Sponsored by BimmerWorld
Old 03-19-2013, 09:51 AM   #1
coffeebob
My Ride: coffee grinder
ready to get new suspension, ZHP inquiry
I have a 02 325i sedan sport package with ACS lowering springs + ZHP shocks/struts for 120k now (car at 160k). They are at about end-of-life.
1) Are they any places that sell the ZHP shocks/struts alone? The link below
sells the whole package with sway bars/control arms/etc that I don't really
need.
http://www.fcpeuro.com/products/bmw-...em-33500429577
2) I am also open to Koni Yellow, but given the ZHP longevity, I would rather
stick with it. What do you think?
3) By the way I also want to get the rear shock mounts, not sure whether they
are bad, but just wanted to replace them at the same time. I don't need
anything fancy given the mileage on my car.
thank you!
My other grinder is a BMW
coffeebob is offline   Reply With Quote
Old 03-19-2013, 09:55 AM   #2
My Ride: Lexus
click my suspension thread, copy/paste part#s into google.
btw, your stock struts/shocks were severely degraded, if not dead, by 40k miles
Old 03-19-2013, 11:41 AM   #3
coffeebob
Thanks Mango
a summary:
from www.rmeuropean.com
31312282459 $187.34 front strut
31312282460 $187.34 front strut
31336752735 $29.42 x 2 front strut mount
31306757046 $9 x 2 front bump stop
51717036781 $10.57 x 2 strut tower reinforcement plates
33522282461 $97.16 x 2 rear shocks
33521092362 $10.75 x 2 shock mount
33506757047 $10.99 x 2 bump stop
33526772864 $0.49 x 2 gasket
51718413359 $9.94 x 2 shock mount reinforcement plate
Struts/shocks only $374.68+$194.32 = $569
+ rest of hardwares $731
Old 03-19-2013, 01:10 PM   #4
Alex323Ci
My Ride: M3 & 323Ci (sold)
yes you can just get the shocks/struts by themselves. I'd check with getBMWparts.com for their pricing on genuine BMW parts.
personally I would really consider the Koni's, they also happen to be 20% off at most places this month(Koni Special)
as for rear shock mount there are the Meyle HD and some other good ones under $50
Old 03-19-2013, 01:15 PM   #5
My Ride: Lexus
Alex, are the ZHP dampers stiffer than the sport 330 dampers?
(this question is for the grand kodiak only)
Old 03-19-2013, 01:36 PM   #6
Alex323Ci
according to the magazine specs they're suppose to have different percentage of both compression and rebound. but I'm sure that was given to them by BMW and who knows what the baseline was, from previous sport, non-sport?? (I have seen specs on the 323/328 zsp and they also are firmer). I could quote the magazines and press release but then I'd be contributing to something I haven't seen confirmed. So wont go that far. but the short answer from literature is Yes.
Old 03-19-2013, 01:42 PM   #7
beckpiece
My Ride: '03 ZHP & '16 STi
I went with the Koni Yellows last spring when they were having the sale. Love 'em.
03 TiAg 330i ZHP
beckpiece is offline   Reply With Quote
Old 03-19-2013, 01:42 PM   #8
Grande D
My Ride: E36 M3
Get Konis or Bilsteins.
I pulled my stock shocks/struts at 105k and they all rebounded promptly, and had no leaks. That said, Koni Sport is the better option that will probably last 200k+
If you want to improve the ride without decreasing handling, you could buy the Koni FSDs.
Grand Kodiak- part numbers are the same. So I think the literature is wrong, as it is for the sway bars. I've had two ZHPs now and neither of you have had one. I've pulled two sets of ZHP struts/shocks and bought another. All the same as the newer sport shocks. Springs may be different, but most likely not, and the only way to know for sure would to have five or so ZHP and ZSP springs tested.
Meyle HD shock mounts suck. Buy Lemforder, Rogue or OE with reinforcement plates.
EDIT: I know I sound abrasive but I'm tired of my (fairly scientific) results on the shock/strut & sway bar matter being passed over.
It will change your life!
Old 03-19-2013, 01:52 PM   #9
My Ride: Lexus
IIRC, the part #s are different for ZHP, non-ZHP, sport struts/shocks, no? RealOEM shows different part #s
Old 03-19-2013, 01:58 PM   #10
Grande D
My Ride: E36 M3
Don't think so. They are all -459, -460. There is an M-Tech suspension or something of the sort made for european markets only.
Old 03-19-2013, 02:24 PM   #11
coffeebob
For Koni Yellow Adj, are these the correct parts (for 02 325i sedan sport pkg)
8741-1390LSport - Koni Left Adjustable Front Strut
8741-1390RSport - Koni Right Adjustable Front Strut
8040-1250Sport - Koni Adjustable Rear Shock (Quantity 2)
What setting should I use to get close to ZHP feel?
Can I use BMW shock mount/reinforcement plate with Koni?
thanks.
Old 03-19-2013, 02:46 PM   #12
Alex323Ci
well that could very well be. I know the swaybars are the same and thought the springs were confirmed years ago by JPR as the same too. it's refreshing seeing a ZHP owner actually stepping up and helping with another "zhp myth" getting correct info out. I know many of the earliest press release stated one thing and we all accepted it, and why shouldn't we. But as time goes on we find much was hype. I contacted one of the writers last month of EC on their article on the zhp specs. Telling them many things they still publish is known to be wrong. His answer was that many parts may have been superseded to the upgraded zhp parts. That was probably a reason for the current same part numbers on zhp and zsp. Which could be true, but Im not sure i buy that excuse. One thing I recall about the shocks is that I know Tischer BMW was selling the zhp upgrade suspension kit and shocks were listed as different then
Old 03-19-2013, 03:50 PM   #13
Grande D
My Ride: E36 M3
I'd be willing to chip in on getting some springs tested if I knew how to go about it, or who to contact for that sort of thing.
Some stuff has been superseded- for example the "ZHP 6 speed" became the 330 6 speed a year later. That sort of thing. I agree, it's not a rock solid blanket explanation for everything though.
Maybe Tischer included the earlier Sachs touring (better) shocks and struts, or the european Sachs M-Tech struts which have different part numbers and do seem to be stiffer. The later sport and ZHP struts/shocks are different from earlier sport shocks, maybe the ZHP was the first with the newer ones in 03? Dunno.
thanks.
Feel out the settings. Everyones preference is different. Stiffer is not always better, certainly from a ride standpoint but also sometimes from a grip standpoint. I think people usually set the rears halfway between stiff and soft.
