Old 03-19-2013, 12:05 PM   #61
basketthis
My Ride: state to state
Originally Posted by smooth1 View Post
You said you cleared codes, not adapts. They're different, hence the different button.
Yes, let it run.
I learn something new about this car almost every time I'm on here!
Okay. And you said it looks like my timing is off? Could leaving the camshaft position sensor unplugged have done that? Or is there another plug that could still be undone from when I did the CCV? I thoroughly checked for any and didn't see any. But if it's your advice that something may still be undone, I will check. Just trying to think of stuff before the next time I get the chance to cold start.
basketthis is offline   Reply With Quote
Old 03-19-2013, 12:25 PM   #62
smooth1
My Ride: BMW FTW
You'd have a code if something was undone. It's just jumping around a lot, so either your tables were modified (Crappily) or the DME is reacting to something.
smooth1 is offline   Reply With Quote
Old 03-19-2013, 01:25 PM   #63
basketthis
Hey. Do you think is possible that a creak in my oil cap gasket could be causing this? I just noticed it.
Edit: crack*. And it probably is a dumb question. However, I've never had a bad oil cap gasket. I'm grabbing a new oil cap from the dealership today. Will update with cold start results when I can. I'd be very happy if the cap was the ultimate culprit!
Old 03-19-2013, 09:44 PM   #64
basketthis
Old oil fill cap:
Replaced cap. Cleared adaptations. Drove 50 miles. SES has not returned yet. Morning shall prove to be the ultimate test.
Old 03-19-2013, 10:08 PM   #65
Gus330vrum
My Ride: 330ci
Interesting thread: I also have 325xi.
Op, did you replace camshafts sensor/crank sensor? & how many miles?
Yes bad oil cap gives you vaccum leak, just like gas cap.(( replace vaccum lines coming from 2nd air pump going towards the back of the engine ))
Where is the goldish oil color?lol
Try this: \/ BG can be found local Goodyear local tires place here in Atlanta $13 ea. Dealer has it also dunno how much.
Sent from my LG using Bimmer App
Gus330vrum is offline   Reply With Quote
Old 03-20-2013, 11:57 AM   #66
basketthis
It lasted for 160 miles. The new code is "mixture deviation" on bank 1 and 2.
New Datalog:
http://www.datafilehost.com/download-7b4007bb.html
If anyone hasn't picked up the BMWLogger software, definitely try it out! Very useful. Feature-filled. I purchased the full version. It's proven very useful. Even after only a couple of days of use! thanks smooth1
