Old 03-23-2013, 10:23 PM   #1
GtownSpartan
My Ride: 2004 325i
Cool How do you pressure test Radiator Cap?
This is for a 2004 325i automatic. I've recently purchased a stant 12270 pressure tester but can't seem to pressure test the expansion tank radiator cap. Can the cap be tested?
thx,
Gtownspartan
GtownSpartan is offline   Reply With Quote
Old 03-24-2013, 07:09 AM   #2
Sansho
My Ride: 2001 325i
You may not get an answer, as people usually just replace the $10 cap periodically.
Sansho is offline   Reply With Quote
Old 04-27-2013, 11:29 PM   #3
AU328i
My Ride: 328i
you put it in a pressure cooker and turn it on for 10 minutes and if it is a full moon and the sea is parted when the times up then you are trolled.
really, you would need to buy a pressure test kit with a coupling for the cap that fits your car. ebay has them but they are usually ****. blue point make a good one but natrually is as expensive as its weight in iridium.
alternatively, you could just replace it and if thats not the problem and if its not, then you have a spare one and it didnt cost as much as a pressre test kit you used once then put on ebay.
AU328i is offline   Reply With Quote
