///M3 Forum
Old 04-10-2013, 07:35 PM   #1
Harlune
My Ride: 2002 Silver M3
Need Replacement Clutch recommendations
Hello e46fanatics,
I've got 130k miles on my 2002 M3 Convertible and it's time for a clutch replacement. I've reviewed the DIY and I intend to do it myself (I have tools & a shop though no experience) but I'm curios if anyone has recommendations on a replacement clutch?
I wasn't planning on replacing the flywheel unless it looked bad. Should I expect to need to replace it as well? If I do need to replace it is there any reason I would want a lightweight one?
I'm looking at the OEM kit on turnermotorsports.com should I consider anything aftermarket. I can't track my car (convertible) and I don't think I'll do much beyond some minor reprogramming.
I assume I should do the recommended replacements from turnermotorsports:
Exhaust Gaskets & Hardware:
11627830668 - exhaust seal ring x 2
11621318568 - bolts x 4
18301317898 - nuts x 4
Transmission Seals:
23127501580 - shift shaft seal
23121222769 - output seal
23127501328 - input seal
Additional Clutch Parts:
11627830668 - clutch pivot pin
11211720310 - pilot bearing
21207548052 - pressure plate bolts x 6
Anything else I should consider? O2 Sensors?
Harlune is offline   Reply With Quote
Old 04-10-2013, 08:06 PM   #2
n3985
My Ride: E92 soon?
If not tracking stick to OEM clutch. The flywheel is dual mass so it cannot be resurfaced but if good just re-use it. While you are there delete the CDV and consider getting a new slave cylinder so you don't have to replace that down the road. Also check the guibo and center support bearing, replace both if worn so again no repeat work down the road.
Also could be a good time to install a short shifter while down there. If the shifter side to side in neutral is sloppy then replace those shifter bushings too.
n3985 is offline   Reply With Quote
Old 04-10-2013, 08:17 PM   #3
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
I would definitely replace the flywheel at that mileage. Use stock parts as you can see it will last another 120k.
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 04-10-2013, 08:52 PM   #4
Harlune
Guibo, center support bearing, and slave cylinder make sense. I guess I should suck it up and just spend the $600 for the flywheel. Car's been really good to me and there's no reason I should cheap out on it now. Plus I'd love to get another 100k out of it.
Forgive the ignorance but why do I want to get rid of the CDV?
Old 04-10-2013, 09:42 PM   #5
n3985
My Ride: E92 soon?
CDV = clutch delay valve. It was BMW's way of making sure no one burnt out the clutch easily but also prevents smooth shifting. Search around the forums, easy DIY.
Old 04-10-2013, 09:47 PM   #6
dabears
My Ride: 2003 BMW M3
CDV delete has been the best mod to date for me, makes a big difference
dabears is offline   Reply With Quote
Old 04-11-2013, 12:31 PM   #7
Broach><330
My Ride: 330CI -E30 325 (S52)
Yep, CDV delete. And I'd go ahead and do rear main seal. As for the flywheel its more than likely okay. If you get to and it's all splotchy and smooth or uneven wear, then I'd overnight one. If so just get you a lightweight flywheel for sure. Make sure you get the tool to take off and replace the clutch.
High-line catback
Kosei K1's
Headers
3.15 Differential
Koni FSD, eibach sports
AA software
205k (9/16/13)
E30 S52B32 100,xxx
5spd ZF, JB LW fly, Megan Coils, OBD1 conv. Mishimoto with low temp stat, TRM 15x8, Black vinyl sport seats, MOMO mod 08, 2:93 LSD, Custom single 2.5" exhaust, SS headers, M3 rack, basically new everything on driveline.
Broach><330 is offline   Reply With Quote
Old 04-11-2013, 03:29 PM   #8
MachRc
E46Fanatic
MachRc's Avatar
chirp into 2nd and 3rd gear.
but yes extra 600 on another flywheel will def be worth the money.
Old 04-12-2013, 06:03 AM   #9
intelone
My Ride: e46 M3
Flywheel should be good. I left mine alone, and did not see any sign otherwise, when I changed my clutch at your mileage. Do the rear main seal and cdv as others have suggested. Check the guibo and csb replace as needed. If you want change the fuel filter since you're down there.
intelone is offline   Reply With Quote
