Sponsored by BimmerWorld
Old 03-16-2013, 03:15 PM   #1
honkifyoubonk
My Ride: E 6666
Looking for a little clarification on rotors
I have a little steering wheel shake when I brake so I pulled the wheels of today and found these black streaks on my rotors. Pads still have plenty left on them and were supposedly new when I bought the car a couple months ago. Any idea if that would cause the wheel to shake? Like I said it only shakes when I apply the brakes.
honkifyoubonk is offline   Reply With Quote
Old 03-16-2013, 03:16 PM   #2
dznuts007
My Ride: 2001 325i Sedan
Warped rotors?
dznuts007 is offline   Reply With Quote
Old 03-16-2013, 03:18 PM   #3
RKiepper
My Ride: 1999 E46 328I x2
+1 on warped rotors
Could also be worn fcabs.
RKiepper is offline   Reply With Quote
Old 03-16-2013, 04:44 PM   #4
jcns
My Ride: California
get one of those green sanding pads ( i forgot the name) but it's gentle enough to not scratch your rotors. Sand/remove that gunk. That's what's causing the insconsistent braking.
Change out the pads too.
I highly doubt you have warped rotors; it's not easy to warp rotors.
jcns is offline   Reply With Quote
Old 03-16-2013, 05:03 PM   #5
Alex323Ci
My Ride: M3 & 323Ci (sold)
i agree it looks like from what i can see the pad to rotors are catching inconsistantly. now i don't know if that's deposits left from the pads or something else. i'd first try to clean rotors and then re-bed the pads to the rotors.
if the previous owner put the new pads on already worn rotors i can see it being high/low spots. new rotors wear little grooves with new pads. these togehter aren't really a problem, but when new flat pads hit the old grooves (like a record) it''ll have high lowspots and inconsistent grabbing. often squeaks or noises is another side effect.
another very common symptom of brake judder when stopping are worn out bushings for the control arms.
Old 03-16-2013, 05:37 PM   #6
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
i would look into caliper operation as well
usually, rotors warp due to the pad making more pressure on one side of the rotor than the other, thus , one side heats up more
usually from slide pins not being greased with every pad change
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 03-16-2013, 07:54 PM   #7
lcoleman
My Ride: '79 Massey Ferguson
You can try brake cleaner and a scotch-brite pad, but more than likely you'll have to replace those rotors.
Old 03-16-2013, 08:59 PM   #8
Alex323Ci
nah the vast majority of "warped" E46 rotors are not warped. but high spots from pad material glazed/deposited on the rotor.
Old 03-17-2013, 04:34 PM   #9
honkifyoubonk
My Ride: E 6666
Would it be bad to just replace the rotors and keep the pads since they are still good?
Old 03-19-2013, 04:35 PM   #10
honkifyoubonk
My Ride: E 6666
anyone^?
Old 03-19-2013, 05:20 PM   #11
caddy1820
My Ride: 2004 325I
Do you get the shaking with light application of the brakes? If no then rotors could be fine. For example my car shakes when braking from higher speeds but not low speed (my FCAB are worn) pars on the way.
caddy1820 is offline   Reply With Quote
Old 03-19-2013, 05:38 PM   #12
lcoleman
That should be fine.
Old 03-20-2013, 07:00 AM   #13
honkifyoubonk
My Ride: E 6666
It does but obviously shakes more when I am going faster I am going to change rotors this weekend ill report back with results
Old 04-01-2013, 01:52 PM   #14
honkifyoubonk
My Ride: E 6666
replaced the rotors and no more shake
Old 04-01-2013, 05:01 PM   #15
dznuts007
