Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 4.80 average.
Old 03-17-2013, 10:04 PM   #1221
KTM434
My Ride: 323it
I'll be buying coilovers very shortly. I just posted a WTB thread in the suspension section to see if I can find a used high dollar setup for less $$ otherwise I may very likely go with the RaceLand coilovers. Flame me if you want and call me a stupid newbie, it won't bother me. I was a BMW master tech for 6 years and yes I own a 323it so go ahead and make fun of that if you'd like,? It's a wagon that'll never see the track... It's my daily driver that will do some Home Depot trips and will tow my standup jetski to the surf on the weekends. I will be tucking a staggered set of 19x8.5 and 19x9.5 rims so the adjustability and stiffer spring rates are what I'm after and if nothing pops up used this is the route I plan on taking
KTM434 is offline   Reply With Quote
Old 03-17-2013, 11:24 PM   #1222
Redline4
My Ride: 02' 330Ci
Send a message via AIM to Redline4
Put over 20k on mine and they still working great! I checked them this weekend and they still look brand new.
http://forum.e46fanatics.com/signaturepics/sigpic201481_1.gif
Redline4 is offline   Reply With Quote
Old 03-18-2013, 11:23 AM   #1223
KTM434
My Ride: 323it
^^ thats good to know. I've seen some posts about needing wheel spacers to clear some brands of coilovers in the front (even with oem wheels), has anyone had this issue with these coilovers?
Old 03-18-2013, 09:49 PM   #1224
Steven747
My Ride: 05 330ci
Just take out the helper springs they are pointless and do nothing
Old 03-23-2013, 02:41 PM   #1225
dinan19
My Ride: 2004 Imola ZHP
The helper springs have nothing to do with clearance at all. The problem is with the offsets of the front wheels. You will need at least 5mm spacers for the front so the wheels clear the shock body.
Sent from my SGH-T959V using Bimmer App
Old 03-23-2013, 02:53 PM   #1226
KTM434
My Ride: 323it
5mm spacer for what rim width/offset? There are too many variables for such a general statement to be true
Old 03-23-2013, 03:08 PM   #1227
dinan19
The statement is true specifically for raceland or rokkor coilovers. Basically any stock wheel and aftermarket wheels wont clear in the front unless you have a super small rim width in the front like 17 x 7 or something like that. The inner rim lip will touch and grind against the side of the spring on the front coilover. Ask me how i know, because it happened to me lol.
Old 03-23-2013, 03:54 PM   #1228
KTM434
My Ride: 323it
What wheels did you try to fit? I have 19x8.5 et35 in the front (fairly common size). Also are you running camber plates?
Old 03-23-2013, 04:22 PM   #1229
dinan19
That size def will not work. I have 19x8.5 on mine as well in the front and it didnt clear without spacers.
Old 03-23-2013, 04:24 PM   #1230
dinan19
No camber plates. Im using the stock top hats and 15mm spacers as well.
Old 03-23-2013, 04:37 PM   #1231
KTM434
My Ride: 323it
Did you need 15mm spacers for that rim size or did they clear with 5mm spacers?
Old 03-23-2013, 05:04 PM   #1232
dinan19
Lol no 15mm is just what im running to be flush with the fender and it pretty aggresive. All you need is a 5mm anything more is just personal pref and looks.
Old 03-23-2013, 05:09 PM   #1233
dinan19
Here's a pic of my car with 15mm spacers in the front on a 19x 8.5 front on rokkor coils, Sister company of raceland. Hope that helps u.
Old 03-23-2013, 05:15 PM   #1234
KTM434
My Ride: 323it
Definitely helps, thanks bro
Old 03-24-2013, 02:52 AM   #1235
dinan19
Yeah np
Old 03-24-2013, 10:25 PM   #1236
sjacoby112
My Ride: 2002 325ci
what offset and tire size?
sjacoby112 is offline   Reply With Quote
Old 03-25-2013, 02:08 AM   #1237
KTM434
My Ride: 323it
^^ x2
I thought you already said you had the same offset as me but I guess I just assumed.
Old 03-25-2013, 05:13 AM   #1238
dinan19
Same size and offsets
Old 03-25-2013, 05:51 AM   #1239
KTM434
My Ride: 323it
Ok cool, I had already ordered 5mm spacers after you said they'd be needed so that will work out well
Old 03-25-2013, 10:55 PM   #1240
dinan19
yeah 5mm is perfect if all u want to do is just be clear of the struts.
coilovers, ebay, raceland, review
Rate This Thread
