BMW E46 3-Series DIY: Spark Plug Replacement - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 62 votes, 5.00 average. Display Modes
Old 07-29-2012, 06:47 PM   #21
awszach
My Ride: 2001 BMW 325xit5mt
the part number is coming up air filters
awszach is offline   Reply With Quote
Old 08-03-2012, 11:43 PM   #22
325xi2004
My Ride: 2004 325XI
Just did this tonight.. 156k .. 4 of the 6 old plugs were original and 2 were Bosch. Installed 6 NGK double laser platinum. Thanks for the write up!
325xi2004 is offline   Reply With Quote
Old 08-04-2012, 03:43 PM   #23
awszach
Well guys I got it done . Not looking to pretty though what do u guys think?
Old 10-01-2012, 04:35 PM   #24
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
Originally Posted by jizzzoe View Post
Cool, thank you!!
Your car would look so sexy with a Boser hood. ZOMG.
aahmed2016 is offline   Reply With Quote
Old 01-12-2013, 02:39 AM   #25
J LAU
My Ride: E46 / E82 / E89
Great write up!
You actually dont need anti-seize for spark plugs. It is almost impossible to get to the right tq.
NGK Tech Bulletin - Anti-Seize Compounds on Spark Plug Threads
J LAU is offline   Reply With Quote
Old 03-23-2013, 12:11 PM   #26
mejori
My Ride: 325i
thanks for the write up!!! this was very helpful... 148k with original plugs!! didnt have an issue, just figured it was time to do it
mejori is offline   Reply With Quote
Old 03-29-2013, 10:57 PM   #27
rmccracke
My Ride: 330i and z3
Thanks for help, but....
I just completed the coil pack and spark replacement, I had a really really hard time reconnecting the wire/connect to the new coil packs. Did I miss a step somewhere? The plug and the coil pack lined up correctly, looked correct, but I had to really work/press/wiggle/shove the plug into the coil pack. Was there a special way to insert the plug?
Thanks for all of the pic's and demo's.
rmccracke is offline   Reply With Quote
Old 04-27-2013, 08:16 PM   #28
Dave1027
My Ride: '06 IR zhp coupe
Originally Posted by TerraPhantm View Post
I can't imagine doing the spark plugs without removing the cabin air filter housing... there's almost no room above cylinders 5/6 with that thing in the way. I'd rather just remove the 4 screws and have all the room I want
I wouldn't bother removing the positive terminal though.
+1 to this. I also removed the filter housing. It was very easy and give you a clear shot to the last two plugs. I think I would have had issues had I not removed the housing.
I also left the battery cable attached because I did not want to take the risk of losing my radio presets or bluetooth functions. I was not sure if I would but I did not want to find out the hard way.
to the OP for a great DIY.
Old 07-09-2013, 01:11 AM   #29
jizzzoe
My Ride: is no longer E46 :(
Send a message via Yahoo to jizzzoe
What should the plug gap be... anyone?
My Steel Gray '03 330Ci... I miss you, baby!
MODS: Purely aesthetic… Shadowlined, Smoked and LED'd out!
jizzzoe is offline   Reply With Quote
Old 07-14-2013, 12:10 PM   #30
Swendog
My Ride: 2004 330i ZHP
I just followed your write up on my 2004 330i ZHP with 126K. Bought the car with 105K and did the cooling system right away. I should have done the plugs a few months back when the valve cover & gasket were done, but I was traveling and had to have my mechanic do it. Took me less than an hour today to do the plugs. HIGHLY recommend removing the cabin filter housing and battery cable. It's really easy. Anti-seize is a must! Thanks for the DIY!
Swen
Swendog is offline   Reply With Quote
Old 07-14-2013, 10:02 PM   #31
jizzzoe
Agreed, very easy, did mine yesterday! Thanks!
Old 08-21-2013, 12:40 PM   #32
Vault
My Ride: 2005 330xi
Just wrapped this up - very easy project, thanks to your super detailed DIY! Mine was slightly more complicated as I have a strut bar directly over the fourth plug so I had to get creative. Also, I left the battery wire in place without issues.
I replaced them at 100,000mi with NGK, but the old ones were Bosch. I was surprised at how clean the old ones were! They didn't look at all like some of the ones I've seen on here.
Thanks for a great guide!
Just for kicks, a shot of my engine.
Plasti Dip Tutorial: [Link]
Vault is offline   Reply With Quote
Old 08-21-2013, 12:42 PM   #33
Solidjake
Radar Specialist
Solidjake's Avatar
My Ride: '13 328i Msport 6MT
Looks like my vid wasn't posted here so I'll have to do that as well
Old 11-02-2013, 01:37 PM   #34
califrench
My Ride: 2005 325i
Originally Posted by Shonky View Post
I would be a bit concerned about removing the positive battery cable and letting it flap around like that. I'd have to check the wiring to be sure but that's connected directly to the positive battery terminal (via that main fuse). If it touches the grounded/earthed both you will short the battery.
If you're going to disconnect the positive, disconnect the negative first.
Doing the Valve Cover gasket DIY, I spent a good 15 minutes before daring to pull the positive out like that. And finally figured it out, as you are unscrewing the bolt, make sure you're not touching the car frame because the frame is ground. But once the cable is detached from the bolt, there is not risk. You are effectively disconnecting your engine from the battery when you do that. If you look closely at the nut that secures the positive cable, it is connected to a block that is the end of the positive wire that runs all the way to the back of the car (the battery).
So once disconnected there is not risk at all.
In short, this is the cable that feeds electricity to the engine, not from the battery.
Battery ----- cable ------ connector with nut ----- cable2 ------ engine
I would still recommend staying away from the frame while handling that nut and making sure to close the plastic cap once done.
califrench is offline   Reply With Quote
Old 11-02-2013, 10:23 PM   #35
Shonky
My Ride: 2004 E46 M3
Just disconnect the negative first.
Shonky is offline   Reply With Quote
Old 11-10-2013, 06:13 PM   #36
futureSubie
My Ride: ZHP
Does it matter if the engine is hot or cold when doing spark plugs?
futureSubie is offline   Reply With Quote
Old 11-16-2013, 01:31 AM   #37
zxxzvzxcbxzcbzxc
Banned User
Excellent guide! Thank you. Great pictures. I'm going to bookmark this. Any advice how to check if they need replaced or not? Or brands?
zxxzvzxcbxzcbzxc is offline   Reply With Quote
Old 02-14-2014, 01:30 PM   #38
blu_olivz
My Ride: 325i
Just wanted to add my thanks to OP and others who gave helpful tips.
This was the first maintenance job I attempted and totally nailed. Easy and quick
You guys have helped boost my confidence in taking care of my car and getting to know it better, plus you helped me save on labor costs.
Looking forward to more DIY with you all...
blu_olivz is offline   Reply With Quote
Old 06-16-2014, 03:09 AM   #39
bstylz01
My Ride: 1999 328i
do u guys recommend BOSCH or NGK?
bstylz01 is offline   Reply With Quote
Old 10-08-2014, 07:19 PM   #40
joeycannoli
My Ride: 911
***All, the original site hosting the images was removed. The pictures along with the full DIY can now be found below***
BMW E46 3-Series Spark Plug DIY
BMW 325xi
Porsche 996 GT3
Joey Cuccaro
joeycannoli is offline   Reply With Quote
