Old 03-18-2013, 12:23 PM   #1
kertiss
My Ride: '00 323i
HELP!! Car sputtered then died.
Hi - I have a 2000 323i with 190k miles. It was running great last week, but is now sitting dead in front of my house and I'm driving a rental that I can't afford to keep doing. Here's the timeline of incidents...
Low fuel light came on and I filled her up with about 10 miles to go. Got home with no problems then tried to start her again later that evening and she started but then sputtered out after a few seconds. Tried several more times and run-time got shorter and shorter until she wouldn't run at all. Immediately thought fuel pump, but tried again next day by keeping gas pedal to floor and letting it crank for 5-10 seconds. Revved up and ran smoothly for about 200 miles, starting and stopping the engine along the way. Finally, the SES light came on but she still seemed to be running fine and started up every time the engine was turned off.
After about the 4th time it was the same situation as before...ran for a few seconds at a very low RPM then died, etc. After letting it sit for a bit, I tried again with the pedal to the floor and cranking for a few seconds. Started up again so I hit the road in hopes of making it home and avoiding getting towed. Ran fine for about 30-40 miles then suddenly stopped responding to the gas pedal. The engine would rev up but the car wouldn't go any faster. If I floored it, the car would buck so I knew she didn't like that! After a couple miles of this, she just tuckered out and died again...on a country road, of course! I had her towed home and am obviously hoping this won't be a major repair, but I just need her to run again. Soon!!
Any insight/suggestions would be greatly appreciated!
kertiss is offline   Reply With Quote
Old 03-18-2013, 12:34 PM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
Umm, sounds like the fuel pump to me. You have a car with 190K miles. The pump is vital PM.
Old 03-18-2013, 12:39 PM   #3
Rhnyman
My Ride: 2001 BMW 330i
Agree. My fuel pump acted similar. Easy to check, you should hear the pump run when you first turn the ignition to ON. It is directly under the back seat on the right side. You should also have pressure in the fuel rail, but you SHOULD use a gauge to check this.
Rhnyman is offline   Reply With Quote
Old 03-18-2013, 02:28 PM   #4
kertiss
My Ride: '00 323i
Okay, thanks. I was leaning towards that but just wasn't sure. Will give it a try...
Old 03-18-2013, 02:28 PM   #5
ixtoxi
My Ride: 02 330xi, 88 325iX
I agree. Sounds like typical fuel pump death.
ixtoxi is offline   Reply With Quote
Old 03-18-2013, 03:17 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
2nd link below in my signature.
Old 03-18-2013, 03:23 PM   #7
kertiss
My Ride: '00 323i
Thanks jfoj. I've been checking out the forum for other posts on this subject and came across that one earlier this afternoon. I'm definitely thinking fuel pump now and hoping that is the correct fix!
Old 03-18-2013, 03:29 PM   #8
krnlight
My Ride: 2013 335i xDrive
It is the fuel pump. Mine just did that last week. Mine unfortunately died on a busy intersection.
Sent from my SCH-I535 using Bimmer App
krnlight is offline   Reply With Quote
Old 03-24-2013, 08:53 PM   #9
kertiss
My Ride: '00 323i
Well, we replaced the fuel pump on Tuesday (5 days ago) and the car has been running well since....and then the SES light came on again tonight!! Nothing "seems" to be wrong other than that. I got home but am very nervous about driving to work in the morning. Any other ideas or similar experiences?? I'm going to get the codes as soon as possible, but the last time we hooked it up, we just got a bunch of lean codes. Again...HELP!!!
Old 03-24-2013, 09:33 PM   #10
jfoj
Lean codes are typical, read the first link below in my signature.
Also search on Google - e46fanatics, jfoj, software and read that thread regarding a number of software and code reading options.
Old 03-24-2013, 09:48 PM   #11
krnlight
Did you also replace the fuel filter as well? I changed mine out this weekend after I did the fuel pump and there is a noticeable difference with the car.
Old 03-25-2013, 07:49 PM   #12
kertiss
My Ride: '00 323i
I asked about that but was told it was a pain in the butt to change out so we didn't. Mind you, the car was not on a lift as it was stranded in my parking lot at the time. I'll look for a DIY on that and will try to do it myself. Thanks very much for your replies!
Old 03-25-2013, 08:04 PM   #13
scarede46er
it's very easy. You need to jack up the car, take out the protective shield, pry open 3 clamps and be prepared to lose half a gallon of fuel.
Old 03-25-2013, 08:09 PM   #14
///MPR77
My Ride: 02 ///M3 Tri-Ped
+1 very easy, but...
Don't forget to pull the FP relay while the car is running until the car dies of starvation...this keeps the spillage down to a minimum.
Old 03-26-2013, 12:18 AM   #15
jonesenberg
My Ride: '04 330i ZHP 6spd
Def. change the filter while you're at it. It's quite possible, likely even, that the filter became clogged and has been dogging your fuel pump for a few thousand miles, which in turn caused the pump to burn up.
jonesenberg is offline   Reply With Quote
Old 03-26-2013, 12:31 AM   #16
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Well i didn't read that you changed the fuel pump already.... but anyone who reads this thread in the future, and is trying to diagnose:
go under the car near the rear passenger seat and beat on the plastic panel there with a wrench or tire iron.... If the car starts and runs after that, it's definitely the fuel pump.
It will die again, for sure though...so don't drive.
Sometimes when fuel pump is going out there is a solenoid that gets stuck... Jarring it with a vibrating hit will loosen it up and the car will start.
Use this only for diagnosis.
Bimmer4Lyfe is offline   Reply With Quote
Old 03-26-2013, 10:07 AM   #17
kertiss
My Ride: '00 323i
Hooked up to a scanner this morning and got P1188 and P1189 codes. Doing some research on the forum now to see what they could mean...
Old 03-26-2013, 10:08 AM   #18
My Ride: Lexus
n00b. the fuse, not the relay
Old 03-26-2013, 03:36 PM   #19
///MPR77
Ooops..that's what I meant.
My bad on that one...
Old 03-26-2013, 03:36 PM   #20
My Ride: Lexus
Ooops..
haha I know it was just a typo. Just bustin your hamhocks
