Thread Tools Search this Thread Rating: Thread Rating: 179 votes, 4.99 average. Display Modes
Old 03-23-2013, 08:12 AM   #301
james1050
My Ride: 2001 BMW 325CiI Conv
Always on buzzing sound
I have installed the piezzo buzzer as stated,but now I have soft buzzing sound always on , sound gets higher when alarm is activated.
I'm concerned about my battery, is soft buzzing sound always should be on or is these any way deactivate the soft buzzing always on sound and only activate sound when locking and unlocking the doors?
Help is appreciate it .Thanks
james1050 is offline   Reply With Quote
Old 03-23-2013, 06:57 PM   #302
anton2718
My Ride: 2001 325i
i have the same thing, never bothered to do anything about it, it goes away once the car is locked for a bit
anton2718 is offline   Reply With Quote
Old 09-14-2013, 08:30 PM   #303
FooFighter94
My Ride: 2001 325Cic
"Pinning"
For those of you wondering how to pin the wires in easily, I think I found a way.
Earlier today I tried this DIY but the wires wouldn't stay in the plug in the car so it just fell out.
To remedy this, I took apart an old USB plug and took out two of the pins and soldered them onto the end of the buzzer wires with a little extra length of wire.
Looks like this!
ID:	526542   Click image for larger version
WVU Mountaineer
-2001 325Ci Convertible Slushie
-Orient Blue Metallic
-Koni Yellows, Otherwise hella stock
FooFighter94 is offline   Reply With Quote
Old 11-20-2013, 04:48 PM   #304
trentcdrums
My Ride: BMW 323i Sedan
So will it always buzz even when the car is off? I just hooked one up and that is what's it's doing.
Old 11-20-2013, 05:23 PM   #305
trentcdrums
$5 Alternative for Lock beep
Nvm, post #302 is right.
Old 11-21-2013, 07:53 AM   #306
Hovs13
My Ride: E46 325ci
The buzzing is a result of the peizo you have. I had the same issue. I replaced it with another piezo and no longer have the issue.
Hovs13 is offline   Reply With Quote
Old 11-24-2013, 01:28 PM   #307
3c
OO[][]OO
My Ride: E46 E53 R129W202W124
Originally Posted by FooFighter94 View Post
........... the wires wouldn't stay in the plug in the car so it just fell out..............
I did my installation using standard Bell [single wire [red/white]] from the local hardware store - it's perfect fit .
3C
E46 CLUB [SF Bay Area CA USA]
http://autos.groups.yahoo.com/group/BMWE46club/
US
'01 330-2Ci Sport [Silver/Black] 5sp MT 150k miles
'01 330Ci Sport [Silver/Gray] 5sp MT 8k orig. miles
'05 X5 4.4i Sport 70k miles
'99 Benz SL50R AMGsport 50k miles
'96 Benz C280 Elegance 16k orig. miles
'89 Benz 300TE Wagon 160k miles
EU
'93 Benz 250TE RWD Wagon Diesel 5sp MT 200k km's
3c is offline   Reply With Quote
Old 11-24-2013, 01:59 PM   #308
3c
OO[][]OO
I have installed the piezzo buzzer as stated,but now I have soft buzzing sound always on ................Thanks
I went from Buzzer to SIREN [TWO TONE siren 120db #273-0079 from the Shack] - usually any car alarms use Sirens and not Buzzers .... the buzzers are great for gates or smoke detectors lol.
For siome reason I did notice the Siren with less db was way louder than the buzzer listed with higher db .....
Try switching to SIREN to see if you like it better .....
3C
US
EU
Old 11-24-2013, 11:29 PM   #309
trentcdrums
Got a video?
Old 12-04-2013, 03:50 PM   #310
gregs0427
My Ride: 03 330ci 5speed
Wrong Harness?
I pulled the harness from behind the filter and mine had different colored wires does anyone know twhich ones are the right ones I tried every combination i could think of last night and none worked when i clicked the button on my remote. oh and mine is programed to flash when you lock it here is a pic of the wires i have
Name:	Alarm Wires.jpg
gregs0427 is offline   Reply With Quote
Old 12-04-2013, 04:08 PM   #311
trentcdrums
That's right. Look up th diy and you have to compare.. I did
Old 12-04-2013, 05:30 PM   #312
gregs0427
I am sure i have the right harness but the wires just dont match up
Edit: My clown noes does blink when locked too
Old 12-06-2013, 09:40 AM   #313
trentcdrums
Black goes to brown and red goes to the black with stripped. Twist the wire and insert
Old 12-11-2013, 03:15 AM   #314
/Stifmeister
My Ride: 330ci M-Sport
I tried this mod with a Piezo buzzer 86db and it works fine but it constantly buzzing quietly , would this problem be fixed if I was to buy a Piezo siren instead of a buzzer ? thank you!
/Stifmeister is offline   Reply With Quote
Old 12-11-2013, 10:53 AM   #315
philliplong
My Ride: 2002 325CI
Re: $5 Alternative for Lock beep
I have tried both but I don't have the constant buzz with the siren that I had with the buzzer.
philliplong is offline   Reply With Quote
Old 12-11-2013, 03:07 PM   #316
gregs0427
pretty sure when i do black to brown and red to black w/stripe i get a constant loud buzz
Old 12-11-2013, 07:26 PM   #317
trentcdrums
Supposed to. It stopped 5 minutes after locked or unlocked
Old 12-11-2013, 09:37 PM   #318
sygex
My Ride: 2001 330i
Hey guys,
First, I want to say thanks for this awesome and cheap mod!
I did the mod and everything works fine, however, the first time I did it, I hooked up the radioshack siren but didn't like the sound at all! Next I got this buzzer #273-0057 108db, it is actually a lot louder than the siren and it sounds better. Now that I hear it everyday, I am starting not to like it again. I was thinking of hooking up the actual horn of the car to the harness via relay but I wanted to know if anybody else has tried that? The horn sounds a lot better than the buzzer and its internals are not that different so it shouldn't be a problem.
sygex is offline   Reply With Quote
Old 12-11-2013, 09:57 PM   #319
philliplong
My Ride: 2002 325CI
Originally Posted by sygex View Post
Hey guys,
I have always wanted to do this.
Old 12-11-2013, 10:34 PM   #320
trentcdrums
Super easy. A monkey did mine.
