Old 03-30-2013, 06:14 PM   #1
Vince_B
My Ride: ZHP
Completely Disabling DSC on a ZHP
First I should say that I have read the previous threads on this topic and they are consistent with the 330 CI manual, and the advice of a BMW shop foreman. Unfortunately, it doesn't work on my ZHP. We had a BMW autocross today and by holding in the DSC (or equivalent) button long enough, we could completely disable all of the DSC on all E46s but mine. I don't know it there is something unique to the ZHP or if there is something wrong with my particular car.
What should happen is, after a brief press of the button, the CBC is disabled, but the DTC is still enabled. If instead, one holds the button in longer, like 5 to 10 seconds, both controls are disabled. What happens on my car is, a brief tap causes the DSC warning line to come on and DTC is definitely disabled, but the CBC is definitely still enabled. Pressing it longer (about 10 seconds) only causes the warning line to go out and the DSC to completely re-enable.
I really want to solve this some way (including removing a fuse, etc.) that does not disable the ABS. Although I normally autocross an Integra Type-R, I brought out my dead stock daily driver ZHP and it was much faster than I expected--even though the CBC interfered significantly. Any help would be much appreciated.
Vince_B is offline   Reply With Quote
Old 03-30-2013, 06:54 PM   #2
TerraPhantm
My Ride: M3 & ZHP
On my own ZHP the press and hold worked fine.
Old 03-30-2013, 07:24 PM   #3
Vince_B
My Ride: ZHP
@TerraPhantm, that's good to know. If that's true, then there is something wrong with mine. When you pressed and held, what lights or indicators did you see? Also, about how long did you have to press and hold?
Old 03-30-2013, 07:32 PM   #4
|2eckLesS
My Ride: 2004 330ci
works fine on my ZHP. Rarely ever done, but still works. 04 ZHP 82k.
|2eckLesS is offline   Reply With Quote
Old 03-30-2013, 07:54 PM   #5
silyb0y
My Ride: E46 330
Im not sure if I read it on this forum but I did read about a guy who had trouble turning his DSC off. He wrote he needed to do so to dyno his car. As it turned out - his button was faulty.
silyb0y is offline   Reply With Quote
Old 03-30-2013, 08:09 PM   #6
Vince_B
My Ride: ZHP
@I2eckLesS, I have the same questions for you as I had for TerraPhantm. When you pressed and held, what lights or indicators did you see? Also, about how long did you have to press and hold?
Old 03-30-2013, 08:12 PM   #7
TerraPhantm
My Ride: M3 & ZHP
Press and hold would cause the DSC and brake light to light up amber. Had to hold it for maybe 3 seconds.
Old 03-30-2013, 08:24 PM   #8
Vince_B
My Ride: ZHP
@TerraPhantm, Thanks for the info. It appears that mine is broken. Hopefully, it's something simple like a faulty button as SilybOy suggested.
Old 03-30-2013, 09:16 PM   #9
Grande D
My Ride: E36 M3
Mine goes all the way off. Nothing is different about the DSC in the ZHP compared to any other non-M with DSC.
It will change your life!
Old 03-31-2013, 01:36 AM   #10
TerraPhantm
My Ride: M3 & ZHP
Actually it is a different module compared to most non-Ms. For some reason, the ZHP got the RPA DSC module regardless of whether or not it was equipped with the RPA system.
Old 03-31-2013, 02:11 AM   #11
katu
My Ride: '04 330ci ZHP
Same here. I do it for autox.
katu is offline   Reply With Quote
Old 03-31-2013, 02:19 AM   #12
cvx5832
My Ride: 325Ci, 325Cic, C300
Any chance you got the codes read? Maybe there's a fault in the system that's preventing it to fully disengage?
cvx5832 is offline   Reply With Quote
Old 03-31-2013, 03:38 AM   #13
Vince_B
My Ride: ZHP
@cvx5832, that's a very interesting idea. I'll definitely check the codes, it can't hurt and might be the answer.
Old 03-31-2013, 07:40 AM   #14
|2eckLesS
My Ride: 2004 330ci
Pressing and holding DSC - First yellow DSC light comes on immediately, still holding for 5 seconds and the emergency brake light turns on and says "Brake" in yellow. If you have the emergency brake on the "Brake" light will illuminate red but as soon as it is relased, the "Brake" light turns yellow. Are you auto or manual? MT here.
Old 04-01-2013, 10:25 AM   #15
Vince_B
My Ride: ZHP
@I2eckLesS, thanks for your input. What you say is consistent with the manual and what others have described. I wish mine would do that. It's a 6-speed MT.
Once I get it fixed, I'll report here what the issue was. Hopefully, that will be sooner rather than later.
