///M3 Forum
Old 03-14-2013, 11:50 PM   #1
emm3speed
My Ride: 2005 m3
Where is the Hk amp in an 02 e46 m3?
Saw a few links say its in the trunk and the bsw site shows in the rear side panel but its a vert.. Anyone know where it is? 02 m3 w/nav and Hk and 6cd.
Thanks!
emm3speed is offline   Reply With Quote
Old 03-16-2013, 12:05 PM   #2
emm3speed
My Ride: 2005 m3
Surprised noone knows?
Old 03-16-2013, 01:55 PM   #3
illestminimike
My Ride: Project Drama
For a vert or coupe? I couldn't really understand your first post.
Old 03-16-2013, 03:13 PM   #4
emm3speed
My Ride: 2005 m3
Its a coupe . Sorry for the confusion. The bsw link show a vert which mine is not. Just thought I'd ask before ripping the interior out.
Old 03-16-2013, 05:27 PM   #5
Slyde
My Ride: 2001 M3 TiAg
My coupe, non-nav has the HK amp left side in trunk under side wall carpeting. Just lift out the base carpet and the solid-ish panel below that (exposing the M-mobile air pump), then take out the 4 pegs (2 on the black tray and 2 in the carpet panel). Unclip the left trunk light (brake light/signal bulb carrier). You should then be able to bend back the side carpeting and see and access the amp. Fold the seat down and you I think you can remove the side carpet section with a little tugging. That is, I think there are no more anchors, but I cannot recall completely (I think it just wraps behind the closed seat a little bit). Well, don't yank too hard without looking to see how it's secured.
I'd be surprised if the Nav version has the amplifier anyplace else. Isn't the disc changer right there? I think the amplifier is on a metal shelf along with the changer.
Slyde is offline   Reply With Quote
Old 03-28-2013, 04:14 PM   #6
oojkoo
My Ride: E46 M3 996 C4
Thanks!
I always wondered about this myself.
oojkoo is offline   Reply With Quote
