How do I remove a output flange? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-05-2013, 08:32 PM   #1
nateo
My Ride: 2002 330ci
I'm attempting to replace a axle seal on my '02 300ci ragtop. I have the half axel unbolted and out of the way. However I am having trouble getting the drive flange out. I tried tapping it out with several different styles of hammers and also tried a cold chisel. Won't seem to budge. Is there a clip that needs to be removed or something? It doesn't appear to be enough room for a slide hammer.
Any help would be very appreciated. Thank you.
nateo is offline   Reply With Quote
Old 04-05-2013, 08:36 PM   #2
glhx
My Ride: 2002 330ci
dont know.....but dont hammer on it till someone pipes in that does. Usually if something wont come apart there is still something holding it on there that needs to come off. I would like to see this myself.
if you figure it out. post here so everyone knows
glhx is offline   Reply With Quote
Old 04-05-2013, 08:40 PM   #3
glhx
My Ride: 2002 330ci
http://www.bimmerfest.com/forums/sho...d.php?t=326409
try here.
the part you refer to is called the output flange. A google search for bmw output flange will give you some results
Old 04-05-2013, 08:46 PM   #4
glhx
My Ride: 2002 330ci
http://forum.e46fanatics.com/showthread.php?t=359219
here is a diy.....he used slide hammer or 2 pry bars...there is a spring clip in there holding them in. Its a pretty good diy. maybe a shorter slide hammer or some sort of gear puller
Old 04-05-2013, 08:55 PM   #5
glhx
My Ride: 2002 330ci
http://forum.e46fanatics.com/showthread.php?t=732982
diy (do it yourself) seal change
Old 04-05-2013, 08:58 PM   #6
glhx
My Ride: 2002 330ci
http://forum.e46fanatics.com/showthread.php?t=145570
this one has install torque specs.
and procedures with pictures of them removed
Old 04-05-2013, 09:12 PM   #7
nateo
My Ride: 2002 330ci
Looks like he pulled the whole thing out. I was afraid of that. Ill see if i can cheat and get two pry bars in there without taking the whole thing out.
