Old 03-23-2013, 02:24 PM   #1
bmwcanman
My Ride: 2004 330ci m-sport
Oil Leak - front passenger side
I've been trolling the forums and I can't find the right answer to my oil leak. The leak is not the valve cover gasket or the exhaust cam sensor.
The pictures below are taken standing at the front on the car. The first one is a close up of what I believe to be the source of the leak. It is a similar looking device to the cam shaft sensor except it has a tube running into it. The tube running into the device also shows in the third picture with the black cap on the top of it in the front left of the picture.
Anyone know what this is or if I should be looking at somewhere else?
Name:	Oil Leak 1.jpg
ID:	496709   Click image for larger version
Name:	Oil Leak 2.jpg
ID:	496710   Click image for larger version
Name:	Oil Leak 3.jpg
bmwcanman is offline   Reply With Quote
Old 03-23-2013, 02:27 PM   #2
04330ciZHP
My Ride: E46 E90
How well was the engine bay cleaned after the valve cover gasket and exhaust can sensor o ring? Could be a/c oil... or residue from other leaks
Sent from my LG-P999 using Bimmer App
04330ciZHP is offline   Reply With Quote
Old 03-25-2013, 12:44 AM   #3
bmwcanman
The residual oil from the other leak was cleaned up as much as possible and has now dried. Therefore, it is very easy to see the difference between fresh oil and the oil that had dried. There is now fresh oil on the swaybar below and splash pan.
Old 03-25-2013, 12:32 PM   #4
mikeson
My Ride: 99 323I
Did you find out and fixed it?
Because I think I have same place leak.
OEM xenon retrofit, Auto light/rain sensor DIY, OEM fog DIY,..........so many things DIY since 2000 :)
mikeson is offline   Reply With Quote
Old 03-25-2013, 11:24 PM   #5
bmwcanman
I understand from a BMW mechanic that it is likely the timing chain tensioner which is directly above the compressor hose in my pictures. The tensioner is behind a screw in cover 24 mm he believes. The tensioner has an aluminum washer type seal that likely needs to be replaced.
I have not had the time to verify this information, but it is the best advice I've received so far. I will likely take a closer week next week to verify.
Old 07-26-2014, 01:05 PM   #6
the xecutionr
My Ride: Imola M3 Vert
Did you ever get it fixed?
THE ONLY THING I FEAR IS FAILURE, AND FAILURE IS NEVER AN OPTION. GO HARD OR GO HOME.
the xecutionr is offline   Reply With Quote
