E46 Xi Forum
Old 03-22-2013, 11:16 AM   #21
SamDoe1
My Ride: 4cyl of fury
I vote vacuum leak as well. Time to smoke test.
I don't remember if I said this earlier or not but have you checked the intake air temp sensor o-ring? It's hidden pretty far in there and might be the source of your leak. Also, spray the temp sensor with a shot of MAF cleaner spray while you have it out.
Old 03-22-2013, 12:30 PM   #22
basketthis
My Ride: state to state
I think i will be performing a smoke test. I'm reading online that people have been able to use the party store smoke machines to do the test. Is this a safe way to go about it?
basketthis is offline   Reply With Quote
Old 03-22-2013, 07:27 PM   #23
basketthis
Whatever piece is between the brake booster line and the intake seems to be letting smoke out. I pulled the brake booster hose from the brake booster and am blowing toward the engine. Would that cause my issue?
Old 03-22-2013, 08:15 PM   #24
basketthis
Here is more information on the part I am referring to:
http://www.bimmerfest.com/forums/sho...d.php?t=578766
Old 03-22-2013, 09:30 PM   #25
White_Knuckles
My Ride: 2003 325xi
Yeah, any smoke is "safe". I got a kick out of a guy on YouTube using a cigar and coffee can contraption, whatever works. I'd quit squirting carb cleaner around. It's a nasty solvent and may damage rubber stuff. Get starting fluid or propane and watch the idle leap up when a leak is sprayed. If you spot smoke, retest the area spraying a known combustion booster.
So you're inserting smoke into the booster line "blowing toward the engine". You see smoke rolling out of the vac amp and are asking the cause? Well, the cause may be a split plastic seam or damaged amp unit? If smoke is getting out then air is sucking in. Verify spraying that thing under idle. Use a flexible hose like from a vacuum cleaner, hold one end on your ear and listen for sucking sounds moving the other end around suspect areas. You're looking for a pretty major leak here not a micro crack. Move the hose around and listen to several areas. Then back to the smoke, injecting it in various spots looking to almost pressurize the engine vac system. That bugger has got to rear his head!
Old 03-22-2013, 09:46 PM   #26
basketthis
I just verified. In fact, the smoke comes from between the brake booster line and the sucking jet pump. seems the clamp has given up.
Old 03-22-2013, 11:29 PM   #27
White_Knuckles
My Ride: 2003 325xi
Hmmmm, could this be the "sucker"? Toss a stainless worm screw hose clamp on there, clear your codes and hope for gold!
I checked out that logger software and it seems like a great deal for features. Wish the seller had PayPal but will order it anyway. I got a bonus out of all this!! Thanks.
Old 03-23-2013, 07:04 AM   #28
basketthis
I used PayPal to pay for BMWLogger.
I'll be replacing the house should I be able to source one today.
Old 03-23-2013, 03:52 PM   #29
White_Knuckles
My Ride: 2003 325xi
So you think the hose is split not a clamp issue? Cut that thing down a little and clamp with a screw style. Thanks on the PayPal tip, I only spotted a list of Credit Cards. That is a neat product and certainly priced right compared to big-buck versions out there. Did you get the Amazon cable he recommends?
Old 03-23-2013, 07:22 PM   #30
basketthis
Turns out the hose is just old and firm enough to leave a gap between it and the nipple that it slides onto. No matter how much I tighten the clamp... Went ahead and ordered a new sucking jet pump with hoses and the new fittings for the brake booster. In the meantime, I put electrical tape where I believed it to be leaking. What a difference! When stopping, the car doesn't vibrate to a stop now. I used to think that I just broke in my pads incorrectly and was going to deal with it until next beale pad change. Turns out it was a pretty interesting vacuum leak causing the pulsing while braking. can't wait to get my new parts on and have this solved!
I ordered the "triumph obd2 cable" because it definitely has the ftdi chip that is needed to use the interface between the vehicle and your laptop. Seems other cables are hit or miss. I forked over 10 more dollars for the peace of mind that I was receiving the right item the first time. No troubleshooting. No gimmicks.
