time!
Old 07-20-2013, 06:36 PM   #20
dominicgrillo6
My Ride: E46 Sedan
Originally Posted by Solidjake View Post
Stock strap
Same.
Instagram
dominicgrillo6
Whoooty
For Sale
245/35/19 Tires - 255/35/18 Tires - Yamaha V Star 650
dominicgrillo6 is offline   Reply With Quote
