DIY Gauge Cluster Swapping: Mileage & DSC light Fix (M35080 Chip) - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 02-17-2012, 11:58 AM   #21
glhx
My Ride: 2002 330ci
http://www.obd2be.com/bmw-m35080-p-167.html
this device will change the m35080 to whatever you want. with the pa soft you should be able to recode the ike
glhx is offline   Reply With Quote
Old 10-18-2012, 10:53 AM   #22
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
WOA! thats awesome
redbull 325is is offline   Reply With Quote
Old 01-09-2013, 09:33 PM   #23
GBinSB
My Ride: 2001 325Ti
Does anyone in Santa Barbara / Ventura / Oxnard have the PA Soft 1.4 or other software that they can help me with? I have a used cluster on the way to me but I'd rather not take it apart to unsolder/solder the m35080 chip. And i have no experience with the odb software. The cluster is the exact same model # as the one coming out of my car but it has 100k more miles on it than my car really has.
GBinSB is offline   Reply With Quote
Old 03-22-2013, 11:17 PM   #24
jlmfernando
My Ride: 2000 328ci
2000 328ci
Originally Posted by mvitale27 View Post
anyone?
I bought BM like 126k miles , after 5 days mills jump up 698k so after I remove the battery and reconnect then jump down 44k now doesn't change my mills yet still 44k, how can fix my real milage
jlmfernando is offline   Reply With Quote
Old 06-13-2013, 03:29 AM   #25
lsNICKersl
My Ride: 04 Phoenix Yellow M3
Send a message via AIM to lsNICKersl
Sorry to bring up an old thread but I have an E46 M3 and had to change out my cluster due to it being shorted (the back light didnt work and rpm gauge would intermittently work), however with this used cluster i got from a friend, my DCS and Brake lights stay on. Would this work for my cluster as well ? to flip the chips around.
thanks for your time in advance
Mods
TC Kline D/A Coilovers 550/600 - Vorshlag Camber Plates - RE Spring Perch - RE Rear Shock Mounts - Turner Sways
UUC Urethane Bushings - Streamline Filter - AFE Scoop / Elbow - Fabspeed Headers - Magnaflow - Dinan Stg 2 (evolve tune soon)
lsNICKersl is offline   Reply With Quote
Old 09-18-2014, 06:33 PM   #26
Twitzid
My Ride: 318i touring 2001
Can i swap memory chip from km/h cluster to new mph cluster? Will it work in km/h after? I f*cked up my indocators when i removed them, and i dont know what to do. I have LHD car, but i am in UK now.
Twitzid is offline   Reply With Quote
Old 09-18-2014, 11:30 PM   #27
bxtch37420
My Ride: 2000 BMW 328i
It's serendipitious that this thread got bumped today because for the last two days I have been scouring the internet trying to find a DIY fix for my cluster that went bad a couple days ago. This thread stands out more than any of the other ones I've read.
I want to do this fix described but unfortunately the picture in the OP's follow-up post showing what the M35080 chip looks like doesn't appear anymore.
Can anyone advise what the chip looks like? Is it clearly marked?
My other question is, how important is it that the used cluster I get comes from the same vehicle? I have a 2000 BMW 328.
I am going to PM the OP and see if he will stick his head in to answer questions.
Even if he doesn't I am going to give this a try and I will post my results.
And Twitzid, to answer your question, I think you can enter one of the "test modes" by holding in the trip reset button and turning the key and there is a way to change from km/h to mph.
bxtch37420 is offline   Reply With Quote
Old 09-19-2014, 04:57 AM   #28
Twitzid
Thank you! Maybe somebody know any DIY for fixing dial indicators? I removed them because i wanted to change background to white, but after i replace them, speed and oil meter didnt work. I dont what to change whole cluster, any tip? Cheers.
When im doing test, all needles are moving like they shoud exept speed needle, it keeps stucking. When i was removing the speed needle, it came off with that metal stick in it. So is it possible to change only the motor for it?
Old 09-21-2014, 08:54 AM   #29
redbull 325is
My Ride: 325xit/6
no m35080 chip on a 2000 328i, you should be able to do the swap with only PA soft (iirc)
Royal Elite Club of 6 Speed Tourings - founder
Old 04-23-2015, 04:31 PM   #30
vancitye46
My Ride: 2000 323ci
so the only way to fix this is either do what op has said or find someone with NCS or similiar? i have PA Soft and ive tried and read that you can do it if you have the m35080 chip which my replacement cluster i bought at the wrecker does have,
i wonder if the stealership will do it
vancitye46 is offline   Reply With Quote
Old 05-27-2016, 10:03 PM   #31
Dark Abyss
My Ride: 2000 528i
This device is interesting. Has anyone used this?
If so, do you think a SOIC 8 pin clip will work so you don't have to do any soldering? Ebay has the programmers for around $40.
I was thinking about using it on my e39 cluster upgrade._nr_
Dark Abyss is offline   Reply With Quote
Old 09-23-2016, 12:15 PM   #32
IE46323CI
My Ride: BMW E46 M3
I knkw this is an okd thread, but, Op or Anyone, do you still have a picture of the circled chip that was taken out? Thanks
IE46323CI is offline   Reply With Quote
Old 03-23-2017, 02:54 PM   #33
brag288
My Ride: e46 320i '99
Originally Posted by redbull 325is View Post
Hey,
I had an issue with the gas gauge and the led display in my '01 325xi wagon.
I picked up a used cluster form a junk yard only to find that it triggered the manipulation dot and set off the DSC/ABS system.
I knew I could fix the DSC light with NCS Expert but I wanted to adjust the mileage so the car wouldn't be a true mileage unknown vehicle when I went to get it inspected next year.
I did a lot of research, bought some pointless scan tools and basically figured out that my M35080 chip equipped cluster couldn't be reprogrammed over the odb2 port. I bit the bullet and pulled apart the bad cluster:
Pulled off the needles and found the M35080
De-soldered the chip and re-soldered it on the new replacement cluster
and VOILA!
Notes:
-still need a windshield wiper tank, lol
-This is a pita to do so find someone who is good with a soldering iron and has done this sort of work
-OE cluster was Motormeter and replacement was Bosch.. everything seems to work as it should
-Take care of when you pull your needles to make sure you can put them in the exact right spot
Did you have any problems with the illumination on the clusters?I read that using a bosch one on an e46 that had motometer the cluster won't light.Do you know what year was the car that had the bosch cluster?
brag288 is offline   Reply With Quote
dsc, gauge cluster, m35080, manipulation dot, swap
