Old 03-31-2013, 09:40 PM   #21
scarede46er
My Ride: 2001 BMW 325i ZSP
I think it is the ignition switch too. It makes the car act weirdly. For instance, with me, everything worked. Except sometimes, the car would keep cranking and it would not fire.
Old 03-31-2013, 10:09 PM   #22
pawelgawel
My Ride: 330CI
^ never had a starting issue...
While checking fuse box, I noticed the fuses #1-15 had very low voltage (light was very dimm on tester) with the key in pos II.
I dbl checked on friends e46 and his lit up bright...
Can someone give me some advice where the main ground is for the fuses?
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 03-31-2013, 10:50 PM   #23
pawelgawel
My Ride: 330CI
I found a thread where someone had issues with in the K-bus.. was lucky enough todropped the fuse panel and reconnected the plugs. Ill try this tomorrow.
Old 03-31-2013, 10:57 PM   #24
04330ciZHP
My Ride: E46 E90
Are you connections at the battery tight? What about at the alternator? Ground strap between the body and engine?
Sent from my LG-P999 using Bimmer App
04330ciZHP is offline   Reply With Quote
Old 03-31-2013, 11:19 PM   #25
pawelgawel
My Ride: 330CI
Yes.. went through all of that on saturday. I cleaned - wire from chassis to block and applied electrical grease. then +B as well where I have 13.9 volts going through. Battery and alternator all good...
Old 04-01-2013, 01:06 PM   #26
04330ciZHP
My Ride: E46 E90
How is the amp output of the alternator, may have the right voltage but not enough amps?
Old 04-01-2013, 01:44 PM   #27
pawelgawel
My Ride: 330CI
Just took out the fuse box... its one section that gets only 5.8 volts while all others get 11.6. Its all fuses #1-15 first row on the upper left...
It seems to me I lost ground to those items. Need to see where the bunch from that section goes to. (Where main ground is located)
I need someone who has some experience from taking this crap out.
Old 04-01-2013, 04:35 PM   #28
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
The fuse panel lifts up from the two back corners. Don't be surprised if you can't unclip it while it's in there. I did what everyone does...remove glovebox...screws all around...two hiding by 'string' hinges and two beneath...also under trim above I believe.
Then, just trace the wires and good luck...sounds like that's a significant find likely to yield a solution.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 04-01-2013, 05:13 PM   #29
pawelgawel
My Ride: 330CI
I did all that and those wires go back into the front wall... hard to read where it goes. I took out the K Bus port, Ill look into this and see if I see any drop in voltage if one wire is taken out.
Old 04-01-2013, 06:48 PM   #30
pawelgawel
My Ride: 330CI
Ok. I just did the obc check #9 and my battery shows 11.6 when all off. Im shocked because my multimeter is showing 12.4 directly. It could be also because i was playing with it the day before. ... so I dont know if its my battery. Its 4 years old. Also when on, obc shows 14.1 while my meter shows 13.8...
Any suggestions?
Old 04-01-2013, 09:15 PM   #31
dmax
dmax's Avatar
That's low for a battery...tl;dr if bat is 4-5 years old, just replace it. the alt is fine
See me in June!
dmax on Facebook
Mangofy your E46!
Old 04-01-2013, 09:16 PM   #32
dmax
dmax's Avatar
oh...assuming you're driving it enough to charge the battery fully....but a good battery, even low on power seems to still put out the right voltage...11.6 is down, again, unless you've been doing a lot of short trips, leaving your lights on...
GL
See me in June!
dmax on Facebook
Mangofy your E46!
Old 04-01-2013, 09:47 PM   #33
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
You should check your fuses in your E-Box. There are fuses in the E-Box that supplies 12v to several fuses.
I do not have my manual with me, but if you are only getting 5v instead of 12v, on a row of fuses, I would suspect the supply to those fuses. Ground has nothing to do with It.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-01-2013, 11:05 PM   #34
pawelgawel
My Ride: 330CI
^ could it be one of the relays as well? And do you mean in the fuse box by the driver side firewall? I did notice about 5 fuses in one row within a casing but didnt check that yet.
Old 04-01-2013, 11:09 PM   #35
pawelgawel
My Ride: 330CI
I wont be able to try anything till friday now.. ****ing work
Old 04-01-2013, 11:26 PM   #36
pawelgawel
My Ride: 330CI
Forgot to mention, when I pulled fuse #11 (5), volts when up to 9.3 from 5.6 that I was getting with the fuse in.
Old 04-02-2013, 01:56 AM   #37
BMWCaptain
Yes, there are 5 fuses in the E-Box (only 4 used) in the engine compartment. Just use your Meter to check voltages at the fuses. Try pushing them down to seat them.
Relays are specific to each item, ie: horn, fuel pump etc.
BMWCaptainE46.com
Old 04-02-2013, 07:20 AM   #38
pawelgawel
My Ride: 330CI
Ill look into that when I get couple of minutes.
One other specific, car will NOT start with hand brake on. I need to put it down to start. (Manual)
Old 04-02-2013, 07:26 AM   #39
NumbaOneNewb
My Ride: 2003 330CI Silver
Look. Answer me this. Has the car been in an accident?
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-02-2013, 07:49 AM   #40
NumbaOneNewb
Wont start with handbrake up? Wtf is up with that? The only thing I can think of that could even cause something whack like that would be...... an aftermarket kill switch installed as part of a security system as part of one or more requirements needed to satisfy in order for the car to start. Weird....
