Turbo parts - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-15-2012, 10:15 AM   #1
genius328i
My Ride: 328i
Turbo parts
I have 00 328i I'm looking to turbo would I have to change the pistons and rods and if so where can I find them. When ever I put in the year of my car I can't find anything if I only search the model then everything pops up need help ASAP
Sent from my HTC Sensation 4G using Bimmer App
genius328i is offline   Reply With Quote
Old 12-15-2012, 12:04 PM   #2
SpoonerDee
My Ride: 2005 E46
Don't bother doing it.
SpoonerDee is offline   Reply With Quote
Old 12-15-2012, 01:10 PM   #3
shendrick
My Ride: 05 zhp,08 M3,07 X3
I would only proceed once you have a line on an aftermarket kit from a reputable manufacturer who can provide several references for you to talk to and perhaps a demo car that you can drive. If you going to really boost it, then yes you would need new internals - but then you putting a lot of added stress on everything else - some of which might not have been designed to handle higher loads. So the net is that you want someone else to have sorted all this out - otherwise you'll spend a lot of $ and still have to replace you engine after yours melts.
shendrick is offline   Reply With Quote
Old 12-15-2012, 01:19 PM   #4
HBizzo88
My Ride: 2002 bmw 330ci
Techniqueturbo.com makes a turbo special for our cars. My 330 is turbo'd. The power is awesome but does cause vacuum leaks every so often. May just have to get better hoses n such. Not sure.
Running 8lbs of boost.
HBizzo88 is offline   Reply With Quote
Old 12-15-2012, 01:27 PM   #5
PH03NIX46
My Ride: 2003 M3
Oh yeah?
Eibach | Sportline | OEM Euro Headers | TTFS
PH03NIX46 is offline   Reply With Quote
Old 12-15-2012, 01:49 PM   #6
Alex323Ci
My Ride: M3 & 323Ci (sold)
the 328 internals are pretty good. you'll want to do a compression/leak down test likely to gauge how the engine is.
depending on kit used(and you will want to use a reputable brand kit) and boost you may need to change the head gasket to lower compression.
you can't really get a quick simple answer online without really doing lots of research from the maker of the kit. but yes the 328 unlike the 325/323 has the forged crankshaft and internal specs better suited for FI. go to the FI section of this forum for better answers from "those in the know".
Old 01-02-2013, 08:10 PM   #7
genius328i
My Ride: 328i
I'm about to start the break down and rebuild of my engine and wanted some opinions on good rods and pistons anyone know of any. I had wiseco pistons and rods in mind for my build I'm looking to push about 4-500 horses.
Old 02-25-2013, 06:17 PM   #8
genius328i
My Ride: 328i
Alright fellas I started the break down of my 328i so ill be posting pics from start to finish. Blown head gasket to fully turboed pics will be posted as soon as I get back home.
ID:	492494   Click image for larger version
ID:	492495   Click image for larger version
ID:	492496   Click image for larger version
ID:	492498   Click image for larger version
ID:	492499   Click image for larger version
Old 02-27-2013, 10:14 AM   #9
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Find a new block and head before you build it. Overheating the M52tu or M54 block causes it to warp. If you're going for 400+hp I'd start with a fresh block that hasn't been overheated.
You can find 84.5mm bore pistons from JE, Wiseco, or CP. Eagle rods are affordable and usable once they've been balanced.
I made right around 350whp before I lost compression on the bone stock engine. I was using a gt3076r @ ~12psi.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 03-06-2013, 09:58 AM   #10
genius328i
My Ride: 328i
Im thinking about using either the weisco combo or thr eagle rods and weisco pistons. Not sure yet will post new pic this weekend
Old 03-06-2013, 10:13 AM   #11
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Originally Posted by PH03NIX46 View Post
Oh yeah?
He needs LSD .
AMG-ETR is offline   Reply With Quote
Old 03-06-2013, 06:24 PM   #12
genius328i
My Ride: 328i
Was just searching the web for more things to complete my project I came across a link on the e90 fanatics page that the 325/328 can get 35-50 horses just buy upgrading to the 330 intake manifold. For them it looks like old news, but I never knew, so I'm just sharing the info.
Old 03-08-2013, 11:58 AM   #13
genius328i
My Ride: 328i
Was just about to order my eagle rods and came across conrod, rods. Does anyone know about these rods are they good.
Old 03-16-2013, 08:20 PM   #14
genius328i
My Ride: 328i
Ready ready to be removed ordering my rods Monday and my pistobs Friday. Thinking about adding the arp stud kit to my list as well
Old 03-16-2013, 08:28 PM   #15
genius328i
My Ride: 328i
Old 03-29-2013, 05:03 PM   #16
genius328i
My Ride: 328i
Hit a major bump in the road in my project then came across two really great deals. Both are for m3 motors, one is the s52 and the other the s54 which one is the best choice.
Old 03-29-2013, 05:25 PM   #17
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
OP you're bouncing around like a ping pong ball... Figure out what you're looking to accomplish and the best option for such. Don't just blow money ordering a lot of crap.
I looked into turbo for Quite a while and went with AA supercharger... Seemed like a safer, better bet.
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 03-29-2013, 09:05 PM   #18
genius328i
My Ride: 328i
I'm not bouncing around. I came to a choice buy a head and the block is warped. Or buy a whole new engine that would cost me the same amount as a m3.
Old 04-06-2013, 01:21 AM   #19
bimmerguy055
My Ride: M3
Send a message via AIM to bimmerguy055
if your just aiming for 400 crank hp then the stock internals should be ok. I've put 10k on my car with 20lbs of boost with no problems, but I'm sure I'm at the limit. Data log estimated 522 crank hp hehe
Without Failure There is No Success
bimmerguy055 is offline   Reply With Quote
