The Showroom
Old 03-18-2013, 01:57 PM   #1
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
My Project List
Just posting this so I can keep track of where I've been and where I'm going...
Project List:
So far I have:
-Replaced old crappy broken and repaired stock shifter with gray glue gobbed all over it >>> bavauto lighted shift knob w/ black boot
-Removed old crappy bubbly purple tint from the rear window
-Replaced 5 broken door panel clips causing the driver's side door panel to be loose
-Replaced a broken right kidney grille
-Replaced inop wascherpumpe (original Deutsche spelling on the box lol)
-Replaced front control arms and bushings with Meyle
-Crawled under for a CDV delete and found it already deleted
-Replaced Secondary Air Pump (used)
-Replaced Differential oil (Royal Purple 75w90)
-Replaced Transmission fluid (Royal Purple Synchromax MTF)
-Replaced Front rotors (Zimmerman) / pads (Akebono)
-VCG/plugs/VANOS rebuild
-new Belts/pulleys
-replaced entire cooling system
-replaced both air filters
-replaced battery with Duralast 49DL from Autozone
-replaced windshield cowl
-replaced low beams - philips crystal vision ultra bright white
-replace lug nuts
-replaced wiper blade inserts
-removed aux fan, replaced mechanical fan with electric (Bosch)
-replaced driver's side seat belt tensioner and wiring harness
-replaced headlight covers
To do list (needed):
Rear trailing arm bushings
differential rubber mounts
Fuel filter
sway bar end links
brake fluid flush
oil level sensor
struts/shocks
To do list (wanted):
clutch stop
SSK
Hood dent and front bumper scrape repair/repaint, or facelift hood, or painted CF hood if I can find a used one cheap
Angel Eyes
HID's (possibly quads)
Better mirrors
lower her a bit
different bumpers
respray
Schlag96 is offline   Reply With Quote
Old 10-22-2013, 01:46 PM   #2
Schlag96
Schlag96's Avatar
My Ride: 1999 323i
Update...
Project List:
So far I have:
-new Belts/pulleys
-replace lug nuts
-M3 RTABS with Vorschlag Limiters
-Meyle Fuel Filter
-sway bar end links
-Upgraded to stock 325 sway bars front and back
-brake fluid flush with super blue
-Steering Guibo
-H&R Premium Cup Kit with front strut reinforcement and Rogue Engineering rear shock mounts
-MTECH II front bumper
oil level sensor
FSR
Troubleshoot driver side tensioner code / airbag light
refinish / repaint wheels
new tires
clutch stop
SSK
Hood dent repair/repaint, or facelift hood, or painted CF hood if I can find a used one cheap
Angel Eyes
Better mirrors
Old 10-22-2013, 03:04 PM   #3
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
nice list and all but why is this in the showroom?
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 10-22-2013, 03:12 PM   #4
Tonk
My Ride: 03 VW Passat
Send a message via AIM to Tonk
Cool story bro.
Tonk is offline   Reply With Quote
