Old 03-14-2013, 08:30 PM   #1
andynb
My Ride: e46 m3
HPF running lean but only under very slight acceleration...
It's possible im just losing it but I noticed a couple day ago that my stage 2.5 is runnning crazy lean, but only under a light load at low rpm...
It idles fine and cruises great, and on boost is spot on but if im just accelerating slowly at low rpms (like normal city driving) it goes super lean like above 16.
Anybody else had any similar issues?
andynb is offline   Reply With Quote
Old 03-14-2013, 11:30 PM   #2
Forcefed M3
My Ride: HPF Stage 2.75
Mine did something like that for a long time, but I never worried about it. But after I changed my fuel regulator out I noticed that lean issue seemed to disappear.
Forcefed M3 is offline   Reply With Quote
Old 03-15-2013, 02:35 AM   #3
andynb
My Ride: e46 m3
Fixed. Turned out to be a bad wideband sensor
Old 03-15-2013, 01:16 PM   #4
Forcefed M3
Nice!!!
Old 03-15-2013, 02:48 PM   #5
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Do you run a lot of race fuel (110L)? Wonder if it just coated the sensor is all.
Old 03-17-2013, 10:01 PM   #6
andynb
My Ride: e46 m3
No I don't. But on another note the problem came back after a few days... but not quite as bad. Starting to think im just crazy...
Old 03-27-2013, 11:21 PM   #7
zac5
My Ride: Turbo M3
any update so far?
zac5 is offline   Reply With Quote
Old 03-27-2013, 11:50 PM   #8
andynb
My Ride: e46 m3
Originally Posted by zac5 View Post
any update so far?
Still doing it but not as bad as before... sort of lost at this point
Old 03-28-2013, 01:23 AM   #9
andynb
My Ride: e46 m3
Sometimes its almost normal, and sometimes its crazy lean...
Old 03-28-2013, 07:44 AM   #10
zac5
My Ride: Turbo M3
once the afr gauge read 16 or above, is your car run like a crap as well? i.e. surging/hesitate throttle.
Old 03-28-2013, 11:38 AM   #11
andynb
My Ride: e46 m3
%90 of the time it runs fine. But yes sometimes there is a little hesitation and surging.
Old 03-28-2013, 10:07 PM   #12
InDiGlOM3
My Ride: HPF M3 stg 2.5
Jumper harness. Jumper to ecm. Smaller connector. Fourth wire from bottom right. Bad continuity. No joke lol
Sent from my EVO using Bimmer App
Old 03-29-2013, 12:30 AM   #13
andynb
My Ride: e46 m3
Harness from factory ecu or aem? And I take it this happened to you lol?
Old 03-29-2013, 01:15 AM   #14
GRK///M3
My Ride: LSB M3
Pic or diagram...having same issue.
Sent from my SAMSUNG-SGH-I717 using Bimmer App
GRK///M3 is offline   Reply With Quote
Old 03-29-2013, 08:04 PM   #15
andynb
My Ride: e46 m3
Checked continuity on all wires on both harnesses and every wire is good...
Old 03-31-2013, 05:28 PM   #16
andynb
My Ride: e46 m3
So I took out my aem yesterday to check the harness but i didn't really do anything and once I put it back together it ran perfect.
but today I took it out again to clean all the connections because I figured that's what it must have been and I put dielectric grease on them and now itsback to runnning lean...
Old 03-31-2013, 05:31 PM   #17
Commanderwiggin
My Ride: 900rwhp Turbo M3
I think you found your problem...mabe send your harness/ems to get checked out if you can't resolve it.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 03-31-2013, 06:30 PM   #18
andynb
My Ride: e46 m3
Yup I believe you're right
Old 03-31-2013, 07:34 PM   #19
InDiGlOM3
Sorry i didnt get back to you. Continuity isn't the issue in whole. You got continuity but did you use a buzzer or actually read it. Your not getting enough. Those connectors in the harness. The one that is like eight inches long suck. The more you remove it and put it back on the more your going to **** it up. Factory connector side is good its the stupid white connector side that has the cheapest connectors in it. The ones that plug into jumper box. Best thing is to get a new harness put it on, zip tie it and never touch it again. I sourced better connectors just have not got to replacing them all.
Old 03-31-2013, 07:38 PM   #20
InDiGlOM3
By the way just so its clear. Its the little copper connectors on the end of each wire that is inside the white connector that plugs into jumper box. They are weak and provide no spring action in them to push against tabs in the jumper box. They are also weak dielectirc grease is a bad idea because the connectors are so weak you could possible made a barrier of grease between contacts.
